Recognise a PushButton in Netbeans (DigitalRead, SerialConnection, JSSC)
Hey guys,
i think this problem is so trivial that there is no tutorial that simple.
I have a Arduino Uno and a pushbutton connected to DigitalIn 2.
I want to use the pressing of the button inside my Java Code.
All I need is a Java code that recognises the press of a pushbutton. E.G. Printing out "button pressed". Later I want to use it in an If condition ( if button is pressed, then show image or do whatever)
I read about Jssc and have the library installed. Most tutorials however are about sending data to the arduino
The Arduino can send a serial message to the PC when a button press is detected.
A Java program on the PC can presumably detect when serial data is available, read the data and act on it.
Can you read a serial input in Java ?
Well, I tried some sample code and often I get things like CommPortIdentifier or SerialPort underlined red..
I presume that these are Java error on the PC. Is that right ?
