i bought some GSM and Wifi external antenna in one shipping!
but all this antenna in shape and connector are similar
and i dont know which is GSM or Wifi ?
all is 8 cm with UFL connector and white plastic body
i attach one of the antenna to SIM800L UFL connector and result is noting change with
previous spring gsm antenna (3cm spring antenna), both shows AT+CSQ equal to 25
i think external antenna must be better than spring 3cm spring antenna ...
i havnt ESP32 at this time for testing with wifi modules
srnet:
If its an antenna designed for the frequency, then you would normally expect it to be.
Did you get the antennas from a trusted source ?
ok !
no just buy from iran online market ! also there is another products in the market but they have a SMA connector and they needs to be converter cable for SMA Male to UFL, but this type dont need another parts
