Recommend an efficient way to power 2 DCMotors and Board.
Good morning! (I am from Greece so I just woke up :slight_smile: ).
I want to build a remote controlled car with 3 wheels, 2 of them are controlled by DC Motors and the third one is free to move.
-The board I will use is Arduino UNO.
-The DC motors require 4-6VDC.
-The DC motors will be driven by DRV8835 Dual Motor Driver Carrier.
-What is the safest and most efficient way to power my Arduino and the 2 DC Motors ? Obiously I understand that it is not safe to power the motors directly from Arduino Vout pins.
-Also, if eventually two external power sources is used, must they have common GND ?
This is my available components:
  • 1 x Battery pack of 9 volts (6 x 1.5AA batteries)
  • 1 x Battery pack of 6 volts (4 x 1.5AA batteries)
  • 1 x Arduino UNO
  • 2 DC Motors 4-6VDC
  • 1 x DRV8835 Dual Motor Driver Carrier
  • Voltage Regulator L7805CV -> 5V ( I don't know if it's needed ).
  • Bunch of capacitors and resistors.
  • Breadboard & Jumper wires obviously :stuck_out_tongue:
Thanks in advance!
Really... No one?
connection diagrams here
