Recommendation for 22-28awg wire stripper
Is there any good precise wire stripper for the sizes above under 20-25 usd? From either amazon or aliexpress.
Thanks for any recommendation
What is the main difference between this type of stripper to that one ? What would you recommend to choose?
The first one, in theory, is supposed to be more precise and not nick the wires but it looks needlessly complex and the Klein will probably work for all your needs. The exception is stripping Teflon insulated wire and neither will work especially good for that.
These Ideal Stripmasters that I've owned since the 60s are specially made for Teflon and are expensive but work flawlessly.
I have and like this type:
" Amazon.com "
$25.00 maybe 30 years ago :woozy_face:.
For stripping the insulation from individual wires, IMO these are the best.
OK Industry ST-100
No wire nicking or cutting of strands
Suggest two.
  • 26-24 (will do 28)
  • 24-22 (will do 20)
These look interesting, have not used them.
I have used this type of stripper and the problem with it is that you just cant strip very small of wire because the way this thing build. This is why i was looking for more advanced stripper - to be able to strip tiny part of wire
I have found these as a good backup in my toolset, but sometime need a bit of pulling force if striping off more than 10mm from heavy wire.
Tom.. :smiley: :+1: :coffee: :australia:
Do you think this One is could be just fine as the Klein one? Its 1/4 the price. I was wandering how much the more expensive one is better?
I use a Jokari super 4 pro. Its automatic.https://jokari.de/en/Super-4-Pro-2.htm
Micro-strip or Mini-strip by Klippon have served me very well for many years.
For fine stuff like wire-wrapping wire, a purpose made stripper like Jonard OK wrapping tool has a traditional groove cutter that works really well.
