changks
February 15, 2014, 6:02am
1
Dear all,
I'd like to control the LED on/off via a Grove relay.
The LED power supply is: 277 VAC 0.55A 50/60Hz (input) and +42VDC 2.9A (output).
The Grove relay options:
(1) Grove - Relay http://www.seeedstudio.com/depot/Grove-Relay-p-769.html
(2) Grove - SPDT Relay http://www.seeedstudio.com/depot/Grove-SPDT-Relay30A-p-1473.html
(3) Grove - 2-Coil Latching Relay http://www.seeedstudio.com/depot/Grove-2Coil-Latching-Relay-p-1446.html
(4) Grove - Solid State Relay http://www.seeedstudio.com/depot/Grove-Solid-State-Relay-p-1359.html
My questions:
(1) Are there any Grove Relay can meet the requirements? I see the Grove Relay only can handle +30VDC.
(2) Should I connect the Grove Relay to the input end (VAC) or the output end (VDC) of LED power supply?
(3) any other suggestions for this project?
Thanks all!
Michael
knut_ny
February 15, 2014, 6:20pm
2
If you want dimming you have to coontrol the DC-side.
A N-channel logic level MOSFET can do this
changks
February 15, 2014, 9:40pm
3
Thanks. I just like to turn on/off LED lights. I like to know more information before doing it.
knut_ny
February 15, 2014, 10:00pm
4
You will find ideas to mosfets in other posts
system
February 15, 2014, 10:02pm
5
Any relay rated for 240ac would be fine.
The other option would be to switch the led on via the lower voltage dc side, which could be done with a mosfet.
changks
February 17, 2014, 3:18am
6
Yes. I will try to get one MOSFET.
I also see a good post how to use a relay to the VAC-end.
http://www.glacialwanderer.com/hobbyrobotics/?p=9
http://www.gigamegablog.com/2011/01/08/netduino-let-there-be-light/
It seems it's safer to work on VDC-end.
