Reconnect Arduino WiFi Shield
Hello,
I have a problem with a WiFi Shield on an Arduino Uno.
In the location I want to put the system there are 4 networks. If one looses connectivity the shield should reconnect to other network.
I am posting on Google Docs information regarding some sensors every 10 minutes. If i cannot send 5 times the sensors, i will start a reconnecting cycle.
The problem is that if a reconnect cycle starts, even if i have the network up, the wi-fi doesnt connect to it.
My reconnect function is this:
void reconnect () {
WiFi.disconnect();
// status = WL_IDLE_STATUS;
delay(5000);
// if (status != WL_CONNECTED) {
status = WiFi.begin(ssid1, pass);
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid1);
delay(20000);
status = WiFi.begin(ssid2, pass);
Serial.println(ssid2);
delay(20000);
status = WiFi.begin(ssid3, pass);
Serial.println(ssid3);
delay(20000);
status = WiFi.begin(ssid4, pass);
Serial.println(ssid4);
failed =0;
delay(20000);
if (status == WL_CONNECTED) {
slcd.setCursor(0, 0);
slcd.print("Connected to");
slcd.setCursor(0,1);
slcd.print(WiFi.SSID());
failed =0;
delay (3000);
How can it reconnect to the wrong network - do they have the same SSID as each other?
Geoff
No.
I have 4 SSID, with the same password. After some time the Wi-Fi doesn't connect to network. After 5 connection failed, i try to reconnect to the network.
The function above does that.
Ah sorry I misunderstood. The idea is that if it drops a connection it associates with the next SSID by design.
Any news or solutions to this problem?
