Record by 2 microphone with TMRpcm
I try to use 2 microphone recording audio, but I don't know why it fails.
I first start with 1 microphone with following code, and everything is fine.
#include <SD.h>
#include <SPI.h>
#include <TMRpcm.h>
#define SD_ChipSelectPin 4
TMRpcm audio; // create an object for use in this sketch
  Serial.println("begin");
  if (!SD.begin(SD_ChipSelectPin)) {
    Serial.println("SD Fail");
    return;
  }else{
    Serial.println("SD OK");
  // The audio library needs to know which CS pin to use for recording
  audio.CSPin = SD_ChipSelectPin;
  //start recording
  audio.startRecording("test1.wav",2000,A0);
  Serial.println("Begin");
  delay(20000);
  audio.stopRecording("test1.wav");
  Serial.println("End");
  return;
Then I try to record by two microphone. But the second wav file could play, the first one cannot open. I have no idea why it happen.
#include <SD.h>
#include <SPI.h>
#include <TMRpcm.h>
TMRpcm audio2;
    return;
  }else{
  audio2.CSPin = SD_ChipSelectPin;
  //start recording
  audio2.startRecording("test2.wav",2000,A1);
  delay(20000);
  audio2.stopRecording("test2.wav");
  return;
  audio2.stopRecording("test1.wav");
Should that not be
Sorry it's a typo. I code 'test2.wav' in my code.
Don’t you mean to say you typed in your code for this question and did not copy and paste it from the IDE?
