Record peak microphone readings
I am trying to make a prototype SPL meter for a college project. I need to collect the average level over hour periods. This information will then be inputted into a mySQL database.
I have copied this code from the adafruit website:
And my equipment setup is the same too:
In the serial monitor i am getting readings in volts, which is fine for now.
As you can see in the code, a reading is taken every 50ms. That is 72,000 readings in an hour.
What i need (ideally within the pc) is to calculate the average (im guessing - add all of the 72,000 readings, then divide by 72,000). This will give me a number that i can will go into the database and be displayed on a .php website.
Help and advice would be very much appreciated!
Example Sound Level Sketch for the
Adafruit Microphone Amplifier
const int sampleWindow = 50; // Sample window width in mS (50 mS = 20Hz)
unsigned int sample;
   unsigned long startMillis= millis();  // Start of sample window
   unsigned int peakToPeak = 0;   // peak-to-peak level
   unsigned int signalMax = 0;
   unsigned int signalMin = 1024;
   // collect data for 50 mS
   while (millis() - startMillis < sampleWindow)
      sample = analogRead(0);
      if (sample < 1024)  // toss out spurious readings
         if (sample > signalMax)
            signalMax = sample;  // save just the max levels
         else if (sample < signalMin)
            signalMin = sample;  // save just the min levels
   peakToPeak = signalMax - signalMin;  // max - min = peak-peak amplitude
   double volts = (peakToPeak * 3.3) / 1024;  // convert to volts
   Serial.println(volts);
See Storing, and averaging microphone readings for more information.
What, exactly, are you measuring? I suspect that trends may be more interesting than an average over a one hour period.
