Recording analog input data stream and playing back for development
Problem
I'm trying to write a program for my Arduino project to detect REM (the dreaming stage of sleep) with electrode sensors. However, it's time consuming to only test my code at night when I'm sleeping.
I'd like a way to record the electrode sleep data at night, and then be able play it back through the arduino program when I'm awake, or run sections of it, in order to develop the code.
Any guidance appreciated.
Details/ More Questions:
data file size
If I collect the data from the serial monitor and save it to a text file, the data ends up being around 3mb, because it's a stream of data for about 8 hours.
recording
It would be ideal to save the data without having to be connected to the computers' serial port for battery life reasons, but the serial monitor works for now.
playback latency?
The part that confuses me most is how would I play pack the data? The data is a stream, but Arduino doesn't run its loops at consistent intervals.
For example, I might collect this sleep data in 4 void loops:
millis: 1  electrode: 234
millis: 7  electrode: 238
millis: 14  electrode: 230
millis: 19  electrode: 229
But I cannot ensure that I play back the electrode data through the device at the exact millisecond intervals they were recorded because the arduino loops seem to vary in millis.
And to complicate matters more, if I had to add an SD card to read back the mock data, wouldn't reading the SD card slow the loops down further? These inconsistencies with playing back the recorded data seem like they would effect the my ability to write a program for real data based on mock playback data.
But am I over thinking this? Does it not make that much of a difference?
How might one go about recording and playing back long streams of data or thinking about this problem?
Update:
It seems like I might want to make my program work at a consistent sampling rate- sampling rate tutorial. Up until now, I've been taking data on every loop, instead of at a consistent rate. This would probably mean changing my existing code. One thing I'm still confused about is how do you know what sampling rate to pick to ensure that you don't have any void loops that take longer than the samping rate?
What sort of data are you recording? Is it sound? or an analog output of some sensor?
I'm recording from electrodes:
Each connected to the an analog pin on the Uno.
By definition, your data is NOT streaming. You are asking the A/D converter for an integer of data and then storing it. There is NO data until you ask for it. So, remember the time since the last reading in milliseconds and store the difference that along with the integer of data.
On playback, wait the stored number of milliseconds associated with that data and then do your thing with the data.
So, about 104 bytes per second. That shouldn't be too fast for an SD card.
Only one of each?
  1. Thanks for the clarification. Do you know what people are referring to to when they say data stream in arduino land?
  2. Wouldn't this method of waiting the number of milliseconds not work in the case where the void loop lakes longer than the interval of the stored data? The loops tend to vary on their own already. But even more, if I'm reading the data from an SD card, wouldn't that slow down the loop by quit a bit? So if the data's interval is 6 ms, but the void loop is now 20ms I wouldn't be able to play back the data in time.
But would reading from the SD card (or writing to it) on every loop slow the loops down and throw off the times? Is what I'm asking making sense?
Three electrodes each. But 3 electrodes = 1 flow of data. So one flow of data for EMG and one for EOG.
Not really. In my world, streaming data means you have NO control of when the data is sent, not even the interval between packets. You have to always be ready to read and process it.
The Sparkfun OpenLog is an inexpensive and reliable standalone data logger that simply records everything you choose the Serial.print(). Gigabytes of it, if you like.
If you have a 5V Arduino, be sure to use a level shifter on the OpenLog RX input.
So 6 analog inputs. 104 bytes per second would be about 17-1/3 bytes per analog input per second. Can you show a short sample of the currently logged (Serial Monitor) data?
Sorry for the confusion. 3 electrodes === 1 electrode channel. 1 electrode channel per 1 analog input. So 2 analog inputs.
Here's an example. This isn't the raw data though.
06:30:34.827 -> average: 34
06:30:35.336 -> average: 22
06:30:35.861 -> average: 35
06:30:36.351 -> average: 28
06:30:36.825 -> average: 35
06:30:37.339 -> average: 33
06:30:37.841 -> average: 35
06:30:37.876 -> EOG interpretted: LEFT
06:30:38.320 -> average: 40
06:30:38.830 -> average: 23
06:30:39.361 -> average: 41
06:30:39.895 -> average: 53
06:30:40.056 -> EOG interpretted: RIGHT
average means the average of the last buffer of raw EMG muscle data.
EOG interpretted is the programs calculation of the raw EOG eye movement data numbers into RIGHT or LEFT eye movements.
I could get a sample of the raw data to show you too in a bit.
Oh. So it is "Only one of each" kind of board.
It looks like your 'average' values are about once per half second. Did you want to record the RAW data or just the average every half second?
I sort or wanted to record the raw data, but maybe I don't need to. So I think I see what you're getting at- maybe if the data I'm recording doesn't need to be super high resolution I won't have issues with the loops not being fast enough.
Most microcontrollers ADC's have a free running mode. You can use that and from the interrupt place the sample in a buffer. At some interval you would then copy the buffer and persist it somewhere, sd card, eeprom, whatever.
Basically the reverse. Have a timer interrupt read samples from a buffer and output them using PWM or a DAC (whatever is available). While the interrupt routine does its thing you have some time to read stored samples into a second buffer. When the buffer the interrupt routine reads from is empty, you swap the two buffers. Now the interrupt has fresh data to read from and you have another buffer to read data into.
This technique is called double buffering if you want to read up on it.
thanks for teaching me about this. I'll read up on it
Which presumably refers to a differential pair of two electrodes, and a third electrode as an "active ground".
For these microvolt signals, it is not just a matter of a single electrode picking up a signal.
Yes exactly
I created sample code for doing what I need to do. I haven't tried in the real environment yet, but wanted to share what I have so far.
@johnwasser's suggestions inspired my idea to create a consistent sampling rate and set it to 100ms. My scientist friends are collecting sleep data with consistent sampling rates, so this seems to be standard. I have yet to change my actual code to collect at a consistent sampling rate, so there may be new issues when I try this in the real code.
@nicolajna suggested some more advanced ideas I have yet to implement or understand fully. I couldn't find any simple examples of double buffering on arduino with simple int values. So I will need to look more into these suggestions if I run into more issues, which may happen when I try this in the real code/environment. If anyone knows of a good tutorial or example on double buffering, please share.
Run the test code
You can test this code with an SD card reader connected and something connected to A0. I connected A0 to a pushpin and resistor which gave me changing values even without pressing the pushpin, due to electrical noise, I believe. You could probably also just ground A0 but I found this didn't give me as many varying values. If you want to record more meaningful data, connect some sensor or potentiometer to A0.
Before starting, set bool recording = to recording or playback mode.
Serial monitor in recording mode
15:29:06.404 -> Mode: RECORDING
15:29:06.404 ->
15:29:06.404 -> Initializing SD card...initialization done.
15:29:06.437 -> deleting file.
15:29:06.437 -> DATA.TXT doesn't exist. Now creating....
15:29:06.475 ->
15:29:06.475 -> RECORDING...
15:29:06.509 -> 100: 312
15:29:06.615 -> 200: 214
15:29:06.728 -> 300: 110
15:29:06.800 -> 400: 44
15:29:06.909 -> 500: 24
15:29:07.017 -> 600: 20
Serial monitor in playback mode
15:29:17.519 -> Mode: PLAYBACK
15:29:17.519 ->
15:29:17.519 -> Initializing SD card...initialization done.
15:29:17.519 ->
15:29:17.519 -> PLAYING BACK...
15:29:17.621 -> handling data: 100: 312
15:29:17.697 -> handling data: 200: 214
15:29:17.811 -> handling data: 300: 110
15:29:17.925 -> handling data: 400: 44
15:29:17.997 -> handling data: 500: 24
15:29:18.111 -> handling data: 600: 20
Full Code
   SD card attached to SPI bus as follows for Arduino Uno:
 ** MOSI - pin 11
 ** MISO - pin 12
 ** CLK - pin 13
 ** CS - pin 5
#include <SPI.h>
#include <SD.h>
File myFile;
bool recording = // set whether we should be recording data or playing back data
//  false;
  true;
bool readData = true; // false when we saved a data point from the SDcard to the input string
// and haven't handled it yet during a sampling rate moment,
// so we to pause reading data, ie pause before reading the next data point from the SD card,
// until we handle the last data point. Not used in recording mode.
bool playData = true; // false when we get to the end of the SDcard file. Not used in recording mode.
int samplingDelta = 100;
unsigned long startTime = millis();
unsigned long actualTime;
unsigned long loops = 0;
int stringIndex = 0;
const size_t BUF_DIM = 50;
char inputString[BUF_DIM];
char inputChar;
int  reading;
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.print("Mode: ");
  Serial.println(recording ? "RECORDING" : "PLAYBACK");
  Serial.print("Initializing SD card...");
  if (!SD.begin(5)) {
    Serial.println("initialization failed!");
    while (1);
  Serial.println("initialization done.");
  if (recording) {
    deleteAndRecreateFile();
    myFile = SD.open("DATA.TXT", FILE_WRITE);
  if (!recording) {
    myFile = SD.open("DATA.TXT");
  Serial.println(recording ? "RECORDING..." : "PLAYING BACK...");
  actualTime = millis();
  if (!recording && readData && inputChar != EOF ) {
    inputChar = myFile.read();
    while (inputChar != '\n' && inputChar != EOF) {
      inputString[stringIndex] = inputChar;
      stringIndex++;
    if (inputChar == '\n' || inputChar == EOF) {
      readData = false;
    stringIndex = 0;
  if (recording) {
    reading = analogRead(A0);
  bool timeToCollectData = actualTime - startTime >= samplingDelta;
  if ( timeToCollectData) {
    if (recording) {
      writeToSD(reading, actualTime,  myFile);
      if (playData) {
        if (inputChar != EOF) {
          handleData(inputString);
          readData = true;
        if (inputChar == EOF) {
          playData = false;
    startTime = startTime + samplingDelta;
  if (recording && millis() > samplingDelta * 15) stopCollectingData(); // To limit the recording for testing purposes.
void handleData(String data) {
  // real code would go here
  Serial.print("handling data: ");
  Serial.println(data);
void  writeToSD(int val, unsigned long time, File file) {
  if (file) {
    Serial.print(time);
    Serial.print(": ");
    Serial.println(val);
    file.print(time);
    file.print(": ");
    file.println(val);
    // if the file didn't open, print an error:
    Serial.println("error opening test.txt");
void deleteAndRecreateFile() {
  Serial.println("deleting file.");
  SD.remove("DATA.TXT");
  if (SD.exists("DATA.TXT")) {
    Serial.println("---ERROR DELETING----DATA.TXT exists.");
  else {
    Serial.println("DATA.TXT doesn't exist. Now creating....");
    myFile.close();
void stopCollectingData() {
  myFile.close();
  Serial.println("Done recording. delaying code for a long time...");
  delay(9000000000);
Here's an updated example where, instead of saving each line of the SD card as a string datapoint during playback mode ("500: 24"), each line of the SD card (ex "500,24,110") is parsed into 3 different data variables : time of sample, emg, eog.
There's also a place to run the data, recorded or in real time, through the program:
    if (recording || playData) {
      //---------regular program goes here--------
      // example of handing data
      handleData( timeData, emg, eog);
Serial monitor
14:47:45.674 -> Mode: RECORDING
14:47:45.674 ->
14:47:45.674 -> Initializing SD card...initialization done.
14:47:45.674 -> deleting file.
14:47:45.739 -> DATA.TXT doesn't exist. Now creating....
14:47:45.739 ->
14:47:45.739 -> RECORDING...
14:47:45.782 -> timeData: 100 emg: 396 eog: 357
14:47:45.855 -> timeData: 200 emg: 366 eog: 357
14:47:45.959 -> timeData: 300 emg: 354 eog: 351
14:47:46.066 -> timeData: 400 emg: 346 eog: 345
14:47:46.141 -> timeData: 500 emg: 339 eog: 338
14:47:46.245 -> timeData: 600 emg: 333 eog: 332
14:47:46.352 -> timeData: 700 emg: 328 eog: 326
14:47:46.453 -> timeData: 800 emg: 322 eog: 320
14:47:46.555 -> timeData: 900 emg: 318 eog: 316
14:47:46.658 -> timeData: 1000 emg: 312 eog: 311
14:47:46.764 -> timeData: 1100 emg: 308 eog: 307
14:47:46.868 -> timeData: 1200 emg: 305 eog: 303
14:47:46.936 -> timeData: 1300 emg: 301 eog: 299
14:47:47.046 -> timeData: 1400 emg: 298 eog: 296
14:47:47.155 -> timeData: 1500 emg: 296 eog: 294
14:47:47.155 -> Done recording.
14:48:00.703 -> Mode: PLAYBACK
14:48:00.703 ->
14:48:00.703 -> Initializing SD card...initialization done.
14:48:00.703 ->
14:48:00.703 -> PLAYING BACK...
14:48:00.808 -> timeData: 100 emg: 396 eog: 357
14:48:00.881 -> timeData: 200 emg: 366 eog: 357
14:48:00.992 -> timeData: 300 emg: 354 eog: 351
14:48:01.101 -> timeData: 400 emg: 346 eog: 345
14:48:01.205 -> timeData: 500 emg: 339 eog: 338
14:48:01.277 -> timeData: 600 emg: 333 eog: 332
14:48:01.387 -> timeData: 700 emg: 328 eog: 326
14:48:01.491 -> timeData: 800 emg: 322 eog: 320
14:48:01.602 -> timeData: 900 emg: 318 eog: 316
14:48:01.674 -> timeData: 1000 emg: 312 eog: 311
14:48:01.778 -> timeData: 1100 emg: 308 eog: 307
14:48:01.878 -> timeData: 1200 emg: 305 eog: 303
14:48:01.991 -> timeData: 1300 emg: 301 eog: 299
14:48:02.093 -> timeData: 1400 emg: 298 eog: 296
14:48:02.199 -> timeData: 1500 emg: 296 eog: 294
Code
#include <SPI.h>
#include <SD.h>
File myFile;
  false;
//  true;
char inputChar;
unsigned long timeData;
int eog;
int emg;
  while (!Serial) {
  if (!SD.begin(5)) {
    while (1);
  if (recording) {
  if (!recording) {
  // -------------if PLAYING BACK, get next data point from SD card---------
      stringIndex++;
      readData = false;
    stringIndex = 0;
  bool timeToSample = actualTime - startTime >= samplingDelta;
  // -----------------------SAMPLE-----------------------
  if ( timeToSample) {
    // -----------------if RECORDING get biodata from sensors-----------------
    if (recording) {
      int sensorValue0 = analogRead(A0);
      int sensorValue1 = analogRead(A1);
      emg = sensorValue0;
      eog = sensorValue1;
      timeData = actualTime;
      writeToSD(  emg, eog, timeData,  myFile); //not working
      if (playData) {
          // updates values recordingTime, emg, eog
          parseData(inputString, timeData, emg, eog);
          readData = true;
          playData = false;
void parseData(String data, unsigned long& timeData, int& emgData,  int& eogData) {
  int ary[2];
  int aryI = 0;
  String singleData = "";
  //string data to array
  for (int i = 0; i < data.length(); i = i + 1)
    if ( data[i] == ',') {
      ary[aryI] = singleData.toInt();
      singleData = "";
      aryI++;
      i++;
    singleData = singleData + data[i];
    if ((i + 1) == data.length()) {
      timeData = ary[0];
      emgData = ary[1];
      eogData = ary[2];
void handleData( int timeData, int emgData, int eogData) {
  Serial.print("timeData: ");
  Serial.print(timeData);
  Serial.print(" emg: ");
  Serial.print(emgData);
  Serial.print(" eog: ");
  Serial.println(eogData);
void  writeToSD(int emg, int eog, unsigned long timeOfSample, File file) {
  if (file) {
//    Serial.print(F(" t: "));
//    Serial.print(timeOfSample);
//    Serial.print(F(" emg: "));
//    Serial.print(emg);
//    Serial.print(F(" eog: "));
//    Serial.println(eog);
    file.print(timeOfSample);
    file.print(",");
    file.print(emg);
    file.print(",");
    file.println(eog);
  else {
    myFile.close();
  myFile.close();
  Serial.println("Done recording.");
  delay(9000000000); //not a good real world solution for ending the code, this just pauses the script for sample purposes purposes
I also made a library version:
example.ino
#include <Sample.h>
#include <SPI.h>
#include <SD.h>
// Below are the 3 variables I hard coded into my library: time, eye electrode (eog), muscle electrode (emg).
// the program will record these 3 data points every 100ms in recording more,
// and play them back through the program in playback mode.
unsigned long timeD;
int eog;
int emg;
File dataFile;
Sample sample(false); // false for playback mode, true for recording mode
  while (!Serial) {
  if (!SD.begin(5)) {
    while (1);
  dataFile = sample.getDataFile("DATA.TXT"); // getDataFile("DATA.TXT") creates DATA.TXT in recording mode,
  // but gets the saved DATA.TXTX file in playback mode
  sample.monitorData(timeD, emg, eog, dataFile);  // montitorData() will record the data if in recording mode
  // and it will playback the SD card Data if in playback mode.
  // in both scenarios it will set these 3 referenced variables
  // to the correct value
  if (sample.handleData) { // handleData is set in the monitorData function
    // and is based on the sampling rate (100ms)
    // and whether there is still data in the file to play back if in playback mode
    displayData( timeD, emg, eog);
void displayData( int timeData, int emgData, int eogData) {
Sample.h
  Sample.h - keeps sample rate and handles recording and playing back data for the dream phone.
  Created by Dash Bark-Huss, Jan 28, 2022.
  Released into the public domain but you need to say a nice thing to stranger if you use it.*/
#ifndef Sample_h
#define Sample_h
#include <SD.h>
#include "Arduino.h"
class Sample
  public:
    Sample(bool recording);
     bool handleData;
    void monitorData(unsigned long& timeData, int& emgData, int& eogData , File& file);
    File getDataFile(String fileName);
  private:
    bool _recording;
    bool _playData;
    bool _readData;
    bool _paused;
    unsigned long _startTime;
    void deleteAndRecreateFile(String fileName);
    void parseData(String data, unsigned long & timeData, int& emgData,  int& eogData);
    void writeToSD(int emg, int eog, unsigned long timeOfSample, File file);
#endif
Sample.cpp
#ifndef Sample_h
#define Sample_h
#include <SD.h>
class Sample
  public:
     bool handleData;
  private:
    bool _recording;
    bool _playData;
    bool _readData;
    bool _paused;
#endif
