Hi guys,
So I am aiming to record, and loop a guitar signal using the Arduino software. I have setup the input signal on analogue pin 0 (A0) of the Arduino board and have tested to check there is a signal going into the Arduino. Now I want to view the level of the audio signal on the serial monitor or plotter (before thinking about how to record and loop it). Can anyone help me on this topic? Has anyone been able to record or loop an audio signal? Any help would be appreciated.
Here is the code I used taken from an Instructables tutorial “Arduino Audio Input”:
#include <Boards.h>
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License as published by
- the Free Software Foundation; either version 3 of the License, or
- (at your option) any later version.
//variable to store incoming audio sample
byte incomingAudio;
//clipping indicator variables
boolean clipping = 0;
void setup(){
Serial.begin(9600); // Start serial port
pinMode(13,OUTPUT);//led indicator pin
cli();//disable interrupts
//set up continuous sampling of analog pin 0
//clear ADCSRA and ADCSRB registers
ADCSRA = 0;
ADCSRB = 0;
ADMUX |= (1 << REFS0); //set reference voltage
ADMUX |= (1 << ADLAR); //left align the ADC value- so we can read highest 8 bits from ADCH register only
ADCSRA |= (1 << ADPS2) | (1 << ADPS0); //set ADC clock with 32 prescaler- 16mHz/32=500kHz
ADCSRA |= (1 << ADATE); //enable auto trigger
ADCSRA |= (1 << ADIE); //enable interrupts when measurement complete
ADCSRA |= (1 << ADEN); //enable ADC
ADCSRA |= (1 << ADSC); //start ADC measurements
sei();//enable interrupts
//if you want to add other things to setup(), do it here
ISR(ADC_vect) {//when new ADC value ready
incomingAudio = ADCH;//store 8 bit value from analog pin 0
if (incomingAudio == 0 || incomingAudio == 255){//if clipping
digitalWrite(13,HIGH);//set pin 13 high
clipping = 1;//currently clipping
void loop(){
if (clipping){//if currently clipping
clipping = 0;//
digitalWrite(13,LOW);//turn off clipping led indicator (pin 13)
delay(100);
