Recording OGG using a VS1053
I've got a geeetech VS1053 mp3 player/ogg recorder with micro SD card. I want to use it to record audio. The problem is that the SD functions don't seem to work in the recording sketch there's a repeating noise on the recording, a bit like a needle at the end of a record (sort of like kada-chhhhh).
This is the card: Link to geetech site
I've adapted adafruit's code, as found here: adafruit link.
i've trimmed the sketch down so that it's the bare minimum to record and nothing has changed.
Has anyone dealt with this before?
I’ve edited my top post.
Do you succeed recording with this module?
Has anyone has had any success recording with this module?
Hello, I made success recording. If you need help, get me a message.
kostos:
Hi. I used the library above (adafruit) and when I push the button the ogg file record correctly but when I do it for the second time or more it doesn't work. Other recorded files except the first one are ogg file with 1kB size.
I only can record one time.
If I reset the board I can record the voice once too.
