Recover the value of the first digit after the decimal point
Hi
I can get the value of units and decimals with this command :
unidadeTemp = temp % 10;
dezenaTemp = temp / 10;
but I would like to recover the value of the first digit after the decimal point
how to do ?
What temperature sensor are you using? Does it really give you temperatures that have more than one digit after the decimal point?
float temp = 23.4;
int tempAsInt = (temp + 0.05) * 10; // tempAsInt will be 234
int firstFractionDigit = tempAsInt % 10; // value will be 4
esloch:
Hi
how to do ?
float temp = 12.345;
int result = temp * 10; // 123.45 is truncated to int 123
result = result % 10; // 3
PaulS:
float temp = 23.4;
I use Si7021 sensor ... great ! ... but I don't know who many digit after decimal point I can get with this sensor :confused:
olf2012:
try this ... I think It will work fine
Thanks
Then why did you choose that sensor? If you can't read the datasheet, post a link to it, and one if us will read it for you.
PaulS:
I use at the start the DHT11 ... very bad ... I was advised to use Si7021 ... very professional ...
Thank you for your help, I try to read the datasheet myself, and I will ask your for help ... if needed
Thanks
OK
I try this code :
int temp;
int unidadeTemp, dezenaTemp, centmTemp;
centmTemp = (temp * 10) % 10;
he always return the value 0 in the centmTemp ...
if I change it like this :
float temp;
I have this error message : invalid operands of types 'float' and 'int' to binary 'operator%'
:confused: :confused: :confused:
I don't see much difference between the 2 blocks of code.
But, anyway, post all the code you have written. From the parts you have posted it is not clear how/into what you have read the temperature sensor.
Also say what degree of precision you would like see in the results.
6v6gt:
but the first code I no have error message ...
6v6gt:
OK
but my code is too long ... if you want I will post it
I add the read of the temperature
int temp;
temp = sensor.readTemperature();
I want a precision at the 1st digit after the point (23.4°)
with this code I can't read the 4 ... I always read it 0 !
:confused:
I'm moving slightly
I displayed on the monitor different values to understand the operation
with this command
If I display this command
Serial.println(sensor.readTemperature(), 2)
the result is (for exemple) : 22.45
int temp
Serial.println(temp, 2)
the result is (for exemple) : 10110
the prob (if I understand correctly)
this command no work with the first code
finaly work fine (but with very bad commands)
int temp, temp2, umid, unidadeTemp, dezenaTemp, centmTemp;
temp2 = 10 * (sensor.readTemperature());
centmTemp = temp2 % 10;
:confused:
OK. You could attach the whole code as a file.
You could also do your calculation something like this if you want to cover the full range of the sensor (up to 125 deg Centigrade) and retain a precision of one place of decimal
int temp2 = 10 * (sensor.readTemperature());
int decimalPart    = temp2 % 10 ;
int unitsPart       = (temp2/10) % 10 ;
int tensPart        = (temp2/100) % 10 ;
int hundredsPart  = (temp2/1000) % 10 ;
If you want to represent negative centigrage temperatures as well, however, you probably don't want each digit to be negative so you'd have to set a flag to indicate a negative temperature and force temp2 to always be positive.
work great with this code
  temp = 10*sensor.readTemperature();
  dezenaTemp = temp / 100;
  unidadeTemp = (temp/10) % 10;
  centmTemp = temp % 10;
