recreating the weather
hi i had an idea and i couldnt find anything on the forum the idea is to recreate in live the weather from a certain point on earth to a terrarium using wifi or cable to get the weather data.
i don't know wish arduino i am gonna use but i am wandering if this is possible? :o :o
Yes it is possible. I even like the idea.
Marx generator for the thunderstorms, yay!
yes? how? i found that you can have google weather arduino with an lcd screen how i can use the data so it can control my sensor
Sensor? What sensor?
well for exemple you programme an humidificator to turn on below 50% of humidity the sensor in the terrarium will tell the real humidity and if below 50% it is turnig on but i want that % to be as much accurate as possible to the real weather
That is possible. You will need to control a humidifier as well as read the humidity sensor. Or let it rain.
I imagine you will also want to control the temperature, which would require heating/cooling as well as a sensor.
The possibilities are endless!
The concept you're looking for is "negative feedback" Don't forget a vacuum pump to simulate varying air pressure.
melanocephalus: i had an idea and i couldnt find anything on the forum the idea is to recreate in live the weather from a certain point on earth to a terrarium using wifi or cable to get the weather data.
A lot of use would like to recreate the weather, for instance today was a little hot for me, I would like to recreate the weather today so that it was a little cooler.
There is a suspicion that all you may want to do is compare measured data, temperature, pressure etc with what has been reported (somewhere ?) that this data should be.
You could save a lot of us guessing by providing at least some minimal details of what it is you want to do.
