Recurring GET request
Ok…Warning…total Newbie here!
I am wanting to modify the example below to make a recurring GET request (every 60 seconds) instead of just once, but am having a hard time understanding which sections of code to include in a function that can be called within the loop function, and which need to stay in the setup function.
I have tried a number of arrangements, but with no success. This is obvioulsy due to my lack of understanding regarding the use of the ethernetShield.
Any guidance greatly appreciated.
Here is the unaltered (other than my domain and file request info) sketch, which works great for a single request:
DNS and DHCP-based Web client
based on the example sketch originally created 18 Dec 2009
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe, based on work by Adrian McEwen
modified Jan 1,2014 by me
#include <SPI.h>
#include <Ethernet.h>
byte mac = { mymacaddress };
char serverName = “www.mydomain.com”;
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// start the Ethernet connection:
if (Ethernet.begin(mac) == 0) {
Serial.println(“Failed to configure Ethernet using DHCP”);
// no point in carrying on, so do nothing forevermore:
while(true);
// give the Ethernet shield a second to initialize:
Serial.println(“connecting…”);
// if you get a connection, report back via serial:
if (client.connect(serverName, 80)) {
Serial.println(“connected”);
// Make a HTTP request:
client.println(“GET /arduino.mv?q=1231231 HTTP/1.1”);
client.println(“Host: www.mydomain.com”);
client.println(“User-Agent: arduino-ethernet”);
client.println(“Connection: close”);
client.println();
else {
// kf you didn’t get a connection to the server:
Serial.println(“connection failed”);
// if there are incoming bytes available
// from the server, read them and print them:
if (client.available()) {
char c = client.read();
Serial.print(c);
// if the server’s disconnected, stop the client:
if (!client.connected()) {
Serial.println(“disconnecting.”);
client.stop();
// do nothing forevermore:
while(true);
Event (receiving an e from the serial monitor) based client code. You could use a timing setup instead of receiving an e from the serial monitor.
//zoomkat 9-22-12
//simple client test
//for use with IDE 1.0.1
//with DNS, DHCP, and Host
//open serial monitor and send an e to test
//for use with W5100 based ethernet shields
//remove SD card if inserted
#include <SPI.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
char serverName[] = "www.mydomain.com"; // zoomkat's test web page server
void setup(){
    Serial.println("Failed to configure Ethernet using DHCP");
    while(true);
  Serial.println("Better client test 9/22/12"); // so I can keep track of what is loaded
  Serial.println("Send an e in serial monitor to test"); // what to do to test
void loop(){
  // check for serial input
  if (Serial.available() > 0) //if something in serial buffer
    byte inChar; // sets inChar as a byte
    inChar = Serial.read(); //gets byte from buffer
    if(inChar == 'e') // checks to see byte is an e
      sendGET(); // call sendGET function below when byte is an e
void sendGET() //client function to send/receive GET request data.
  if (client.connect(serverName, 80)) {  //starts client connection, checks for connection
    Serial.println("connected");
    client.println("GET /arduino.mv?q=1231231 HTTP/1.1"); //download text
    client.println("Host: www.mydomain.com");
    client.println("Connection: close");  //close 1.1 persistent connection
    client.println(); //end of get request
  else {
    Serial.println("connection failed"); //error message if no client connect
  while(client.connected() && !client.available()) delay(1); //waits for data
  while (client.connected() || client.available()) { //connected or data available
    char c = client.read(); //gets byte from ethernet buffer
    Serial.print(c); //prints byte to serial monitor
  Serial.println("disconnecting.");
  Serial.println("==================");
  client.stop(); //stop client
Perfect. This is great. Thanks.
