Are they allowed?
if(debugmode)
Serial.begin(9600); // report to PC in Debug Mode
Serial1.begin(57600); // To send updates to Topbox Unit
void updateScore(int p) // 0-3 -> Player 1-4, 4 -> All Players
if(p>3)
for(int i=0; i<4; i++)
updateScore(i);
sprintf(s, "@%d%06d", p, Score[p]);
if(debugmode) Serial.print(s);
Serial1.print(s);
Yes, I will. Oops, already discovered a mistake.
if(p>3)
updateScore(i);
Serial1.print(s);
That's better, I hope.
system
April 12, 2013, 11:24pm
4
Why do you want recursion here?
Just to save a few LOC's.
Stack space is much more valuable than a few lines of code!
system
April 13, 2013, 12:00am
7
Recursion is not the same as looping. You want to save code by looping, not be calling the function from itself.
So, would you rather recommend I add another function?
void updateAllScores(void)
updateScore(i);
system
April 13, 2013, 12:38am
9
In my experience, problems that are best solved by recursion are extremely rare. If you think you may need to use recursion, my advice is not to unless you really have to, and even then don't.
Recursive algorithms might occur more often than expected (not in embedded due to stack/mem constraints).
Best known recursive algorithm is quick sort, but they are also used in parsers etc.
That said all recursive algorithms can be transformed to a (often faster) loop, although complexity might grow.
Still, recursive algorithms have a natural elegance which reflects the recurrent nature of a problem(description).
SimLego:
if(p>3)
updateScore(i);
Serial1.print(s);
Since "s" isn't local, I would be wary of using recursion here. Plus in this particular instance it doesn't seem warranted.
this is your requirement: // 0-3 -> Player 1-4, 4 -> All Players
The following code can be verified with above requirements easily
if (p >= 4) updateAllPlayers();
else if (p >= 0) updatePlayer(p);
// else ; // ignore negative values.
void updateAllPlayers()
for (int p=0; p<4; p++)
updatePlayer(p);
void updatePlayer(int p)
if (debugmode) Serial.print(s);
Serial1.print(s);
If you want to do it recursively (for academic reasons) think this way,
note that there is no loop...;
note two variations
void updateAllPlayers(int p)
p = max(p, 3);
if (p >= 0)
updatePlayer(p);
updateAllPlayer(p-1);
or
p = max(p, 3);
if (p >= 0)
updatePlayer(p);
