Red and blue inverted BMP - TFT
Hello,
I'm using a 3.5" TFT touchscreen. I'm on Arduino Uno but could also use a Mega.
I am trying to display images in bitmap format. The images are stored in a micro sd card.
The image appears on the screen.
Unfortunately the colors are not good.
I notice that it is the blue and red colors that are reversed (green is correct).
For example on this image: link
On the screen, there is blue instead of red, cyan instead of yellow...
How to get normal colors?
I already tried tft.invertDisplay(true); but the colors are even more false.
When I color the screen with fillScreen, the blue is indeed blue and the red is indeed red.
Here is some code I modified:
#include <Adafruit_TFTLCD.h>
#include <MCUFRIEND_kbv.h>
#include <Adafruit_GFX.h>    // Core graphics library
#include <TouchScreen.h>
#include <Fonts/FreeMonoBoldOblique12pt7b.h>
#include <Fonts/FreeSansBold12pt7b.h>
#include <SPI.h>
#include <avr/pgmspace.h>
#include <SD.h>
#define SD_CS  10
const int XP=6,XM=A2,YP=A1,YM=7; //ID=0x9341
const int TS_LEFT=907,TS_RT=136,TS_TOP=942,TS_BOT=139;
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
TSPoint tp;
uint16_t ID, oldcolor, currentcolor;
#define BLACK    0x0000
#define BLUE     0x001F
#define RED      0xF800
#define GREEN    0x07E0
#define CYAN     0x07FF
#define MAGENTA  0xF81F
#define YELLOW   0xFFE0
#define WHITE    0xFFFF
#define ORANGE   0xFBE0
MCUFRIEND_kbv tft;
int x, y;
char currentPage;
  uint16_t tmp;
    tft.reset();
    ID = tft.readID();
    tft.begin(ID);
    tft.setRotation(1);
  Serial.print("Initializing SD card...");
  if (!SD.begin(SD_CS)) {
    Serial.println("failed!");
    return;
  Serial.println("OK!");
  tft.fillScreen(ORANGE);
Homescreen();
while(1);
void Homescreen(){
  bmpDraw("image.bmp",0,0);
  delay(5000); }
#define BUFFPIXEL 20
void bmpDraw(char *filename, int x, int y) {
  File     bmpFile;
  int      bmpWidth, bmpHeight;   // W+H in pixels
  uint8_t  bmpDepth;              // Bit depth (currently must be 24)
  uint32_t bmpImageoffset;        // Start of image data in file
  uint32_t rowSize;               // Not always = bmpWidth; may have padding
  uint8_t  sdbuffer[3*BUFFPIXEL]; // pixel in buffer (R+G+B per pixel)
  uint16_t lcdbuffer[BUFFPIXEL];  // pixel out buffer (16-bit per pixel)
  uint8_t  buffidx = sizeof(sdbuffer); // Current position in sdbuffer
  boolean  goodBmp = false;       // Set to true on valid header parse
  boolean  flip    = true;        // BMP is stored bottom-to-top
  int      w, h, row, col;
  uint8_t  r, g, b;
  uint32_t pos = 0, startTime = millis();
  uint8_t  lcdidx = 0;
  boolean  first = true;
  if((x >= tft.width()) || (y >= tft.height())) return;
  Serial.print(F("Loading image '"));
  Serial.print(filename);
  Serial.println('\'');
  // Open requested file on SD card
  if ((bmpFile = SD.open(filename)) == NULL) {
    Serial.println(F("File not found"));
    return;
  // Parse BMP header
  if(read16(bmpFile) == 0x4D42) { // BMP signature
    Serial.println(F("File size: ")); Serial.println(read32(bmpFile));
    (void)read32(bmpFile); // Read & ignore creator bytes
    bmpImageoffset = read32(bmpFile); // Start of image data
    Serial.print(F("Image Offset: ")); Serial.println(bmpImageoffset, DEC);
    // Read DIB header
    Serial.print(F("Header size: ")); Serial.println(read32(bmpFile));
    bmpWidth  = read32(bmpFile);
    bmpHeight = read32(bmpFile);
    if(read16(bmpFile) == 1) { // # planes -- must be '1'
      bmpDepth = read16(bmpFile); // bits per pixel
      Serial.print(F("Bit Depth: ")); Serial.println(bmpDepth);
      if((bmpDepth == 24) && (read32(bmpFile) == 0)) { // 0 = uncompressed
        goodBmp = true; // Supported BMP format -- proceed!
        Serial.print(F("Image size: "));
        Serial.print(bmpWidth);
        Serial.print('x');
        Serial.println(bmpHeight);
        // BMP rows are padded (if needed) to 4-byte boundary
        rowSize = (bmpWidth * 3 + 3) & ~3;
        // If bmpHeight is negative, image is in top-down order.
        // This is not canon but has been observed in the wild.
        if(bmpHeight < 0) {
          bmpHeight = -bmpHeight;
          flip      = false;
        // Crop area to be loaded
        w = bmpWidth;
        h = bmpHeight;
        if((x+w-1) >= tft.width())  w = tft.width()  - x;
        if((y+h-1) >= tft.height()) h = tft.height() - y;
        // Set TFT address window to clipped image bounds
        tft.setAddrWindow(x, y, x+w-1, y+h-1);
        for (row=0; row<h; row++) { // For each scanline...
          // Seek to start of scan line.  It might seem labor-
          // intensive to be doing this on every line, but this
          // method covers a lot of gritty details like cropping
          // and scanline padding.  Also, the seek only takes
          // place if the file position actually needs to change
          // (avoids a lot of cluster math in SD library).
          if(flip) // Bitmap is stored bottom-to-top order (normal BMP)
            pos = bmpImageoffset + (bmpHeight - 1 - row) * rowSize;
          else     // Bitmap is stored top-to-bottom
            pos = bmpImageoffset + row * rowSize;
          if(bmpFile.position() != pos) { // Need seek?
            bmpFile.seek(pos);
            buffidx = sizeof(sdbuffer); // Force buffer reload
          for (col=0; col<w; col++) { // For each column...
            // Time to read more pixel data?
            if (buffidx >= sizeof(sdbuffer)) { // Indeed
              // Push LCD buffer to the display first
              if(lcdidx > 0) {
                tft.pushColors(lcdbuffer, lcdidx, first);
                lcdidx = 0;
                first  = false;
              bmpFile.read(sdbuffer, sizeof(sdbuffer));
              buffidx = 0; // Set index to beginning
            // Convert pixel from BMP to TFT format
            r = sdbuffer[buffidx++];
            g = sdbuffer[buffidx++];
            b = sdbuffer[buffidx++];
            lcdbuffer[lcdidx++] = tft.color565(r,g,b);
          } // end pixel
        } // end scanline
        // Write any remaining data to LCD
        if(lcdidx > 0) {
        Serial.print(F("Loaded in "));
        Serial.print(millis() - startTime);
        Serial.println(" ms");
      } // end goodBmp
  bmpFile.close();
  if(!goodBmp) Serial.println(F("BMP format not recognized."));
// These read 16- and 32-bit types from the SD card file.
// BMP data is stored little-endian, Arduino is little-endian too.
// May need to reverse subscript order if porting elsewhere.
uint16_t read16(File f) {
  uint16_t result;
  ((uint8_t *)&result)[0] = f.read(); // LSB
  ((uint8_t *)&result)[1] = f.read(); // MSB
  return result;
uint32_t read32(File f) {
  uint32_t result;
  ((uint8_t *)&result)[2] = f.read();
  ((uint8_t *)&result)[3] = f.read(); // MSB
  return result;
Hi @leg2027
Maybe try this function? :
uint16_t color565(uint8_t r, uint8_t g, uint8_t b) { return ((r & 0xF8) << 8) | ((g & 0xFC) << 3) | ((b & 0xF8) >> 3); }
I found it in the library.
Where do I place it in the code?
In the serial monitor:
Loading image 'image.bmp'
File size:
151686
Image Offset: 138
Header size: 124
Bit Depth: 24
Image size: 291x173
Loaded in 1766 ms
Never mind, that won't do anything. I'm not sure why that would be happening.
Looking at my example code
                        case 24:
                            if (bmpDepth == 32) buffidx++; //ignore ALPHA
                            color = tft.color565(r, g, b);
you can see that the BMP colours are stored in B, G, R order
For some reason you have chosen to read them in R, G, B order.
You also have included header files that are never used e.g. Adafruit_TFTLCD.h and TouchScreen.h and some Fonts.
Thanks for your help.
The colors display perfectly now!
I found the code on the internet: [Résolu] Arduino mega, ecran tactile et fichier bmp - Problème de carte sd par PCov3r - page 1 - OpenClassrooms
I modified it to fit my screen and for Uno. I left the errors.
Is the code better like this?
#include <SPI.h>
#include <SD.h>
#define SD_CS  10
#define BLUE     0x001F
#define RED      0xF800
#define CYAN     0x07FF
MCUFRIEND_kbv tft;
int x, y;
char currentPage;
  uint16_t tmp;
    tft.reset();
    ID = tft.readID();
    tft.begin(ID);
    tft.setRotation(1);
    return;
Homescreen();
while(1);
void Homescreen(){
  delay(5000); }
  File     bmpFile;
  int      w, h, row, col;
  uint8_t  r, g, b;
  uint8_t  lcdidx = 0;
    return;
  // Parse BMP header
    // Read DIB header
        Serial.print('x');
        if(bmpHeight < 0) {
          flip      = false;
        w = bmpWidth;
        h = bmpHeight;
            bmpFile.seek(pos);
              if(lcdidx > 0) {
                lcdidx = 0;
                first  = false;
          } // end pixel
        } // end scanline
        if(lcdidx > 0) {
      } // end goodBmp
  bmpFile.close();
  uint16_t result;
  return result;
  uint32_t result;
  return result;
Note: in the future I will also use the touch function of my screen to change the images.
I always recommend starting with the library examples.
Save with a custom name in your sketch folder.
Then you can experiment safely. e.g. strip out stuff that you don't need.
You can always compare your code with the library example.
Random code that is "found" on the Internet might be good or it might be bad !!
David.
Sometimes I do. But certainly not often enough. I should try to do better.
But I believe that to make a code like that, it would have been probably impossible for me in my opinion.
