From the last topic Red board UNO wifi cannot be sketched - Installation & Troubleshooting - Arduino Forum I can use my what's next red board to run the codes in that topic. Very thanks for Juraj's solution for me to follow this https://whatsnext.shop/make/be-ready-to-start-red to setup my red board.
Now, i encounter new problem about my new project. I have to use my red board's WIFI to send my data into firebase. It is not working on this red board. The error is about ESP8266 Library which i dont understand how to solve this problem. I have already installed ESP8266wifi library. The error message and my codes are below.
Can someone help me out please? Thank you
Note: Before i use this red board, i use this codes for my Wemos D1 mini and there is no error about my ESP8266 library like this. Everything is fine. The data can send into my database.
IDE imagehttps://www.img.in.th/image/VAHwbk
Arduino: 1.8.5 (Windows 10), Board: "red, AVR 328p"
C:\Users\User\Desktop\Project\for_box\for_box.ino:1:25: fatal error: ESP8266WiFi.h: No such file or directory
#include <ESP8266WiFi.h>
compilation terminated.
exit status 1
Error compiling for board red.
option enabled in File -> Preferences.
My codes for this project
#include <FirebaseArduino.h>
#include <SoftwareSerial.h> //delete
#include <PZEM004T.h>
#include <time.h>
// Config WiFi
#define WIFI_SSID "Pengg'"
#define WIFI_PASSWORD "pongpeng"
// Config Firebase
#define FIREBASE_HOST "electricity-consumption-da63c.firebaseio.com"
#define FIREBASE_AUTH "Ejp8h9kVUWIsc37hIMZqRVXN1A4Tj9FGMl9WIq5CH"
#ifndef min
#define min(a,b) ((a)<(b)?(a):(b))
#endif
float calBill(float Unit, float ft, bool over_150_Unit_per_month = false) ;
// Config time
int timezone = 7;
// Config bill
#define FIX_FT 0
char ntp_server1[20] = "ntp.ku.ac.th";
char ntp_server2[20] = "fw.eng.ku.ac.th";
char ntp_server3[20] = "time.uni.net.th";
int dst = 0;
unsigned long lastUpdateEnergy = 0, lastUpdateFirebase = 0;
float Volt, Amp, Power;
//unsigned long Energy = 0;
float Energy = 0;
PZEM004T pzem(10, 11); // (RX,TX) connect to TX,RX of PZEM
IPAddress ip(192, 168, 1, 1);
while (!pzem.setAddress(ip)) {
Serial.println("Connecting to PZEM...");
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
Serial.print("connecting");
Serial.print(".");
Serial.print("connected: ");
configTime(timezone * 3600, dst, ntp_server1, ntp_server2, ntp_server3);
Serial.println("Waiting for time");
while (!time(nullptr)) {
Serial.print(".");
Serial.println("Now: " + getTime());
Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH);
if ((millis() - lastUpdateEnergy) >= 1000) {
lastUpdateEnergy = millis();
unsigned long startTime = millis();
Volt = pzem.voltage(ip);
Volt = Volt > 0 ? Volt : 0;
Amp = pzem.current(ip);
Amp = Amp > 0 ? Amp : 0;
Power = Volt * Amp;
Energy += Power/3600;
Serial.print("Load time: ");
Serial.print(millis() - startTime);
Serial.println("ms");
Serial.println("Voltage: " + String(Volt, 2));
Serial.println("Current: " + String(Amp, 2));
Serial.println("Power: " + String(Power, 2));
Serial.println("Energy: " + String(Energy));
Serial.println("--------------------");
time_t now = time(nullptr);
struct tm* nowTime = localtime(&now);
if ((nowTime->tm_sec % 30) == 0) {
lastUpdateFirebase = millis();
StaticJsonBuffer<200> jsonBuffer;
JsonObject& root = jsonBuffer.createObject();
root["volt"] = Volt;
root["amp"] = Amp;
root["time"] = getTime();
String name = Firebase.push("/logPower", root);
// handle error
if (Firebase.failed()) {
Serial.print("pushing failed:");
Serial.println(Firebase.error());
return;
Serial.print("pushed: /logPower/");
Serial.println(name);
Firebase.setInt("/energy", Energy);
return;
Firebase.setFloat("/amount", calBill(Energy / 1000, FIX_FT, false));
return;
delay(0); // Disable WDT
String getTime() {
struct tm* newtime = localtime(&now);
String tmpNow = "";
tmpNow += String(newtime->tm_year + 1900);
tmpNow += "-";
tmpNow += String(newtime->tm_mon + 1);
tmpNow += "-";
tmpNow += String(newtime->tm_mday);
tmpNow += " ";
tmpNow += String(newtime->tm_hour);
tmpNow += ":";
tmpNow += String(newtime->tm_min);
tmpNow += ":";
tmpNow += String(newtime->tm_sec);
return tmpNow;
float calBill(float Unit, float ft, bool over_150_Unit_per_month) {
float Service = over_150_Unit_per_month ? 38.22 : 8.19;
float total = 0;
if (!over_150_Unit_per_month) {
float Rate15 = 2.3488;
float Rate25 = 2.9882;
float Rate35 = 3.2405;
float Rate100 = 3.6237;
float Rate150 = 3.7171;
float Rate400 = 4.2218;
float RateMore400 = 4.4217;
if (Unit >= 0) total += min(Unit, 15) * Rate15;
if (Unit >= 16) total += min(Unit - 15, 10) * Rate25;
if (Unit >= 26) total += min(Unit - 25, 10) * Rate35;
if (Unit >= 36) total += min(Unit - 35, 65) * Rate100;
if (Unit >= 101) total += min(Unit - 100, 50) * Rate150;
if (Unit >= 151) total += min(Unit - 150, 250) * Rate400;
if (Unit >= 401) total += (Unit - 400) * RateMore400;
float Rate150 = 3.2484;
total += min(Unit, 150) * Rate150;
if (Unit >= 151) total += min(Unit - 150, 150) * Rate400;
total += Service;
total += Unit * (ft / 100);
total += total * 7 / 100;
return total;
