Can anybody tell me if these generic TFT displays are unreliable or flakey when used with an Uno? I have a project that works perfectly fine with a parallel display shield, but need to switch to an SPI type because I need to use pin 8 and timer1 as a frequency counter.
I'm using the following to initialize it, borrowed from one of the Adafruit examples.
#include "SPI.h"
#include "Adafruit_GFX.h"
#include "Adafruit_ILI9341.h"
#define TFT_RST 7
#define TFT_DC 9
#define TFT_CS 10
#define TFT_MOSI 11
#define TFT_MISO 12
#define TFT_CLK 13
#define TFT_LED A0
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS,TFT_DC,TFT_MOSI,TFT_CLK,TFT_RST,TFT_MISO);
In the setup I'm turning on the backlight with this, no need for brightness control at this time.
pinMode(TFT_LED,OUTPUT);
digitalWrite(TFT_LED,HIGH);
tft.begin();
tft.setRotation(1);
tft.fillScreen(ILI9341_BLACK);
All I get is a backlit white screen, the screen doesn't fill black and nothing else will write to the display either. I've checked the wiring over and over, even completely disconnected it and replaced the wires.
Is there some obvious trick that I'm missing?
