Hello
I am discovering the arduino. I have a problem, when I plug my arduino uno a red light to the L is constantly on. When I launch my first program that aims to turn on an LED, here is the message that it appears after uploading: "The sketch uses 726 bytes (2%) of the program storage space. The maximum is 32256 bytes. The variables globally use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. The maximum is 2048 bytes." Do you know where the problem is please?
Bonjour
Je suis en train de découvrir l'arduino. J'ai un soucis, lorsque je branche mon arduino uno une lumière rouge au L est constamment allumé. Quand je lance mon premier programme qui a pour but d'allumer un LED voici le message qu'il apparait après le téléversement: " Le croquis utilisent 726 octets (2%) de l'espace de stockage de programme. Le maximum est de 32256 octets. Les variables globalement utilisent 9 octets (0%) de mémoire dynamique, ce qui laisse 2039 octets pour les variables locales. Le maximum est de 2048 octets." Savez vous où est le problème svp ?
The "power" LED is always on. You can remove it with a solder pencil.
The message is informational, and perfectly normal. There is no problem with program upload.
What is a solder pencil ?
The fact that I have a red light L constantly on my arduino is not a problem?
An orange light appears in L
A solder pencil heats up and melts the solder holding parts on, so they can be removed.
In your case, the Power LED, labeled "ON" is green. If it goes off, the Uno is not powered and will not function.
There are two yellow LEDs connected to the serial port (TX and RX).
The LED labeled "L" is the built in LED and is under program control (pin 13).
Then I don’t understand why I have an orange light on?
Sorry I’m just discovering this area...
Please post the program you uploaded, using code tags ("</>" button on post editor).
const int led_rouge = 4; //définition de la broche
// fonction d'initialisation de la carte
// initialiation de la broche 4 comme étant la sortie
pinMode(led_rouge, OUTPUT);
//fonction principale, elle se prépète (s'exécute) à l'infini
// é riture en sortie (broche 4) d'un état bas
digitalWrite(led_rouge,LOW);
The LED labeled "L" is controlled by pin 13, not by pin 4.
Try this to turn OFF the LED labeled L.
const int led_rouge = 13; //PIN 13 controls LED
digitalWrite(led_rouge,LOW); // HIGH to turn on
Or this, to make it blink:
const int led_rouge = 13; //définition de la broche
digitalWrite(led_rouge,HIGH);
Thank you so much for your help!! I did my editing!
On a number of Arduino (compatible) boards, you will have to actively control the led on pin 13 to switch it off. You can check the circuit diagram. If the LED is controlled by an opamp that will be the case.
Arduino Uno (with opamp)
SparkFun RedBoard (without opamp)
