Red Text in library name
I had to reinstall the Arduino software after a new PC build and two of the libraries I am using for one of my projects reference with red text. I do not remember them showing up with a red text color the last time I was using them. Also the code that used to work is no longer working. Did I install the libraries wrong?
#include <OneWire.h>
#include <LCDI2C.h>
#include <WProgram.h>
#include <Wire.h>
#include <DS1307.h>
To do:
  • integrate keypad
    A-normal mode ----Done
    B-set time ----Done
    *Set hours and minutes ---Done
    C-feed mode ----Done
    *turn off pumps/skimmer for 5 min ----Done
    D-water change mode
    *turn off pumps/skimmer/heater/ato/fan
Arduino Reef Controller
Analog Pin 0 =
Analog Pin 1 = PH Probe
Analog Pin 2 = **ORP Probe?
Analog Pin 3 =
Analog Pin 4 = SDA for I2C
Analog Pin 5 = SCL for I2C
Digital Pin 0 = RX
Digital Pin 1 = TX
Digital Pin 2 = Temp Sensor
Digital Pin 3 = Alarm
Digital Pin 4 =
Digital Pin 5 =
Digital Pin 6 = Relay 1 Right MH
Digital Pin 7 = Relay 2 Left MH
Digital Pin 8 = Relay 3 Actinic
Digital Pin 9 = Relay 4 Fan
Digital Pin 10 = Relay 5 Refugium Light
Digital Pin 11 = Relay 6 Power Head #1
Digital Pin 12 = Relay 7 Return Pump
Digital Pin 13 = Relay 8 Skimmer/air pump
LCDI2C lcd = LCDI2C(4,20,0x4C,1); //[# of lines on LCD],[address of serial LCD controller on I2C]
OneWire ds(2); // Temp Sensor on pin 2
int left_mh = 6;
int right_mh = 7;
int actinic = 8;
int fan = 9;
//int ato = 10;
int ph_1 = 11;
int ph_2 = 12;
int skimmer = 13;
int alarm = 3;
int fuge_light = 5;
Each library comes with a ketwords.txt file that the IDE reads to determine what color to apply to what words. It appears that you did not have the keywords.txt files before (they are not used by the compiler, so being missing is not a problem) but do now, or that they were in the wrong place (same effect as not being there).
Does not compile? Or does not run the same? What does not work the same?
Did you re-install the same version of the IDE?
The code compiles fine, however it does not display any output to the display. In the past this had been caused by not having the temp probe hooked up, and could be corrected by either attaching the DS18B20 temp probe or commenting out the associated lines. Neither fix is working now.
BUMP
You missed one of the questions.
Also, the code you posted is nowhere near complete. We can't tell what is wrong with so little info.
Yes I did install the same version.
I unfortunately am not able to post the entire code since the forum only allows 9500 characters, do you know a way around this?
Post it in chunks.
here is the first section of code
#include <LCDI2C.h>
#include <Wire.h>
#include <DS1307.h>
To do:
*  integrate keypad
    B-set time    ----Done
    D-water change mode
Analog Pin 0 =
Analog Pin 3 =
Digital Pin 0 = RX
Digital Pin 1 = TX
Digital Pin 4 =
Digital Pin 5 =
int left_mh = 6;
int right_mh = 7;
int actinic = 8;
int fan = 9;
//int ato = 10;
int ph_1 = 11;
int ph_2 = 12;
int skimmer = 13;
int alarm = 3;
int fuge_light = 5;
//int heater_on_temp = 7850;  //Turn on the heater at this temp         ex 78 degrees = 7800, 78.5 degrees = 7850
//int heater_off_temp = 8000; //Turn off heater at this temp
int fan_on_temp = 8150;  //Turn on fan at this temp
int fan_off_temp = 8050; //turn fan off once below this temp
int lights_off_temp = 8100;  //Turn off the lights if the temp rises above this temp
int left_mh_on_time = 1900;  //Turn day lights on at this time (military time)
int left_mh_off_time = 0100; //Turn day lights off at this time
int wait_time_left_mh = 0; //how long to wait before turning on lights if they are turned off due to power loss or overheating
int lights_out_left_mh = -100;  //placeholder  --don't change
int right_mh_on_time = 1930;  //Turn day lights on at this time (military time)
int right_mh_off_time = 0130; //Turn day lights off at this time
int wait_time_right_mh = 0; //how long to wait before turning on lights if they are turned off due to power loss or overheating
int lights_out_right_mh = -100;  //placeholder  --don't change
int actinic_on_time = 2100;  //Turn on Actinic lights at this time
int actinic_off_time = 700;  //Turn off Actinic lights at this time
int fuge_on_time = 2000;  //Turn on refugium lights at this time
int fuge_off_time = 1000;  //Turn off refugium lights at this time
int feed_time = 5;  //Turn off power heads for this amount of time when feed mode button is pressed.
int pumps_off = -10; //placeholder  --don't change
int pumps_off_second, pumps_off_minute, pumps_on_minute, pumps_off_hour, pumps_on_second, pumps_on_hour, pumps_on;
//int ato_time = 3; //Number of seconds for teh ATO to run each time the switch is on.
#define NUMREADINGS 10
int readings[NUMREADINGS];                // the readings from the analog input
int index = 0;                            // the index of the current reading
int total = 0;                            // the running total
int average = 0;                          // the average
int keypad_delay = 15;  //necessary delay to keep from having scrambled characters on the display
void setup(void) {
  Wire.begin(); //initialize the I2C bus
  lcd.init(); //initialize LCD
  /*Un-comment to set the time
    RTC.stop();
  RTC.set(DS1307_SEC,01);        //set the seconds
  RTC.set(DS1307_MIN,51);     //set the minutes
  RTC.set(DS1307_HR,20);       //set the hours (military)
  RTC.set(DS1307_DOW,7);       //set the day of the week
  RTC.set(DS1307_DATE,29);       //set the date
  RTC.set(DS1307_MTH,3);        //set the month
  RTC.set(DS1307_YR,9);         //set the year
  RTC.start();
  //****** initialize inputs/outputs ************************************/
  pinMode(left_mh, OUTPUT);  // digital pin for left MH as output
  pinMode(right_mh, OUTPUT);  // digital pin for Right MH as output
  pinMode(actinic, OUTPUT);  // digital pin for Actinics as output
  pinMode(fan, OUTPUT);  // digital pin for fan as output
  //pinMode(ato, OUTPUT);  // digital pin for auto top off as output
  pinMode(ph_1, OUTPUT);  // digital pin for power head 1 as output
  pinMode(ph_2, OUTPUT);  // digital pin for power head 2 as output
  pinMode(skimmer, OUTPUT);  // digital pin for skimmer as output
  pinMode(alarm, OUTPUT);  // digital pin for alarm as output
  digitalWrite(left_mh, LOW);
  for (int i = 0; i < NUMREADINGS; i++)
    readings[i] = 0;
int High = 0;
int Low = 10000;
int on_minute = 1;  //indicates that this is the first time through the program.
void loop(void){
  int mode = 100;  //Check for keypad input
  if(lcd.keypad() != -1){
  mode = lcd.keypad();
    //***********Mode B Set Time*************************************************************************************************
  if(mode == 101){
  int minute, hour, second, date, month, year, tens, ones, key;
  int set_time = 0;
  while(set_time == 0){
  lcd.clear();
  hour = RTC.get(DS1307_HR,true);  //This is in military time  [0,23]
  minute = RTC.get(DS1307_MIN,false);
  second = RTC.get(DS1307_SEC,false);
  date = RTC.get(DS1307_DATE,false);
  month = RTC.get(DS1307_MTH,false);
  year = RTC.get(DS1307_YR,false);
  lcd.setCursor(0,0);
  if(hour < 10){
    lcd.print(" ");
    delay(keypad_delay);
  lcd.print(hour);
  lcd.print(":");
  if(minute < 10){
    lcd.print("0");
  lcd.print(minute);
  /*  Don't print seconds
  lcd.print(":");
  if(second < 10){
    lcd.print("0");
  lcd.print(second);
  lcd.setCursor(1,0);
   if(month < 10){
     lcd.print(" ");
  lcd.print(month);
  lcd.print("/");
   if(date < 10){
     lcd.print(" ");
  lcd.print(date);
  lcd.print("/");
     if(year < 10){
     lcd.print("0");
  lcd.print(year);
  lcd.setCursor(0,0);
  lcd.cursor_on();
second section of code
  //**************Set Hour*********************************************************************************************
  for (;;){
    key = lcd.keypad();
    if(key >= 0 && key <= 2){tens = key; break;}
  for (;;){
    key = lcd.keypad();
    if(key == -1){break;}
    lcd.print(tens);
  for (;;){
    key = lcd.keypad();
    if(key >= 0 && key <= 9){ones = key; break;}
  for (;;){
    key = lcd.keypad();
    lcd.right();
    RTC.stop();
    RTC.set(DS1307_HR,tens * 10 + ones);
    RTC.start();
    lcd.setCursor(0,0);
     if(hour < 10){
      lcd.print(" ");
    lcd.print(hour);
    lcd.right();
    //**************Set Minute*********************************************************************************************
  for (;;){
    key = lcd.keypad();
    if(key >= 0 && key <= 6){tens = key; break;}
  for (;;){
    key = lcd.keypad();
    lcd.print(tens);
  for (;;){
    key = lcd.keypad();
  for (;;){
    key = lcd.keypad();
    lcd.right();
    RTC.stop();
    RTC.set(DS1307_MIN,tens * 10 + ones);
    RTC.start();
    lcd.setCursor(0,3);
    minute = RTC.get(DS1307_MIN,true);
      if(minute < 10){
       lcd.print("0");
    lcd.print(minute);
    //**************Set Month*********************************************************************************************
    lcd.setCursor(1,0);
  for (;;){
    key = lcd.keypad();
    if(key == 0 || key == 1){tens = key; break;}
  for (;;){
    key = lcd.keypad();
    lcd.print(tens);
  for (;;){
    key = lcd.keypad();
  for (;;){
    key = lcd.keypad();
    lcd.right();
    RTC.stop();
    RTC.set(DS1307_MTH,tens * 10 + ones);
    RTC.start();
    lcd.setCursor(1,0);
    month = RTC.get(DS1307_MTH,true);
      if(month < 10){
       lcd.print(" ");
    lcd.print(month);
   //**************Set Date*********************************************************************************************
    lcd.setCursor(1,3);
  for (;;){
    key = lcd.keypad();
    if(key >= 0 && key <= 3){tens = key; break;}
  for (;;){
    key = lcd.keypad();
    lcd.print(tens);
  for (;;){
    key = lcd.keypad();
  for (;;){
    key = lcd.keypad();
    lcd.right();
    RTC.stop();
    RTC.set(DS1307_DATE,tens * 10 + ones);
    RTC.start();
    lcd.setCursor(1,3);
    date = RTC.get(DS1307_DATE,true);
      if(date < 10){
       lcd.print(" ");
    lcd.print(date);
        //**************Set Year*********************************************************************************************
    lcd.setCursor(1,8);
  for (;;){
    key = lcd.keypad();
    if(key >= 0 && key <= 9){tens = key; break;}
  for (;;){
    key = lcd.keypad();
    lcd.print(tens);
  for (;;){
    key = lcd.keypad();
  for (;;){
    key = lcd.keypad();
    lcd.right();
    RTC.stop();
    RTC.set(DS1307_YR,tens * 10 + ones);
    RTC.start();
    lcd.setCursor(1,6);
    year = RTC.get(DS1307_YR,true);
      if(year < 10){
       lcd.print(" ");
    lcd.print(year);
    //**************Finish Up*********************************************************************************************
  for (;;){
    lcd.cursor_off();
    lcd.setCursor(2,0);
    lcd.print("Time & Date Set");
    lcd.setCursor(3,0);
    lcd.print("Choose Mode A or B");
    if(lcd.keypad() == 100){set_time = 1; break;}
    if(lcd.keypad() == 101){break;}
    lcd.clear();
  } //end while
  } //end mode 101
  //*************Normal Mode 100 and Feed Mode 102*************************************************************************************************
  if(mode == 100 || mode == 102){
  byte i;
  byte present = 0;
  byte data[12];
  byte addr[8];
  long ph_val;
  int HighByte, LowByte, TReading, SignBit, Tc_100, Whole, Fract, minute, hour, second, date, month, year, mil_time;
  //int ph_read;
  //Get time from DS1307**********************************************************************************************
 // date = RTC.get(DS1307_DATE,false);
 // month = RTC.get(DS1307_MTH,false);
 // year = RTC.get(DS1307_YR,false);
  mil_time = (hour * 100) + minute;  //create military time output [0000,2400)
  //Get temp data from DS18B20 ***************************************************************************************
    if ( !ds.search(addr)) {
      ds.reset_search();
      return;
  ds.reset();
  ds.select(addr);
  ds.write(0x44,1);         // start conversion, with parasite power on at the end
  delay(750);     // maybe 750ms is enough, maybe not
  // we might do a ds.depower() here, but the reset will take care of it.
  present = ds.reset();
  ds.select(addr);
  ds.write(0xBE);         // Read Scratchpad
  for ( i = 0; i < 9; i++) {           // we need 9 bytes
    data[i] = ds.read();
  LowByte = data[0];
  HighByte = data[1];
  TReading = (HighByte << 8) + LowByte;
  SignBit = TReading & 0x8000;  // test most sig bit
  if (SignBit) // negative
    TReading = (TReading ^ 0xffff) + 1; // 2's comp
  Tc_100 = (6 * TReading) + TReading / 4;    // multiply by (100 * 0.0625) or 6.25
  Tc_100 = (Tc_100 * 9/5) + 3200;  //Convert to fahrenheit, comment this out to display in celcius
  //Display current temperature*****************************************************************************
  lcd.setCursor(0,0);
  Whole = (Tc_100 / 100);  // separate off the whole and fractional portions
  Fract = (Tc_100 % 100);
    lcd.print(Whole, DEC);
    lcd.print(".");
    if (Fract < 10)
     lcd.print("0");
    lcd.print(Fract, DEC);
    lcd.write(0xDF);
    lcd.print("F   ");
    //Display Time******************************************************************************************
    lcd.setCursor(0,10);
    if((hour < 10 && hour > 0) || (hour > 12 && hour - 12 < 10)){
        lcd.print(" ");
    if(hour > 12){
      lcd.print(hour - 12, DEC);
    if(hour == 0){
    lcd.print(12, DEC);
    if(hour > 0 && hour < 13){
      lcd.print(hour, DEC);
    lcd.print(":");
    if(minute < 10){
      lcd.print("0");
    lcd.print(minute, DEC);
    lcd.print(":");
    if(second < 10){
      lcd.print("0");
    lcd.print(second, DEC);
    if(hour < 12 || hour == 0){
      lcd.print("AM");
    else{
      lcd.print("PM");
    //Display High Temp***********************************************************************************
 if(on_minute == 0){  //used so if bad data is sent for the first reading, it is not saved
  lcd.setCursor(1,0);
  if(Tc_100 > High){
    High = Tc_100;
    Whole = (High / 100);  // separate off the whole and fractional portions
    Fract = (High % 100);
    lcd.print("H= ");
    lcd.print(".");
    if (Fract < 10)
     lcd.print("0");
    lcd.write(0xDF);
    lcd.print(" ");
    //Display Low Temp***************************************************************************************
      if(Tc_100 < Low){
    Low = Tc_100;
    Whole = (Low / 100);  // separate off the whole and fractional portions
    Fract = (Low % 100);
    lcd.print("L= ");
    lcd.print(".");
    if (Fract < 10)
     lcd.print("0");
    lcd.write(0xDF);
    lcd.print(" ");
Third section of code
  //Relay Controls ***************************************************************************************
  //****************MH Lights****************************************************************************
   if((lights_off_temp < Tc_100 && digitalRead(left_mh) == HIGH) || (digitalRead(left_mh) == LOW && on_minute == 1)){
     lights_out_left_mh = (minute + wait_time_left_mh) % 60;
   if((lights_out_left_mh == minute) || (left_mh_on_time > mil_time  || left_mh_off_time <= mil_time)){
   if( (lights_out_left_mh == -100 && lights_off_temp > Tc_100)&&(((left_mh_off_time < left_mh_on_time) && (left_mh_on_time <= mil_time || left_mh_off_time > mil_time)) || (left_mh_on_time <= mil_time && left_mh_off_time > mil_time))  ) {
     digitalWrite(left_mh, HIGH);
   else{
     lights_out_right_mh = (minute + wait_time_right_mh) % 60;
   if((lights_out_right_mh == minute) || (right_mh_on_time > mil_time  || left_mh_off_time <= mil_time)){
   if( (lights_out_right_mh == -100 && lights_off_temp > Tc_100)&&(((right_mh_off_time < right_mh_on_time) && (right_mh_on_time <= mil_time || right_mh_off_time > mil_time)) || (right_mh_on_time <= mil_time && right_mh_off_time > mil_time))  ) {
     digitalWrite(right_mh, HIGH);
   else{
     digitalWrite(right_mh, LOW);
  //****************Actinic Lights*******************************************************************************
  if( ((actinic_off_time < actinic_on_time) && (actinic_on_time <= mil_time || actinic_off_time > mil_time)) || (actinic_on_time <= mil_time && actinic_off_time > mil_time)  ) {
    digitalWrite(actinic, HIGH);
  else{
    digitalWrite(actinic, LOW);
  //****************Refugium Lights*******************************************************************************
 if( ((fuge_off_time < fuge_on_time) && (fuge_on_time <= mil_time || fuge_off_time > mil_time)) || (fuge_on_time <= mil_time && fuge_off_time > mil_time)  ) {
    digitalWrite(fuge_light, HIGH);
  else{
    digitalWrite(fuge_light, LOW);
  //****************Fan****************************************************************************************
   if(Tc_100 > fan_on_temp){     // turn fan on if temp is above fan_on_temp
    digitalWrite(fan, HIGH);
  if(Tc_100 < fan_off_temp){    //turn fan off if temp is below fan_off_temp
   digitalWrite(fan, LOW);
  /****************Auto top off********************************************************************************
  if(digitalRead(ato_input) == LOW && ato_hour != hour){
    digitalWrite(ato, HIGH);
    delay(ato_time * 1000);               //Turn on ATO pump for the number of seconds defined by ato_time
    digitalWrite(ato, LOW);    //Turn off ATO Pump
    ato_hour = hour;  //only allow the ATO to run once per hour.
    lcd.setCursor(3,0);  //Display the last time the ATO ran
    lcd.print("ATO ");
      if(hour < 10 || (hour > 12 && hour - 12 < 10)){
        lcd.print(" ");
    if(hour > 12){
    if(hour == 0){
    lcd.print(12, DEC);
    lcd.print(":");
    if(minute < 10){
      lcd.print("0");
    if(hour < 12){
      lcd.print("AM ");
    else{
      lcd.print("PM ");
  //***********PH Probe**********************************************************************************************
  /* To calibrate ph probe set 7ph to 2V and 10PH to 1V
  total -= readings[index];               // subtract the last reading
  readings[index] = analogRead(ph_probe); // read from the sensor
  total += readings[index];               // add the reading to the total
  index = (index + 1);                    // advance to the next index
  if (index >= NUMREADINGS)               // if we're at the end of the array...
    index = 0;                            // ...wrap around to the beginning
  average = total / NUMREADINGS;          // calculate the average
    ph_val = (-1.47 * average + 1300);  //ph is stored 100 times value
    Whole = (ph_val / 100);  // separate off the whole and fractional portions
    Fract = (ph_val % 100);
    lcd.setCursor(3,12);
    lcd.print("PH ");
     if (Whole < 10){
     lcd.print(" ");
    lcd.print(".");
    if (Fract < 10){
     lcd.print("0");
 //****************Power heads and skimmer feed mode 102******************************************************************
  if(mode == 102 && digitalRead(ph_1) == LOW){
    pumps_off = -10;
  if(mode == 102 && digitalRead(ph_1) == HIGH){
    pumps_off = 10;
    pumps_on_second = second;
    if(minute + feed_time > 59){
      pumps_on_minute = (minute + feed_time) % 60;
      pumps_on_hour = hour + 1;
    else{
    pumps_on_minute = minute + feed_time;
    pumps_on_hour = hour;
      if(pumps_on_hour > 23){
      pumps_on_hour = pumps_on_hour - 24;
  if((pumps_on_hour == hour  && pumps_on_minute == minute  && pumps_on_second <= second) || pumps_off == -10){
  digitalWrite(ph_1, HIGH);
  digitalWrite(ph_2, HIGH);
  digitalWrite(skimmer, HIGH);
  pumps_off = -10;
  else{
  digitalWrite(ph_1, LOW);
  digitalWrite(ph_2, LOW);
  digitalWrite(skimmer, LOW);
  //Display when normal operation will resume*******************
  if(pumps_off != -10){
    lcd.setCursor(3,0);
    if(pumps_on_minute >= minute){
    pumps_off_second = pumps_on_second - second + feed_time * 60 + pumps_on_minute * 60 - minute * 60 - feed_time * 60;
    else{
      pumps_on = minute - 60;
      pumps_off_second = pumps_on_second - second + feed_time * 60 + pumps_on_minute * 60 - pumps_on * 60 - feed_time * 60;
   pumps_off_minute = pumps_off_second / 60;
    if(pumps_off_minute < 10){
       lcd.print(" ");
    lcd.print(pumps_off_minute);  //minutes until pumps turn on
    lcd.print(":");
    if(pumps_off_second % 60 < 10){
      lcd.print("0");
    lcd.print(pumps_off_second % 60);  //seconds until pumps turn on
    else{
    lcd.setCursor(3,0);
    lcd.print("          ");
  //Display what relays are on******************************************************************************************
  lcd.setCursor(2,0);
  if(digitalRead(fuge_light) == HIGH){lcd.print("S1 ");delay(keypad_delay);}
    else{lcd.print("S0 ");delay(keypad_delay);}
  if(digitalRead(left_mh) == HIGH){lcd.print("LMH1 ");delay(keypad_delay);}
    else{lcd.print("LMH0 ");delay(keypad_delay);}
  if(digitalRead(right_mh) == HIGH){lcd.print("RMH1 ");delay(keypad_delay);}
    else{lcd.print("RMH0 ");delay(keypad_delay);}
  if(digitalRead(actinic) == HIGH){lcd.print("A1 ");delay(keypad_delay);}
    else{lcd.print("A0 ");delay(keypad_delay);}
  if(digitalRead(ph_1) == HIGH){lcd.print("P1    ");delay(keypad_delay);}
    else{lcd.print("P0 ");delay(keypad_delay);}
  on_minute = 0;  //signals that the program has been run once
  } //end mode 100 & 102
} //end loop
bump
