Redeclaration
Hello,
I’m working on a code where you transform a 4x4 matrix whit 16 random numbers to allot more random numbers whit a button(number of times). Don’t ask me why, I just came with a stupid idea hehe.
This is the code:
const int button = 10;
boolean on = false;
int buttonState =0;
int buttonPresses = 0;
const int numRows = 4;
const int numCols = 4;
const int debounceTime = 20;
const  char keymap1[numRows][numCols] = {
  {'A', 'B', 'C', 'D'},
  {'E', 'F', 'G', 'H'},
  {'I', 'J', 'K', 'L'},
  {'M', 'N', 'O', 'P'},
const  char keymap2[numRows][numCols] = {
  {'Q', 'R', 'S', 'T'},
  {'U', 'V', 'W', 'X'},
  {'Y', 'Z', ' ', ' '},
const  char keymap3[numRows][numCols] = {
  {'a', 'b', 's', 'd'},
  {'e', 'f', 'g', 'h'},
  {'i', 'j', 'k', 'l'},
  {'m', 'n', 'o', 'p'},
const  char keymap4[numRows][numCols] = {
  {'q', 'r', 's', 't'},
  {'u', 'v', 'w', 'w'},
  {'x', 'y', 'z', ' '},
const  char keymap5[numRows][numCols] = {
  {'1', '2', '3', '4'},
  {'5', '6', '7', '8'},
  {'9', '+', '-', '*'},
const int rowPins[numRows] = {2, 3, 4, 5};
const int colPins[numCols] = {6, 7, 8, 9};
char getKey1(){
  char key = 0;
  for (int column = 0; column < numCols; column++){
    digitalWrite(colPins[column], LOW);
    for (int row = 0; row < numRows; row++){
      if (digitalRead(rowPins[row]) == LOW){
        delay(debounceTime);
        while (digitalRead(rowPins[row]) == LOW);
        key = keymap1[row][column];
    digitalWrite(colPins[column], HIGH);
  return key;
char getKey2(){
  char key = 0;
        key = keymap2[row][column];
  return key;
char getKey3(){
  char key = 0;
        key = keymap3[row][column];
  return key;
char getKey4(){
  char key = 0;
        key = keymap4[row][column];
  return key;
char getKey5(){
  char key = 0;
        key = keymap5[row][column];
  return key;
void setup(){
  pinMode(10, INPUT);
    pinMode(rowPins[row], INPUT);
    digitalWrite(rowPins[row], HIGH);
    pinMode(colPins[column], OUTPUT);
void loop(){
  if(digitalRead(button) == HIGH){ // This will check how many times button1 is pressed and save the positions to an array depending on how many times it is pressed; switch/case works like a if statement
    buttonPresses++;
    switch(buttonPresses){
      case 1:
            char key = getKey1();
            if (key !=  0){
              Serial.print(key);
      case 2:
            char key = getKey2();
            if (key !=  0){
              Serial.print(key);
      case 3:
            char key = getKey3();
            if (key !=  0){
              Serial.print(key);
       case 4:
            char key = getKey4();
            if (key !=  0){
              Serial.print(key);
       case 5:
            char key = getKey5();
            if (key !=  0){
              Serial.print(key);
But the error I get is a redeclaration for the ‘char key’ in the void loop(). I taught that the return command it would work, but it doesn’t. Can someone help me understand what’s wrong with this code?
Tanks in advance.
Ow nevermind I got it
It will not. There is a huge difference between the switch IS presses and HAS BECOME pressed. You haven't a clue what you are counting.
I'm not saying that to be insulting. You just have no idea how many times loop() will iterate while the switch is pressed. It depends on what else the Arduino is doing.
