Redefinition of void setup() Error
So I am new to the Arduino scene. I was doing one of the starting projects and got a load of errors uploading and compiling my sketch.
Here it is
void setup(){
void loop(){
int switchState = 0;
void setup(){
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(2, OUTPUT);
void loop(){
switchState = digitalRead(2);
// this is a comment
if (switchState == LOW) {
//the button is not pressed
digitalWrite(3, HIGH);
digitalWrite(4, LOW);
digitalWrite(5, LOW);
else{
digitalWrite(3, LOW);
digitalWrite(4 LOW);
digitalWrite(5, HIGH);
delay(125);
digitalWrite(4, HIGH)
delay(150);
Please Help
You have two void setup()s, as well as two void loop()s.
Delete the empty ones.
Next time, use code tags, which is the button that looks like </>
You appear to have an extra setup and loop function defined (but empty) at the top of your sketch. There can be only one setup and loop function.
void setup(){
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(2, INPUT);
void loop(){
  else{
    delay(125);
    delay(150);
Try this.
make 2pin as input.(in your code you are used that pin as output.)
But You are try to read the pin.
