Redifining Volatile Error
I got this sketch off the internet with a Cut and Paste and I hope I've got the error/code format right. Copied the error message, Code tags etc.
The sketch won't verify/compile. The error is something about redefinition of "volatile int rpmcount". There's a reference link to volatile and I've looked it several times.
It seems a volatile variable needs to be from RAM vs a Storage Register. This sketch counts pulses so I'm guessing the need for a volatile is because the number can change. I've also noticed the very first line of code seems to establish the "volatile int rpmcount as 0, but I don't know what to make of that.
I'm deeply interested in this particular sketch and was planning on getting it running so I could study it further, but maybe there's something to learn by fixing the code or whatever it is I'm doing wrong.
Here it is:
 Arduino: 1.8.5 (Windows 8.1), Board: "Arduino/Genuino Uno"
sketch_nov11a:44: error: redefinition of 'volatile int rpmcount'
 volatile int rpmcount = 0;//see http://arduino.cc/en/Reference/Volatile
C:\Users\Bill\AppData\Local\Temp\arduino_modified_sketch_928984\sketch_nov11a.ino:3:14: note: 'volatile int rpmcount' previously defined here
sketch_nov11a:45: error: conflicting declaration 'long unsigned int rpm'
 unsigned long rpm = 0;
C:\Users\Bill\AppData\Local\Temp\arduino_modified_sketch_928984\sketch_nov11a.ino:4:5: note: previous declaration as 'int rpm'
 int rpm = 0;
sketch_nov11a:46: error: redefinition of 'long unsigned int lastmillis'
 unsigned long lastmillis = 0;
C:\Users\Bill\AppData\Local\Temp\arduino_modified_sketch_928984\sketch_nov11a.ino:5:15: note: 'long unsigned int lastmillis' previously defined here
C:\Users\Bill\AppData\Local\Temp\arduino_modified_sketch_928984\sketch_nov11a.ino: In function 'void setup()':
sketch_nov11a:48: error: redefinition of 'void setup()'
 void setup(){
C:\Users\Bill\AppData\Local\Temp\arduino_modified_sketch_928984\sketch_nov11a.ino:7:6: note: 'void setup()' previously defined here
 void setup(){
C:\Users\Bill\AppData\Local\Temp\arduino_modified_sketch_928984\sketch_nov11a.ino: In function 'void loop()':
sketch_nov11a:53: error: redefinition of 'void loop()'
 void loop(){
C:\Users\Bill\AppData\Local\Temp\arduino_modified_sketch_928984\sketch_nov11a.ino:12:6: note: 'void loop()' previously defined here
 void loop(){
C:\Users\Bill\AppData\Local\Temp\arduino_modified_sketch_928984\sketch_nov11a.ino: In function 'void rpm_fan()':
sketch_nov11a:88: error: redefinition of 'void rpm_fan()'
 void rpm_fan(){ /* this code will be executed every time the interrupt 0 (pin2) gets low.*/
C:\Users\Bill\AppData\Local\Temp\arduino_modified_sketch_928984\sketch_nov11a.ino:33:6: note: 'void rpm_fan()' previously defined here
exit status 1
option enabled in File -> Preferences.
pntrbl:
I got this sketch...
LOL! What sketch? That would seem to be pertinent to any sort of discussion. Wouldn't it? :o
The sketch;
// read RPM
int rpm = 0;
void setup(){
 attachInterrupt(0, rpm_fan, FALLING);//interrupt cero (0) is on pin two(2).
void loop(){
 if (millis() - lastmillis == 1000){  /*Uptade every one second, this will be equal to reading frecuency (Hz).*/
 detachInterrupt(0);    //Disable interrupt when calculating
 rpm = rpmcount * 60;  /* Convert frecuency to RPM, note: this works for one interruption per full rotation. For two interrups per full rotation use rpmcount * 30.*/
 Serial.print("RPM =\t"); //print the word "RPM" and tab.
 Serial.print(rpm); // print the rpm value.
 Serial.print("\t Hz=\t"); //print the word "Hz".
 Serial.println(rpmcount); /*print revolutions per second or Hz. And print new line or enter.*/
 rpmcount = 0; // Restart the RPM counter
 lastmillis = millis(); // Uptade lasmillis
 attachInterrupt(0, rpm_fan, FALLING); //enable interrupt
  rpmcount++;
// Elimelec Lopez - April 25th 2013
// read RPM and calculate average every then readings.
const int numreadings = 10;
int readings[numreadings];
unsigned long average = 0;
int index = 0;
unsigned long total;
void setup(){
void loop(){
 if (millis() - lastmillis >= 1000){  /*Uptade every one second, this will be equal to reading frecuency (Hz).*/
 total = 0;
 readings[index] = rpmcount * 60;  /* Convert frecuency to RPM, note: this works for one interruption per full rotation. For two interrups per full rotation use rpmcount * 30.*/
 for (int x=0; x<=9; x++){
   total = total + readings[x];
 average = total / numreadings;
 rpm = average;
 index++;
 if(index >= numreadings){
  index=0;
if (millis() > 11000){  // wait for RPMs average to get stable
 Serial.print(" RPM = ");
 Serial.println(rpm);
  rpmcount++;
And the error message again;
 int rpm = 0;
 void setup(){
 void setup(){
 void loop(){
 void loop(){
exit status 1
You have several variables declared twice. Don't do that.
Needs to be greater than or equal.
I've no direct experience but, I've read other posts to the effect that using nointerrupts() and its opposite number is preferable to detaching/reattaching interrupts.
The difference is that an interrupt that comes in while detached is simply gone, it never existed. Interrupts arriving while disabled via noInterrupts() will be latched and acted upon when re-enabled via interrupts().
ONE instance of the interrupt will be queued, not ALL instances.
The absolute minimum time should be spent with interrupts disabled/detached. Serial printing is verbotten in that context. Disable/detach the interrupt. Copy the needed data. Re-enable/re-attach the interrupts. THEN, perform the required computations based on the copied data and print, as needed.
PaulS:
Thanks for the clarification.
