Redifintion of int red error issue with the code
#include <Wire.h>
#include <DallasTemperature.h>
#define RELAY1  4  // Relay heating
#define RELAY2  6  // Relay cooling
int red = 8 // red LED heating
int blue = 2 // blue LED cooling
#define BACKLIGHT_PIN 13
#define ONE_WIRE_BUS 7
LiquidCrystal_I2C lcd(0x27F, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
  sensors.begin();
  lcd.begin(20, 4);
  lcd.backlight();
  pinMode(red, OUTPUT);
  pinMode(blue, OUTPUT);
  pinMode(RELAY1, OUTPUT);
  pinMode(RELAY2, OUTPUT);
  lcd.setCursor(0, 0);
  lcd.print(" TEMP CONTROL");
  sensors.requestTemperatures();
  float temperature = sensors.getTempCByIndex(0);
  lcd.setCursor(0, 2);
  lcd.print("      ");
  lcd.print(sensors.getTempCByIndex(0));
  lcd.print("\337C");
if (temperature < 25) ////// Had a bogus ';' here
  digitalWrite(red, HIGH);
  digitalWrite(blue, LOW);
  digitalWrite(RELAY1, 0);
  digitalWrite(RELAY2, 1);
  lcd.setCursor(0, 3);
  lcd.print("      Heating");
else if (temperature > 25) ////// Had a bogus ';' here
  digitalWrite(RELAY1, 1);
  digitalWrite(RELAY2, 0);
  digitalWrite(red, LOW);
  digitalWrite(blue, HIGH);
  lcd.setCursor(0, 4);
  lcd.print("      Cooling ");
Hello Everyone,
I have shared the code above, it is for a temperature sensor and I am using if and else condition, but I am having an issue of redefinition of int red error, can anyone please suggest any input ?
The curly brackets for setup() and loop() are in the wrong places. Look at some example code to see the proper syntax.
Plus a handful of other errors...
Missing semicolons.
Too many arguments, I think (!). And POSITIVE is not defined.
{    // Useless brace
  void setup()  // Missing brace
{    // Useless brace
  void loop()  // Missing brace
And some code that's not in a function:
 lcd.print("      ");
 lcd.print("\337C");
etc...
I fixed your code so that it compiles. I fixed the parts that Erik_Baas pointed out and others. See the comments in the code.
I think that you are using code from one LiquidCrystal library and including a different one. There are several libraries called LiquidCrystalI2C and they are different. The best current library for the hd44780 controller LCDs is the hd44780 library. For an I2C LCD display to work, the I2C address and the I2C backpack to LCD pin mapping must be correct. If the library default settings for either or both are not correct the LCD will not work. You can try to figure out the right pin mapping and use an I2C scanner to find the address, but if you install and use the hd44780 library that is done automatically by the library.
To install the hd44780 library. The hd44780 library is the best available for I2C LCDs. The library is available in the Library Manager. Go to Library Manager (in the IDE menus, Sketch, Include Libraries, Manage Libraries) and in the Topics dropdown choose Display and in the Filter your search box enter hd44780. Select and install the hd44780 library by Bill Perry.
The class that you want to use is the hd44780_I2Cexp class. There are examples to show how to use the library. The nice thing about the hd44780 library is that it will autodetect the I2C address and the I2C backpack to LCD pin mapping.
In the examples, there is a diagnostic sketch that will help us to help you if you still have trouble with the display. Run the diagnostic sketch and post the results.
Your code:
#include <Wire.h>
//#include <LiquidCrystal_I2C.h>  // wrong library for the code
#include <hd44780.h>                       // main hd44780 header
#include <hd44780ioClass/hd44780_I2Cexp.h> // i2c expander i/o class header
int red = 8; //  ********* missing ; // red LED heating
int blue = 2; //  ********* missing ; // blue LED cooling
//LiquidCrystal_I2C lcd(0x27F, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
hd44780_I2Cexp lcd; // declare lcd object: auto locate & auto config expander chip
// {   ********* in wrong place
{ // ********* added
   sensors.begin();
   lcd.begin(20, 4);
   lcd.backlight();
// {   ********* wrong place
   // }  ********* wrong place
   lcd.print("      ");
   lcd.print("\337C");
   //}  ********* wrong place
} //  ********* added
