Redirecting to file on Ethernet Shield SD card
I have a web page I want to host on my Arduino w/ Ethernet Shield but I don't want to have to put in every line of the markup into the sketch. There are also a couple of files that I can't put into the sketch. Is there anyway to show the browser the files on the shield's SD card, so that it can use them?
Have you looked at tinywebserver? https://github.com/ovidiucp/TinyWebServer I don't recall whether I needed to mod it; but I have used it to serve files from sd. Basically anything I didn't recognize as a command was treated as a file on SD. Best regards Jantje
Test code for supplying a file from the SD card to the browser.
//zoomkat 12/26/12
//SD server test code
//open serial monitor to see what the arduino receives
//address will look like http://192.168.1.102:84 when submited
//for use with W5100 based ethernet shields
#include <SD.h>
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port
String readString;
void setup(){
  // disable w5100 while setting up SD
  pinMode(10,OUTPUT);
  digitalWrite(10,HIGH);
  Serial.print("Starting SD..");
  if(!SD.begin(4)) Serial.println("failed");
  else Serial.println("ok");
  Ethernet.begin(mac, ip, gateway, gateway, subnet);
  //delay(2000);
  server.begin();
  Serial.println("Ready");
void loop(){
  // Create a client connection
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        //read char by char HTTP request
        if (readString.length() < 100) {
          //store characters to string
          readString += c;
          //Serial.print(c);
        //if HTTP request has ended
        if (c == '\n') {
          Serial.println(readString); //print to serial monitor for debuging
          client.println("HTTP/1.1 200 OK"); //send new page
          client.println("Content-Type: text/html");
          //client.println("Content-Type: image/jpeg");
          //client.println("Content-Type: image/gif");
          //client.println("Content-Type: application/x-javascript");
          //client.println("Content-Type: text");
          client.println();
          //File myFile = SD.open("boom.htm");
          File myFile = SD.open("HYPNO.JPG");
          //File myFile = SD.open("BLUEH_SL.GIF");
          //File myFile = SD.open("SERVOSLD.HTM");
          if (myFile) {
            //Serial.println("test.txt:");
            // read from the file until there's nothing else in it:
            while (myFile.available()) {
              client.write(myFile.read());
            // close the file:
            myFile.close();
            delay(1);
            //stopping client
            client.stop();
            readString="";
Thanks I converted the example code to how it fit my needs but now the site is stuck “transferring data” and the file will not load. Any ideas?
I’d assume that you would want to see my sketch so here it is:
#include <SPI.h>
#include <SD.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
IPAddress ip(192, 168, 1, 24);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
  // start the Ethernet connection and the server:
  Ethernet.begin(mac, ip);
  server.begin();
  Serial.print("server is at ");
  Serial.println(Ethernet.localIP());
  pinMode(10,OUTPUT);
int b = 1;
  // listen for incoming clients
  if (client) {
    Serial.println("new client");
    // an http request ends with a blank line
      digitalWrite(8, HIGH);
        Serial.write(c);
        if (c == '\n')
          client.println();
          File index = SD.open("index.html");
          if(index)
            while (index.available())
              client.write(index.read());
            index.close();
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
    digitalWrite(8, LOW);
    Serial.println("client disonnected");
Any ideas?
Looks completely different from my code.
