reduce noise on analog sensor
First of all I hope to have a good day
I need help with a temperature monitoring project which
It consists of a thermal probe connected to an arduino one. make the connection
and everything works perfect I can read the temperature without problem.
the problem arose in the place where I want to locate the project where
in some moments the probe sending an erroneous signal (-127.00)
but it is alternated, then resets the correct reading.
In the place there are several signals and electrical equipment working.
I think the mistake is difficult because of the noise in the place.
I was reading a bit and saw the option of placing an optocoupler to remove
the noise in the probe reading. Is this a good option? what kind of opcocoupler
Should use?
HI,
It would help if you identified the sensor and what board you are using. Also the wiring you are using (could be a hand sketch if not too complex.)
You might read the how to post section for more useful information.
John
I am using the sensor DS18B20 (10 meters) and arduino uno..
the connection cable is the one that brings the probe
Try using a stiffer (lower value) pull-up resistor on the OneWire signal, 4k7 or 3k3.
I suspect the cable isn't shielded allowing noise in. If you can break the cable near the sensor and add a
100nF ceramic decoupling capacitor between 5V and ground in the cable that might help.
Optocouplers don't work on the OneWire bus.
Colorambal:
The DS18B20 is digital, not analog.
But MarkT's suggestion of a smaller pullup resistor should help. Put the resistor at the sensor end, not the Arduino end.
I use similar probes. I read the probe every ten seconds, the arduino sleeps for eight seconds between readings, and then it powers up the radio, and takes the reading. I ignore temperatures below -50 when I save the data. I also get odd values of -500 as the battery goes flat, but the -127 is the probe function., iirc. Have a look at the Dallas data sheet, you may be better connecting it as one wire., or not. I expect the cable is unscreened.
