Hi, I bought this capacitive led touch dimmer and it's working perfectly fine but the problem is that it's taking 1.5mA of current when main led is off. There seems to be a red led indicator on the module which I think is taking most of that current.
Can I safely take out that led? will the module still work? I dont know if the led in the cirsuit is series or parallel. Here is the picture of that module.
Yes, it runs from Vcc (after a diode) to GND, so its just showing power. You could drill out
the via on the reverse side of the board to break the connection, which allows reconnection by
soldering in a thin wire.
