Hello humans,
I've been using arduino + HM10 BLE to talk with an MIT AI2 app. I have the basic setup as follows:
- Arduino sends the app the initial variables (Mode,speed,brightness etc)
- App tells arduino when to change a value and to send updated variables after change
Now im running into some serious lag and delay issues and eventual hanging of the arduino when the App sends multiple requests.
Here is a copy of my entire code with a millis readout added to the main loop to allow me to attempt to diagnose the problem.
#include "FastLED.h"
#include <SoftwareSerial.h>
#define NUM_LEDS 144 ///144
#define PIN 3 // LED signal Pin
SoftwareSerial HM10(9, 8);///9 (RX) ///8 (TX)
CRGB pixels[NUM_LEDS];
int leds[294]; ///For Aligning Vertical/Horizontal Motion /// NUMBER OF LEDS IN ONE CIRCLE~?leds[NUM_LEDS/4];
int max_overall_brightness = 255;
int overall_brightness = 255;
float red_max = 1;
float green_max = 1;
float blue_max = 1;
int red;
int green;
int blue;
int animation_rate = 5;
int MAXanimation_rate = 10;
int mode = 0; // Animation mode index
int MAXmode = 14; // max mode index
int incoming_command = 0;
int animation_speed = 2;
// These variables are used within the animation methods.
// They are scoped by name, but global in the sketch,
// so that animations will not restart when commands are received.
///////////////////////////////Serial BT Receiver
int Power;
const byte numChars = 32; //array size limiter
char receivedChars[numChars]; // Array of received data
boolean RecNewData = false;
boolean SendNewData = false;
static byte ndx = 0; // index size of array
bool modechanged = true;
bool animchanged = true;
bool Brightchanged = true;
bool Powerchanged = true;
char CSV[2] = {',','\0'};
//char AAA[4] = {'M', '1', '3','\0'};
//char BBB[3] = {'S', '4','\0'};
//char CCC[4] = {'V', '8','0','\0'};
//char DDD[3] = {'P', '1','\0'};
//BeaconEDIT Vars
int VerticalLEDs = 6;
int HorizontalLEDs = 24; //LEDS in one circle
// Beacon Vars
double beacon_angle = 0;
int beacon_led_angle = 0;
double beacon_left_distance = 0;
double beacon_right_distance = 0;
double beacon_absolute_distance = 0.0;
int beacon_beam_width = 10; // in degrees
int beacon_beam_width_Half = (HorizontalLEDs / VerticalLEDs);
int beacon_falloff = 35; // in degrees
int beacon_pixel_brightness = 0; // in degrees
volatile boolean animate = true;
volatile long animation_change_timeout;
LEDS.setBrightness(255);
FastLED.addLeds<WS2812B, PIN, GRB>(pixels, NUM_LEDS).setCorrection(TypicalLEDStrip);
FastLED.setMaxPowerInVoltsAndMilliamps(5, 700); // limit power of LED strip to 5V, 500mA
FastLED.clear();
HM10.begin(9600);
unsigned long start = micros();
recvWithStartEndMarkers(); // Receive BT serial data
unsigned long end = micros();
unsigned long delta = end - start;
Serial.print("SerialBufferScan = ");
Serial.println(delta);
unsigned long start2 = micros();
RecNewDataFunc(); // Use BT serial Data
unsigned long end2 = micros();
unsigned long echo = end2 - start2;
Serial.print("SerialDataStore = ");
Serial.println(echo);
unsigned long start3 = micros();
SendNewDataFunc();
unsigned long end3 = micros();
unsigned long fox = end3 - start3;
Serial.print("SerialDataSend = ");
Serial.println(fox);
switch (incoming_command) {
// Color Buttons
case 0:
red_max = 1;
blue_max = 0;
green_max = 0;
case 99:
default:
switch (mode) {
/// beacon(int beams,int vertical);
case 0:
lamp ();
case 1:
beacon(1);
case 2:
beacon(2);
case 3:
beacon(3);
case 4:
beacon(4);
case 5:
beacon(5);
case 6:
beacon(6);
case 7:
beacon(7);
case 8:
beacon(8);
case 9:
beacon(9);
case 10:
beacon(10);
case 11:
beacon(11);
case 12:
beacon(12);
case 13:
lamp ();
case 14:
lamp ();
case 99:
rest ();
default:
animation_change_timeout = 0;
animate = true;
void recvWithStartEndMarkers() {
static boolean recvInProgress = false;
ndx = 0;
char startMarker = '<';
char endMarker = '>';
char IncomingChar;
while (HM10.available() > 0 && RecNewData == false) {
IncomingChar = HM10.read();
if (recvInProgress == true) { // If receiving
if (IncomingChar != endMarker) { // if incoming is not line end marker
receivedChars[ndx] = IncomingChar; // index chars in array
ndx++; // increase index number
if (ndx >= numChars) { // if index exceeds byte limit
ndx = numChars - 1; // set index to re-write over last char in array
else {
receivedChars[ndx] = '\0'; // terminate the string
//ndx = 0; //reset index value
RecNewData = true; // enable data release
else if (IncomingChar == startMarker) { /// if string start marker found
recvInProgress = true; // enable data copy proccess
// Serial.println(recvInProgress);
void RecNewDataFunc() { /// Find values in received Data
if (RecNewData == true) {
// Serial.print("This just in ... ");
// Serial.println(receivedChars);
char ControlValue;
if (receivedChars[0] == 77){ // if mode('M') char found ASCII
// mode = atoi(&receivedChars[1]); /// convert chars from 1 upwards
// Serial.print("mode:"); // print mode result
// Serial.println(mode); // print mode result
ControlValue = receivedChars[1]; /// convert chars from 1 upwards
modechanged = true;
if (ControlValue == '+'){
if ((mode < MAXmode)&&(mode != 99)){
mode += 1;
else if (mode == 99){
mode = 0;
else if (ControlValue == '-'){
if ((mode > 0)&&(mode != 99)){
mode -= 1;
mode = 0;
// Serial.print("ControlValue:"); // print mode result
// Serial.println(ControlValue); // print mode result
// Serial.print("modechanged:"); // print mode result
// Serial.println(modechanged); // print mode result
else if (receivedChars[0] == 83){ // if speed('S') char found ASCII
// animation_rate = atoi(&receivedChars[1]); /// convert chars from 1 upwards
///Serial.print("animation_rate:"); // print mode result
///Serial.println(animation_rate); // print mode result
animchanged = true;
if (animation_rate < MAXmode){
animation_rate += 1;
if (MAXanimation_rate > 0){
animation_rate -= 1;
// Serial.print("animation_rate:"); // print mode result
// Serial.println(animation_rate); // print mode result
// Serial.print("animchanged:"); // print mode result
// Serial.println(animchanged); // print mode result
else if (receivedChars[0] == 86){ // if brightness('V') char found ASCII
// int overall_brightness_Rec = atoi(&receivedChars[1]); /// convert chars from 1 upwards
// overall_brightness = (overall_brightness_Rec * 2.55);
// Serial.print("overall_brightness:"); // print mode result
// Serial.println(overall_brightness); // print mode result
if (overall_brightness < max_overall_brightness){
overall_brightness += 5;
if (overall_brightness > 5){
overall_brightness -= 5;
// Serial.print("Brightchanged:"); // print mode result
// Serial.println(Brightchanged); // print mode result
else if (receivedChars[0] == 82){ // if red('R') char found ASCII
int red_Rec = atoi(&receivedChars[1]); /// convert chars from 1 upwards
green_max = ((float)red_Rec / 255); /// convert 255 into decimal for animations
// Serial.print("red_max:"); // print mode result
// Serial.println(red_max); // print mode result
incoming_command = 99;
else if (receivedChars[0] == 71){ // if green('G') char found ASCII
int green_Rec = atoi(&receivedChars[1]); /// convert chars from 1 upwards
red_max = ((float)green_Rec / 255); /// convert 255 into decimal for animations
// Serial.print("green_max:"); // print mode result
// Serial.println(green_max); // print mode result
else if (receivedChars[0] == 66){ // if blue('B') char found ASCII
int blue_Rec = atoi(&receivedChars[1]); /// convert chars from 1 upwards
blue_max = ((float)blue_Rec / 255); /// convert 255 into decimal for animations
// Serial.print("blue_max:"); // print mode result
// Serial.println(blue_max); // print mode result
else if (receivedChars[0] == 80){ // if Power('P') char found ASCII
mode = 0;
Power = 1;
mode = 99;
Power = 0;
// Serial.print("Power:"); // print mode result
// Serial.println(Power); // print mode result
// Serial.print("Powerchanged:"); // print mode result
// Serial.println(Powerchanged); // print mode result
// else if (receivedChars[0] == 88){ // if SendValuesRequest('X') char found ASCII
// SendNewData = true;
RecNewData = false;
SendNewData = true;
void SendNewDataFunc() { /// Find values in received Data
if (SendNewData == true) {
int BrightnessConversion = (overall_brightness / 2.55);
char BUFFER[6];
if (modechanged == true){
HM10.write('M');
HM10.write(itoa((mode),BUFFER,10));
HM10.write(CSV);
// HM10.write(itoa((mode += 'M') += ','),BUFFER,10);
if (animchanged == true){
HM10.write('S');
HM10.write(itoa(animation_rate,BUFFER,10));
HM10.write(CSV);
// HM10.write(itoa((animation_rate += 'S') += ','),BUFFER,10);
if (Brightchanged == true ){
HM10.write('V');
HM10.write(itoa(BrightnessConversion,BUFFER,10));
HM10.write(CSV);
// HM10.write(itoa((BrightnessConversion += 'V') += ','),BUFFER,10);
if (Powerchanged == true){
HM10.write('P');
HM10.write(itoa(Power,BUFFER,10));
HM10.write(CSV);
// HM10.write(itoa((Power += 'P') += ','),BUFFER,10);
modechanged = false;
animchanged = false;
Brightchanged = false;
Powerchanged = false;
void break_for_input() {
if (animation_change_timeout > 100) {
animate = false;
void change_animation_rate(bool dir) {
if (dir == 0){
if (animation_rate < MAXanimation_rate) {
animation_rate++;
else if (dir == 1){
if (animation_rate < 0) {
animation_rate--;
void rest () {
long loop_start = millis();
while(animate) {
for(int i=0; i<NUM_LEDS; i++) {
pixels[i] = CRGB(0, 0, 0);
FastLED.show();
animation_change_timeout = millis() - loop_start;
EVERY_N_MILLIS(100){
break_for_input();
void lamp () {
while(animate) {
//Some quick and dirty grascale whitebalance and min brigtness corrections
red = max_overall_brightness;
green = max_overall_brightness - 3/max_overall_brightness;
if (green < 0) green = 0;
if (max_overall_brightness > 1 && green < 2) green = 2;
blue = max_overall_brightness * .45;
if (max_overall_brightness > 1 && blue < 2) blue = 2;
// Aapply color maximums
red *= red_max * (overall_brightness / 255.0);
green *= green_max * (overall_brightness / 255.0);
blue *= blue_max * (overall_brightness / 255.0);
pixels[i] = CRGB(green, red, blue);
FastLED.show();
break_for_input();
void beacon(int beams) {
// Set start time for minimum time to chenge interval
while (animate) {
// Beacon angle is normalized to -180 to 180 degrees to make angular distance calc easier
//Find the angle on the tube of the current LED
// beacon_led_angle = fmod((i * (360.0 / 11.41)), 360.0); ///OG VALUES FMOD = https://en.cppreference.com/w/c/numeric/math/fmod
////////Beacon angle used to change animation types//////////
if (beams == 1){ //SingleBeam
beacon_led_angle = fmod(i * (360 / HorizontalLEDs), 360);
else if (beams == 2){ //DoubleBeam
beacon_led_angle = fmod((i * (360 / (HorizontalLEDs /2) )), 360);
else if (beams == 3){ // Meteors
beacon_led_angle = fmod((i * (360 / (HorizontalLEDs - VerticalLEDs) ) ), 360);
else if (beams == 4){ //Falling Spiral
beacon_led_angle = fmod((i * (360 / ((HorizontalLEDs - VerticalLEDs)/2) )), 360);
else if (beams == 5){ //Climbing Spiral
beacon_led_angle = fmod((i * (360 / ((HorizontalLEDs - VerticalLEDs)/3) )), 360);
else if (beams == 6){ // ODD/EVEN Flash
beacon_led_angle = fmod((i * (360 / ((HorizontalLEDs - VerticalLEDs)/VerticalLEDs) )), 360);
else if (beams == 7){ // Climbing Ring
beacon_led_angle = fmod(i * (360 / (HorizontalLEDs * VerticalLEDs)), 360);
else if (beams == 8){ // Beacon Flash Fade
beacon_led_angle = fmod(i * ((HorizontalLEDs * VerticalLEDs)/360), 360);
else if (beams == 9){ // Falling Ring
beacon_led_angle = fmod(i * (360 * HorizontalLEDs), 360);
else if (beams == 10){ // Thick Falling Ring
beacon_led_angle = fmod((i * (360 * (HorizontalLEDs / VerticalLEDs) )), 360);
else if (beams == 11){ // Rain
beacon_led_angle = fmod((i * (360 * (HorizontalLEDs*(HorizontalLEDs*2)) )), 360);
else if (beams == 12){ // TwistFill
beacon_led_angle = fmod(i * (i/HorizontalLEDs), 45);
//Normalize heading to -180 to 180 for angular distance to beacon calc
if (beacon_led_angle < beacon_angle) beacon_led_angle += 360;
beacon_left_distance = beacon_led_angle - beacon_angle;
if (beacon_left_distance < 180) {
beacon_absolute_distance = abs(beacon_left_distance);
beacon_absolute_distance = abs(360.0 - beacon_left_distance);
//Find pixel brightness given beam characteristics
if (beacon_absolute_distance <= beacon_beam_width_Half) {
beacon_pixel_brightness = overall_brightness;
} else if (beacon_absolute_distance <= (beacon_beam_width_Half + beacon_falloff)) {
beacon_pixel_brightness = overall_brightness - ((overall_brightness/(float)beacon_falloff) * (beacon_absolute_distance - beacon_beam_width_Half));
//Some quick and dirty grascale whitebalance and min brightness corrections
red = beacon_pixel_brightness;
green = beacon_pixel_brightness - 3/beacon_pixel_brightness;
if (beacon_pixel_brightness > 1 && green < 2) green = 2;
blue = beacon_pixel_brightness * .45;
if (beacon_pixel_brightness > 1 && blue < 2) blue = 2;
//Finally, apply color maximums
red *= red_max;
green *= green_max;
blue *= blue_max;
//Assign color
beacon_angle += (0.05 * (animation_rate * animation_rate * 3));
FastLED.show();
if (beacon_angle >= 360) {
beacon_angle -= 360;
break_for_input();
From the app the longest string sent is "<R255>"
(But will be in groups of 3 - RGB values)
From the arduino the longest string sent is "M20," (4 chars? )
If someone can give me advise on the best course of action that would be great.
Any options need to be non-blocking and I am currently considering:
- Create a storage variable inside the App with a clock delay to only send one snippet at a time.
(I would prefer to have limited delay between button presses and arduino action so not prefferable) - Honestly thats all i've got. SerialOptimisation isn't something i've ever considered...
Here is an example of the times taken once inputs are received and sent. (20,5,5 is idle jumps to 100s to start with then spikes into the 10000's)
