Does anyone have any idea of how to reduce the sensitivity of a PIR detector?
I have a PIR driven plastic owl in my garden to scare the critters out. It surprisingly seems to keep them out, but the PIR sensor is so sensitive, that any critter within 20-30 ft sets it off when I really want a 2-3 ft range. The result is that I am replacing the batteries every two or three days.
There is no adjustment. The PIR is in a moulded enclosure with no way to access whatever module is inside. Any changes have to be external to the PIR sensor.
You can alter your software so it requires a number of hits before operating the owl . This doesn’t reduce sensitivity but helps reduce false triggers .
I am intrigued into what the plastic owl does when triggered?
Could a larger, rechargable, battery pack be an answer?
The problem with reducing the range is that light/IR doesn't really have a range - if you make it sensitive
to small critter nearby it will also be sensitive to larger critter further away. And the basic sensor isn't
adjustable, only the circuit responding to the sensor can be adjusted to wait longer before believing
the sensor, or have a higher threshold (which risks missing smaller critters).
hammy:
That assumes that I know what's inside the plastic owl.
MarkT:
Flashing LED eyes, which I don't think actually fool the chipmunks at all. But the pulsing ultrasonic transducer does seem to be keeping them out of the garden. As long as the batteries last, which is about two days.
