But it is a game flappy birds.
Memory flash, too, I should have written it better.
flappp_com.ino (15.5 KB)
tee1:
You wrote it?
boolean data111[8][8]=
{0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0},//8
I suspect that 'boolean' uses a byte of FLASH and SRAM. That is 64 bytes per array. I would recommend packing each row into a byte and unpacking when needed:
byte data111[8]=
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000
Every place you have .print("string constant"); or .println("string constant"); use .print(F("string constant")); or .println(F("string constant")); That will keep the strings from using SRAM as well as FLASH.
pYro_65:
You wrote it?
I wrote it all
byte data111[8]=
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000
[/quote]
Thank you It will guide you how to make more programming by other means is created array
To reduce the size of the program I will not see it
tee1:
I wrote it all
tee1 == Shae Erisson ?
