Hello All,
I am currently working on replicating this project: https://maker.pro/arduino/projects/christmas-light-show-with-arduino
The difference is that I am wanting to do only one 8 channel relay board.
My thought is that the code is referencing 3 seperate “74HC595 IC” and I only have one connected.
I have successfully gotten Studio One’s MIDI output to speak to the Arduino Serial Port, however the relays do not turn on. Currently it is configured with only one relay board.
Is it possible to modify this code to include reference to only one 74HC595 IC and therefore only one relay board?
/* Christmas New year light show with Arduino
* by Akshay James
* My blog: techmusician.wordpress.com/2017/01/01/the-arduino-lights-project/
* This project was inspired from a YouTube video by John Storms
* from his channel ListenToOurLights (http://www.youtube.com/user/listentoourlights).
* Thank you.
* GND (pin 8) to ground,
* Vcc (pin 16) to 5V
* OE (pin 13) to ground
* MR (pin 10) to 5V
* DS (pin 14) to Ardunio DigitalPin 9 (blue wire)
* SH_CP (pin 11) to to Ardunio DigitalPin 8 (yellow wire)
* ST_CP (pin 12) to Ardunio DigitalPin 10 (green wire)
#include"notes_bits.h"
//Pin connected to latch pin (ST_CP) of 74HC595
const int latchPin = 9;
//Pin connected to clock pin (SH_CP) of 74HC595
const int clockPin = 8;
//Pin connected to Data in (DS) of 74HC595
const int dataPin = 10;
int pitch, cmd, velocity;
int light;
boolean state;
byte lightData1 = 0, lightData2 = 0, lightData3 = 0; //
pinMode(latchPin, OUTPUT);
pinMode(dataPin, OUTPUT);
pinMode(clockPin, OUTPUT);
Serial.begin(38400);
//read the midi signal
if(Serial.available()>2) {
cmd = Serial.read();
pitch = Serial.read();
velocity = Serial.read();
//the lights are set according to the data on MIDI ch.1
if(cmd==144) state=0; //144 ch1 noteON ; 0=relayON
else if(cmd==128) state=1; //128 ch1 noteOFF ; 1=relayOFF
// so that lights don't change while the new data is being shifted
digitalWrite(latchPin, LOW);
light = getBit(pitch);
// set the corresponding bit in lightData
if(light<8)
bitWrite(lightData1, light, state);
else if(light<16){
light-=8;
bitWrite(lightData2, light, state);
else {
light-=16;
bitWrite(lightData3, light, state);
// shift out the data
shiftOut(dataPin, clockPin, MSBFIRST, lightData3);
shiftOut(dataPin, clockPin, MSBFIRST, lightData2);
shiftOut(dataPin, clockPin, MSBFIRST, lightData1);
// turn on the lights according to the new data
digitalWrite(latchPin, HIGH);
notes_bits.h
/*Which bit has to be turned ON or OFF is found
* with the below function.
* The range of music notes used for the control
* of lights is from C3 to E6.
* (sharp notes are excluded) (total 24 lights)
* So, this function will return the number of the bit
* to be set.
* For eg, C3(note 62) corresponds to the first light,
* So this function will return '1'.
* Similarly, '2' is returned for D3(note 64), etc.
int getBit(int p) {
switch(p) {
case 60: return 0; //note C3 (middle C)
case 62: return 1; //D3
case 64: return 2; //E3
case 65: return 3; //F3
case 67: return 4; //G3
case 69: return 5; //A3
case 71: return 6; //B3
case 72: return 7; //C4
case 74: return 8; //D4
case 76: return 9; //E4
case 77: return 10; //F4
case 79: return 11; //G4
case 81: return 12; //A4
case 83: return 13; //B4
case 84: return 14; //C5
case 86: return 15; //D5
case 88: return 16; //E5
case 89: return 17; //F5
case 91: return 18; //G5
case 93: return 19; //A5
case 95: return 20; //B5
case 96: return 21; //C6
case 98: return 22; //D6
case 100: return 23; //E6
Any help is appreciated!
