Reducing Dynamic Memory Usage / Serial Communication
I'm working on a project with 2 arduinos- an Uno connected to a fingerprint scanner and SD reader, which communicates with a Mega controlling a touchscreen LCD. I feel as if I'm running into danger regarding memory, however, as I've already used 75% of the Uno's dynamic memory and I still have a decent amount of programming left to do.
Uno
#include <FPS_GT511C3.h>
#include <SPI.h>
#include <SD.h>
#include <SoftwareSerial.h>
SoftwareSerial mega(6, 7);
FPS_GT511C3 fps(4, 5);
File voterList;
char vFirst[25];
char vLast[25];
char vAge = 10;
char vID[3];
char in = '1';
const byte numChars = 25;
char receivedChars[numChars];
boolean newData = false;
boolean voting = false;
boolean regng = false;
boolean recd = false;
class Profile {
  private:
    char ID[3];
    char first[25];
    char last[25];
    char age = 10;
  public:
    Profile(char ID[3], char first[25], char last[25], char age) {
      this->ID[3] = ID[3];
      this->first[25] = first[25];
      this->last[25] = last[25];
      this->age = age;
    void sdWrite() {
      voterList.write(ID);
      voterList.write(" ");
      voterList.write(first);
      voterList.write("last");
      voterList.write(age);
      voterList.write("\n");
  mega.begin(9600);
  while (!mega) {
  while (!Serial) {
  voterList = SD.open("voterList.txt", FILE_WRITE);
  mega.write('a'); //prompt
  if (mega.available() > 0) {
    in = mega.read();
    if (voting == false && regng == false && in == '1') {
      reg();
      regng = true;
    if (voting == false && regng == false && in == '2') {
      vote();
      voting = true;
    else return;
void reg() {
  mega.write("b");
  while (recd == false) {
      in = mega.read();
      if (in == "r") recd = true;
  recv();
  store(0);
  mega.write("F");
  recv();
  store(1);
  mega.write("L");
  recv();
  store(2);
  mega.write("A");
  recv();
  store(3);
  store(4);
  regng = false;
  recd = false;
void vote() {
  mega.write("c");
void recv() {
    static byte ndx = 0;
    char endMarker = '\n';
    char rc;
    while (mega.available() > 0 || newData == false) {
          rc = mega.read();
          if (rc != endMarker) {
             receivedChars[ndx] = rc;
             ndx++;
             if (ndx >= numChars) {
                ndx = numChars - 1;
           else {
             receivedChars[ndx] = '\0';
             ndx = 0;
             newData = true;
void store(int i) {
  if (newData == true) {
        if (i == 1) strcpy(vFirst, receivedChars);
        if (i == 2) strcpy(vLast, receivedChars);
        if (i == 3) strcpy(vAge, receivedChars);
        if (i == 4) {
          strcpy(receivedChars, enroll());
          if (strlen(receivedChars) == 3) strcpy(vID, receivedChars);
          if (strlen(receivedChars) == 1) {
            strcpy(vID, "00");
            strcat(vID, receivedChars);
          if (strlen(vID) == 2) {
            strcpy(vID, "0");
        Serial.println(receivedChars);
        newData = false;
        regng = false;
        Profile voter = Profile(vID, vFirst, vLast, vAge);
        voter.sdWrite();
char enroll() {
  int enrollid = 0;
  bool usedid = true;
  mega.write("I");
  while (usedid == true) {
    usedid = fps.CheckEnrolled(enrollid);
    if (usedid == true) enrollid++;
  fps.EnrollStart(enrollid);
  mega.write((byte)0); // tell to place finger
  while(fps.IsPressFinger() == false) delay(100);
  bool bret = fps.CaptureFinger(true);
  int iret = 0;
  if (bret != false) {
    mega.write((byte)1); // remove finger
    fps.Enroll1();
    while(fps.IsPressFinger() == true) delay(100);
    mega.write((byte)2); // place finger again
      fps.Enroll2();
        iret = fps.Enroll3();
        if (iret == 0) {
          mega.write((byte)3); // scan succesfull
        else {
          Serial.print("Enrolling Failed with error code:");
          Serial.println(iret);
      else mega.write((byte)4); // failed
  return enrollid;
Mega:
char uno;
char in;
boolean scanning = false;
  Serial1.begin(9600);
void vote() {
  Serial.print("vote");
  if (Serial1.available() > 0) {
    uno = Serial1.read();
    if (uno == 'a') prompt();
    else if (uno == 'b') reg();
    else if (uno == 'c') vote();
void prompt() {
  Serial.println("Enter 1 to register, or 2 to vote.");
  if (Serial.available() > 0) {
     in = Serial.read();
     Serial1.write(in);
void recv() {
    char rc;
    while (Serial.available() > 0 || newData == false) {
          rc = Serial.read();
             ndx++;
                ndx = numChars - 1;
           else {
             ndx = 0;
             newData = true;
   Serial1.write(receivedChars);
void reg() {
  regng = true;
  Serial1.write("r");
  while (regng == true) {
    if (Serial1.available() > 0) uno = Serial1.read();
    if (uno == "F") {
      Serial.print("First Name: ");
      recv();
    if (uno == "L") {
      Serial.print("Last Name: ");
      recv();
    if (uno == "A") {
      Serial.print("Age: ");
      recv();
    if (uno == "I") {
      scanning = true;
      while (scanning == true && Serial1.available() > 0) {
        if (uno == '0') Serial.println("Place finger on the scanner.");
        if (uno == '1') Serial.println("Remove finger.");
        if (uno == '2') Serial.println("Place finger on the scanner again.");
        if (uno == '3') {
          Serial.println("Scan complete!");
          Serial.println("Registration successful.");
          scanning = false;
          regng = false;
        if (uno == '4') {
          Serial.println("Scan unsuccessful.");
          scanning = false;
There are two primary functions of this program- to register a citizen, and then to allow someone to to cast a vote after verifying their identity. So far, only the registering function is complete, which is why I'm slightly concerned about my memory. The mega sketch is using the serial monitor as opposed to the touchscreen as I haven't implemented it yet. The question is, how could I modify or tweak the Uno's sketch to potentially save some space?
You can try:
Serial.println(F("Registration successful."));
Rather than:
You can pass flash-memory based strings to Serial.print() by wrapping them with F(). For example:
Serial.print(F(“Hello World”))
Source: Serial.print() - Arduino Reference
A 3 element array does NOT have a index 3 location.
That is NOT how to copy arrays.
  while (!mega) {
There is absolutely no point in waiting for a software serial instance to start. It started instantly.
  while (!Serial) {
There is no point, on Arduinos that do not have 32U4 chips, for hardware serial instances to start. They start instantly.
    void sdWrite() {
It is a bad idea to assume that you can write() to a file.
The libraries take up a certain amount of space. But only one copy of each function is used. Once you have used print() or println() once then using it 100 times more takes minimal to zero space.
Also, look at https://www.arduino.cc/en/Tutorial/Memory
rtek1000:
You can try:
[/code]
I actually saw this while researching before I posted... This would be nice but I actually don't print anything to the hardware serial with the Uno.
PaulS:
How would I go about it correctly? I only assumed that was correct because I did the same thing in a mock up sketch a few weeks back and it worked-
#include <SPI.h>
#include <SD.h>
File voterList;
char in = '1';
const byte numChars = 32;
boolean inLoop = false;
char vFirst[25];
char vLast[25];
char vAge = 10;
char vID[9];
class Profile {
  private:
    char ID[9];
    char first[25];
    char last[25];
    char age = 10;
  public:
    Profile(char ID[9], char first[25], char last[25], char age) {
      this->ID[9] = ID[9];
      this->age = age;
  while (!Serial) {
  Serial.println("Welcome!");
  Serial.println("Press 1 to register, press 2 to vote.");
    in = Serial.read();
    if (inLoop == false && in == '1') {
      reg();
      inLoop = true;
    else if (inLoop == false && in == '2') {
      vote();
      inLoop = true;
    else return;
void reg() {
  recv();
  store(0);
  recv();
  store(1);
  recv();
  store(2);
  recv();
  store(3);
  Serial.print("ID: ");
  recv();
  store(4);
  inLoop = false;
void vote() {
  Serial.println("void vote()");
  inLoop = false;
void recv() {
    char rc;
          rc = Serial.read();
             ndx++;
                ndx = numChars - 1;
           else {
             receivedChars[ndx] = '\0'; // terminate the string
             ndx = 0;
             newData = true;
void store(int i) {
        if (i == 1) vFirst = receivedChars;
        if (i == 2) vLast = receivedChars;
        if (i == 3) vAge = receivedChars;
        if (i == 4) {
          if (strlen(receivedChars) != 9) {
            Serial.println("ID must be 9 characters in length.");
            newData = false;
            recv();
            store(4);
        else {
            vID = receivedChars;
            newData = false;
            inLoop = false;
       else {
        newData = false;
        inLoop = false;
    Profile *voter = Voter(vID, vFirst, vLast, vAge);
PaulS:
  while (!mega) {
while (!Serial) {
Noted, I wasn't sure if that was necessary or not
PaulS:
what would be the difference between myFile.write() and myFile.print()?[/quote]
That might be for other reasons. E.g. as pointed out by PaulS, you have an 3 element array and writing to element with index 3 writing can result in undefined behaviour.
memcmp() or strcmp().
print() converts the input to a string, and outputs the string one character at a time, using write().
write() outputs, be default, one byte/character.
The difference is irrelevant to the comment I made, though. Just because you tried to open the file does NOT mean that that was successful. If there is no File object created, you should NOT be trying to dereference that object. You must check that there is an object before you try to use it.
void sdWrite() // Functions start in column 1.
{ // Open braces go on their own line
   if(voterList)
#include <SPI.h>
#include <SD.h>
FPS_GT511C3 fps(8, 9);
File voterList;
char vFirst[25];
char vLast[25];
char vAge = 10;
char vID[3];
char in = '1';
class Profile {
  private:
    char ID[3];
    char first[25];
    char last[25];
    char age = 10;
  public:
      this->age = age;
    void sdWrite() {
      if (voterList) {
        voterList.print(ID);
        voterList.print(" ");
        voterList.print(first);
        voterList.print("last");
        voterList.print(age);
        voterList.print("\n");
  mega.begin(9600);
  while (!mega) {
  while (!Serial) {
    in = mega.read();
    Serial.println(in);
      reg();
      regng = true;
      vote();
      voting = true;
    else return;
void reg() {
  mega.write("b");
      in = mega.read();
  recv();
  store(0);
  mega.write("F");
  recv();
  store(1);
  mega.write("L");
  recv();
  store(2);
  mega.write("A");
  recv();
  store(3);
  store(4);
  regng = false;
  recd = false;
void vote() {
  mega.write("c");
void recv() {
    char rc;
          rc = mega.read();
             ndx++;
                ndx = numChars - 1;
           else {
             ndx = 0;
             newData = true;
void store(int i) {
        if (i == 4) {
            strcpy(vID, "00");
            strcpy(vID, "0");
        newData = false;
        regng = false;
        voter.sdWrite();
char enroll() {
  int enrollid = 0;
  bool usedid = true;
  mega.write("I");
  int iret = 0;
    fps.Enroll1();
      fps.Enroll2();
        if (iret == 0) {
        else {
  return enrollid;
char uno;
char in;
void vote() {
void prompt() {
     in = Serial.read();
     Serial1.write(in);
void recv() {
    char rc;
          rc = Serial.read();
             ndx++;
                ndx = numChars - 1;
           else {
             ndx = 0;
             newData = true;
void reg() {
  regng = true;
  Serial1.write("r");
    if (uno == "F") {
      recv();
    if (uno == "L") {
      recv();
    if (uno == "A") {
      recv();
    if (uno == "I") {
      scanning = true;
        if (uno == '3') {
          scanning = false;
          regng = false;
        if (uno == '4') {
          scanning = false;
Here is my code with a few revisions... I didn't want to start a new thread on the same project so I'm going to ask here.
Initially, the Uno sends a character to the MEGA prompting it to ask to enter either a 1 or 2 serially. Upon entering a 1 to the Uno, nothing happens. To troubleshoot I printed out what the Uno was receiving, and it printed 2 backwards '?' symbols. Any idea why that could be?
@paul-
Thank you for that tip, I was unaware
  mega.begin(9600);
  while (!mega) {
mega is an object. It does not overload any operators that while can be using. So, this statement says "while the object we just used doesn't exist...". The object exists. The while loop is pointless.
void prompt() {
     in = Serial.read();
     Serial1.write(in);
This code does NOT wait for the Uno to respond. If there IS serial data available to read at this point that available() is called, it will NOT be the response to that prompt.
Serial data transfer is asynchronous. It looks to me like you are expecting it to be synchronous. If you ARE trying to force serial data transfer into a synchronous pattern, you WILL be using while statements to wait for input.
PaulS:
  mega.begin(9600);
while (!mega) {
What's this then?
class SoftwareSerial : public Stream
public:
  operator bool() { return true; }
The loop is still totally useless.
What's this then?
When was that added?
In 1.6.1 (March 2015).
PaulS:
I sorta developed a system in which one arduino would send a byte to initiate some process, with the other Arduino replying to confirm it and then execute it. I was hoping the manner in which I did that it would keep the two Arduinos in sync throughout the program. Evidently not.
What would be a more proper method to do so? T/F statements mixed with a while loop to make an arduino 'wait' for a serial message? Or make another 2 connections between the arduinos, each sending/receiving pulses and 'waiting' for those pulses to keep in sync?
Additionally, back to the OP- I really do feel as if I won't have enough dynamic storage to complete this program. Does anything else seem redundant catch your guys' eye that could potentially save memory through more efficient syntax?
If you are going to force asynchronous communications into a synchronous mode, then you need to do something like:
   Serial.print("A");
   while(Serial.available() == 0)
      // Just twiddling my thumbs waiting for a response
   // A single character came in. Deal with it...
PaulS:
   Serial.print("A");
What does that ^ do opposed to the code below that would force them into synchronization?
void prompt() {
     in = Serial.read();
     Serial1.write(in);
The first code, as the comment says, twiddles its thumbs waiting for serial data.
The second code does NOT wait for data. It simply reads anything that might be available, or returns if there is nothing available.
The second code is NOT synchronous.
if (uno == "F") {
uno is declared as a char. But double quotes (") means "string". There is no char which is equal to the location of the first char in the string "F".
Use single quotes (') for char. This mistake appears several times.
PaulS:
Ah, I see- So anything regarding interpreting an input should be after the while() loop?
MorganS:
Just out of curiosity what happens as a result of that? Is Arduino able to convert the string to a char? Or is that something that causes broken data being sent? Good eye, thank you!
It's not able to convert because you told it not to. You specified that "F" is a string. If you told somebody to turn left and he went right, how are you going to tell them to turn right at the next street? Do you say "right" or "left"?
When you do Serial.write("A"); then it's going to send something related to the address of the string "A" in memory. It won't send an "A". However Serial.print("A"); does understand strings and will send the single character 'A'. Write is used for binary data. Print is best for human-readable text.
write(7) will send the bit pattern 00000111. Binary 7.
print(7, BIN) will send "111" because it does not print leading zeroes. That's three '1' characters in three bytes.
write('7') and print('7') and print("7") will all send the same thing: '7', which is encoded with the bit pattern 00110111 under the ASCII system.
MorganS:
This just explained a lot for me- thank you so much!
