I have a sketch running on a Nano that controls a sound module & syncs an LED to flash with the sound. I can activate it in 2 ways.
- pressing a button the sketch plays only one sound and flashes the LED, no loop
- pressing 1 on the remote control the sketch plays random sounds and flashes the LED & loops until i press 1 on the remote control
This is the working sketch
[code]
==================================== BB-8 PADAWAN DOME ============================================
====================================== Version 0.07 =============================================
Version History
0.01 - Original Sketch by DavidScott
0.02 - r0n_dL added annotations & variable for PIN_sound_BUSY as suggested by DavidScott
0.03 - r0n_dL reassigned pins to align with Padawan control system
- Changed SoftwareSerial pins (RX/TX) 10/9 to 8/4
0.04 - Change pinMode for PIN_trigger to INPUT_PULLUP to resolve issue using with Pro Micro
0.05 - Added support for the BY8301-16P and BY8001-16P sound modules
0.06 - Using an updated version of MP3FLASH16P (MP3Flash16Pv2) which now removes static serial
mappings out of the .cpp file
- Add support to select between using 3 different sound modules by changing 1 variable
0.07 - Changed hard coded serial port in library
r0n_dL IMPORTANT NOTE & RECOGNITON: This sketch was written by DavidScott. Thanks for a great base!
// DavidScott's original comment below
// This example plays a random file (001 to 010) forever
// It uses the playFileAndWait() command so no extra code is needed, it will play another file as soon as
// the previous one finishes. If it doesn't work, try reversing the RX/TX wires as that's probably going to be
// the most common mistake. Also check that the player's BUSY line is connected to Arduino pin 3
// Finally check that the player has a speaker connected as well as ground and VCC
r0n_dL NOTES: Basic sketch provided by DavidScott to give sounds and synchronized voice lights for
scale BB-8 Domes
REQUIRED Libaries to make this sketch work:
MP3Flash16Pv2 Library
https://github.com/r0ndL/MP3Flash16Pv2
BY8x0116P Library
https://github.com/r0ndL/BY8x0116Pv2
r0n_dL PARTS USED
1 Arduino Pro Micro
1 MP3-FLASH-16P MP3 Soundboard
1 Red 3mm Flanged LED (Radar Eye)*
1 Blue 3mm Flanged LED (Side Logic Display)*
1 White 3mm Flanged LED (Top Front Logic Display)*
1 White 5mm Flanged LED (PSI/Voice LED)*
1 5v power supply
2 1K ohm Resistors*
2 220 ohm Resistors*
1 56 ohm Resistor*
1 Switch - local or remote
There are actually MORE LEDs required if using BB-8 Club spec (as of 4 Jan 16 T&M beta v033) pg 42
If using additional LEDs, more resistors and/or different value resistors will be required.
May want to consider adding a LED to the HP as well which will also require changes to the resistor
& wiring
Example: 2 Front (Top & Bottom) Logic Lenses have 5 round 3mm LEDs each
1 Side Logic Lens has 4 round 3mm LEDs
r0n_dL BASIC WIRING for testing
Switch | 5v Power | Pro Micro | MP3-FLASH-16P | Speaker | LEDs
| POS | VCC | VCC | | + (3mm Red)- +(3mm Blue) 56 R
1 | NEG | GND | GND | | GND all LEDs
| | 3 | BUSY | |
| | 9 | | | + (3mm Wht 220 R)
| | 8*(1K R) | TX | |
| | 4 (1K R) | RX | |
| | 6 | | | + (5mm Wht 220 R)
| | A2 | SPK1 | + |
| | | SPK2 | - |
2 | | A3 | | |
NOTE: 3mm Red LED and 3mm Blue LED wired in series with 56 ohm Resistor
MP3 TX to Pin 8 not required. Do not use pin 8 for anything else
RESERVED DO NOT USE
8 (Analog) - RX (SoftwareSerial)
FREE PINS on Arduino
TX1
RX0
2
5
7
10
16
14
15
A0
A1
// SET AUDIO OPTIONS...
// NOTE: This sketch currently supports 3 different sound modules (MP3-FLASH-16P, BY8001-16P, BY8301-16P)
#define AUDIO1 2 // 1=MP3-FLASH-16P
// 2=BY8001-16P or BY8301-16P
// INCLUDE LIBS AND DECLARE VARIABLES...
#include <IRremote.h>
int RECV_PIN = 11; // the pin where you connect the output pin of sensor
int PIN_trigger = 3;
int itsONled[] = {0, 1};
/* the initial state of LEDs is OFF (zero)
the first zero must remain zero but you can
change the others to 1's if you want a certain
led to light when the board is powered */
#define code1 16724175 // code received from button no. 1
IRrecv irrecv(RECV_PIN);
decode_results results;
#include "SoftwareSerial.h"
SoftwareSerial MP3Serial(8, 4); // SoftwareSerial port assignments (RX, TX) to communicate with sound module
#if (AUDIO1==2)
//settings for BY8001-16P or BY8301-16P module...
#include "BY8x0116Pv2.h"
BY8x0116Pv2 myPlayer(MP3Serial); // Use SoftwareSerial as the serial port
#else
//settings for MP3-FLASH-16P...
#include "MP3Flash16Pv2.h"
MP3Flash16Pv2 myPlayer(MP3Serial); // Use SoftwareSerial as the serial port
#endif
// ARDUINO PIN ASSIGNMENTS...
// Default Pin Assignments - BASIC WIRING in NOTES
#define PIN_sound_BUSY 3 //Connect to BUSY pin on sound module
#define PIN_pulse_LED 9 //Logic LED - 3mm White & 220 Ohm Resistor
#define PIN_voice_LED 6 //Voice LED - 5mm White & 220 Ohm Resistor
#define PIN_sound A2 //Speaker lead for sound & LED sync
#define PIN_trigger A3 //Connect to Switch
// ADDITIONAL SOUND OPTIONS...
#define number_of_sounds 19
Serial.begin(9600); // you can ommit this line
irrecv.enableIRIn(); // Start the receiver
pinMode(PIN_trigger, OUTPUT);
MP3Serial.begin(9600);
myPlayer.init(PIN_sound_BUSY); // Init the player with the MP3 BUSY pin connected to Arduino pin defined
pinMode(PIN_voice_LED, OUTPUT);
pinMode(PIN_pulse_LED, OUTPUT);
pinMode(PIN_sound, INPUT);
pinMode(PIN_trigger, INPUT_PULLUP); // Changed INPUT to INPUT_PULLUP because of issues working with Pro Micro.
// Change back to INPUT if required
randomSeed(analogRead(0));
int voiceBrightness;
int pulseBrightness;
// Checking for trigger going LOW
if (digitalRead(PIN_trigger) == LOW) {
if (!myPlayer.isBusy()) {
myPlayer.playFile(random(1, number_of_sounds + 1));
delay(100);
// Voice light
if (myPlayer.isBusy()) {
// Sets the brightness of the light based on the loudness of the voice
voiceBrightness = constrain(map(analogRead(PIN_sound), 700, 1024, 0, 255), 0, 255);
analogWrite(PIN_voice_LED, voiceBrightness);
// No voice playing, light is off
analogWrite(PIN_voice_LED, 0);
// Slow pulsing light on the side of BB-8's head
pulseBrightness = 130 + (sin(millis() / 1200.00) * 120);
analogWrite(PIN_pulse_LED, pulseBrightness);
if (irrecv.decode(&results)) {
unsigned int value = results.value;
switch (value) {
case code1:
if (itsONled[1] == 1) { // if first led is on then
digitalWrite(PIN_trigger, LOW); // turn it off when button is pressed
itsONled[1] = 0; // and set its state as off
} else { // else if first led is off
digitalWrite(PIN_trigger, HIGH); // turn it on when the button is pressed
itsONled[1] = 1; // and set its state as on
Serial.println(value); // you can ommit this line
irrecv.resume(); // Receive the next value
[/code]
When I press the button to activate the sketch it works instantly, when I press 1 on the remote control it takes almost 9 seconds for the sketch to activate.
I’m using IRremote.h for the remote control & following the instructions in the IRremote sketch I tried to define which decoder to use as this is supposed to reduce the activation time as it's not checking every decoder, just the one specified.
I added “#define DECODE_NEC” into the sketch before “#include <IRremote.h>” but when i did that the sketch won't compile
This is the error message
Arduino: 1.8.15 (Windows Store 1.8.49.0) (Windows 10), Board: "Arduino Nano, ATmega328P"
C:\Users\natha_000\Documents\Arduino\BB8-Basic-Lights-Sound-DavidScott-Nathan_IR\BB8-Basic-Lights-Sound-DavidScott-Nathan_IR.ino: In function 'void loop()':
C:\Users\natha_000\Documents\Arduino\BB8-Basic-Lights-Sound-DavidScott-Nathan_IR\BB8-Basic-Lights-Sound-DavidScott-Nathan_IR.ino:210:29: warning: 'bool IRrecv::decode(decode_results*)' is deprecated: Please use IrReceiver.decode() without a parameter and IrReceiver.decodedIRData.<fieldname> . [-Wdeprecated-declarations]
In file included from C:\Users\natha_000\Documents\Arduino\libraries\IRremote\src/IRremote.h:188:0,
from C:\Users\natha_000\Documents\Arduino\BB8-Basic-Lights-Sound-DavidScott-Nathan_IR\BB8-Basic-Lights-Sound-DavidScott-Nathan_IR.ino:109:
C:\Users\natha_000\Documents\Arduino\libraries\IRremote\src/IRReceive.cpp.h:1373:6: note: declared here
bool IRrecv::decode(decode_results *aResults) {
C:\Users\natha_000\Documents\Arduino\BB8-Basic-Lights-Sound-DavidScott-Nathan_IR\BB8-Basic-Lights-Sound-DavidScott-Nathan_IR.ino:213:7: warning: large integer implicitly truncated to unsigned type [-Woverflow]
case code1:
C:\Users\natha_000\AppData\Local\Temp\cc4xyzL3.ltrans0.ltrans.o: In function `decode':
C:\Users\natha_000\Documents\Arduino\libraries\IRremote\src/IRReceive.cpp.h:1486: undefined reference to `IRrecv::decodeHashOld(decode_results*)'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino Nano.
option enabled in File -> Preferences.
Have i misunderstood how to include the “#define DECODE_NEC” or have i missed something else out in my Sketch, or is it just a limitation of using IRremote.h with a Nano?
I've also attached my wiring diagram incase that is causing delay
