Hello,
I am working on a flight computer for an upcoming weather balloon project. I have run out of space on the Arduino nano that is on my PCB. Is there anyway to change some of my code to reduce the size or change my libraries and reduce the size that way.
-Liam
//Kermputer Code written by Liam and Frank . Flight computer designed by Liam
//Written for use on a Kermputer Board (Can be easily modified for a kermini) and the arduino NANO platform
//I really hope this works
//Notes/Progress: right now the bmp280 and gps are working together but gps does not happen everytime so sometimes get more temperature recrodings then gps log
//now not working woht the adding lines of priting the speed to the oled
//VERSION: 1.0
//Libraries
#include <SPI.h> //SPI Library
#include <Wire.h> //Wire Library
#include <Adafruit_GFX.h> //Graphics Library
#include <Adafruit_SSD1306.h> //OLED Library
#include <Adafruit_BMP280.h>
#include <TinyGPS++.h> //Library for GPS
#include <SoftwareSerial.h> //Library to communicate with sensors
#include <MPU6050_light.h> //Gyro Library
//Other Stuff (Before Void Setup)
// For OLED:
#define OLED_RESET 5 //Oled reset pin is 5
Adafruit_SSD1306 display(OLED_RESET); //Reset the display
// For GPS:
TinyGPSPlus gps; //create an object called gps that can be called on
int RXPin = 4; //Set the rx pin to be pin 4 (WORKS ON THIS ONE DO NOT CHANGE)
int TXPin = 3; //Set the tx pin to be pin 3 (WORKS ON THIS ONE DO NOT CHNAGE)
int GPSBaud = 9600;
SoftwareSerial ss(RXPin, TXPin); //Start listening on the TX (Transmitting) and RX (Reciving pins)
double newMaxHeight = 0;
double newMaxSpeed = 0;
// For MPU-6050 Gyro
MPU6050 mpu(Wire);
int timer = 0;
//For BMP280
Adafruit_BMP280 bmp; // use I2C interface
Adafruit_Sensor *bmp_temp = bmp.getTemperatureSensor();
Adafruit_Sensor *bmp_pressure = bmp.getPressureSensor();
double temperatureC;
Serial.begin(9600); // RUNS 9600 SO SEE IF IT OKAY. HAS TO BE ONE OR THE OTHER. SHOULD BE OKAY KEEP TESTING
Serial.println("Kermputer Start");
//Void Setup for OLED
display.begin(SSD1306_SWITCHCAPVCC, 0x3C); // initialize with the I2C addr 0x3C, telling program where to find it
delay(100); //wait .1 seconds
display.clearDisplay(); //clear the oled screen
display.display();
//Void Setup for GPS
ss.begin(GPSBaud); //Software serial at 9600. gps using that baud rate that we set earlier (9600 baud rate)
//Void Setup for MPU-6050
Wire.begin();
byte status = mpu.begin();
Serial.print(F("MPU6050 status: "));
Serial.println(status);
while (status != 0) { } // stop everything if could not connect to MPU6050
Serial.println(F("Calculating offsets, do not move MPU6050"));
mpu.calcOffsets(); // gyro and accelero
Serial.println("Done!\n");
//Void Setup for BMP280
Serial.println(F("BMP280 Sensor event test"));
if (!bmp.begin()) {
Serial.println(F("Could not find a valid BMP280 sensor, check wiring or try a different address!"));
while (1) delay(10);
bmp.setSampling(Adafruit_BMP280::MODE_NORMAL, /* Operating Mode. */
Adafruit_BMP280::SAMPLING_X2, /* Temp. oversampling */
Adafruit_BMP280::SAMPLING_X16, /* Pressure oversampling */
Adafruit_BMP280::FILTER_X16, /* Filtering. */
Adafruit_BMP280::STANDBY_MS_500); /* Standby time. */
bmp_temp->printSensorDetails();
mpu6050Routine();
gpsRoutine();
bmp280Routine();
oledDisplay(); //this should really be last since it is being called on after the others. needs their data to print
void oledDisplay(){
display.setTextSize(1);
display.setCursor(0,0);
display.setTextColor(WHITE);
display.print("ALT =");
display.print(gps.altitude.feet());
display.println();
display.print("Satellites Lock=");
display.println(gps.satellites.value());
display.print("Temp=");
display.println(temperatureC);
display.display();//Finally display the created image
void gpsRoutine(){ //gps takes about 2 minutes of waiting before it gets a lock and will then flash red when ready
while (ss.available() > 0){
gps.encode(ss.read());
if (gps.location.isUpdated()){ //while the gps location is updated
Serial.println(" ");
Serial.print("Date= ");
Serial.println(gps.date.value()); // Raw date in DDMMYY format (u32)
Serial.println(gps.time.value()); // Raw time in HHMMSSCC format (u32)
Serial.print("Latitude= ");
Serial.print(gps.location.lat(), 3);
Serial.print(" Longitude= ");
Serial.println(gps.location.lng(), 3);
Serial.print("Speed (MPH)= ");
Serial.println(gps.course.deg()); // Course in degrees (double)
Serial.print("Heading (Degrees)= ");
Serial.println(gps.speed.mph()); // Speed in miles per hour (double)
Serial.print("Altitude= ");
Serial.println(gps.altitude.feet()); // Altitude in feet (double)
Serial.print("Satellites= ");
Serial.println(gps.satellites.value()); // Number of satellites in use (u32)
Serial.println("");
if(gps.altitude.feet() > newMaxHeight){
newMaxHeight = gps.altitude.feet();
Serial.print("New Max Height: ");
Serial.println(newMaxHeight);
if(gps.speed.mph() > newMaxSpeed){
newMaxSpeed = gps.speed.mph();
Serial.print("New Max Speed: ");
Serial.println(newMaxSpeed);
void bmp280Routine(){
Serial.print("Temperature: ");
Serial.println(bmp.readTemperature());
Serial.print("Pressure: ");
Serial.println(bmp.readPressure()/100000);
Serial.println("");
temperatureC = bmp.readTemperature();
void mpu6050Routine(){
mpu.update();
if ((millis() - timer) > 10) { // print data every 10ms
Serial.print("Pitch: ");
Serial.print(mpu.getAngleX());
Serial.print("\tTilt: ");
Serial.print(mpu.getAngleY());
Serial.print("\tRoll: ");
Serial.println(mpu.getAngleZ());
timer = millis();
