Hey all, I am having a bit of a hard time wrapping my head around replacing code for individual input_pullup switches with switches being used via ADC
I'm using a 1602 LCD keypad shield with an Arduino Mega2560
previously I had written the code for the inputs as
pinMode(Mode1Pin, INPUT_PULLUP);
pinMode(Mode2Pin, INPUT_PULLUP);
pinMode(Mode3Pin, INPUT_PULLUP);
pinMode(Mode4Pin, INPUT_PULLUP);
pinMode(Mode5Pin, INPUT_PULLUP);
const int Mode1Pin = 9; // Menu next
const int Mode2Pin = 10; // Menu Prev
const int Mode3Pin = 11; // Menu select
const int Mode4Pin = 12; // Retard button
const int Mode5Pin = 13; // Boost button
void checkrunmode(){
int m1;
int m2;
int m3;
int m4;
int m5;
m1 = digitalRead(Mode1Pin);
m2 = digitalRead(Mode2Pin);
m3 = digitalRead(Mode3Pin);
m4 = digitalRead(Mode4Pin);
m5 = digitalRead(Mode5Pin);
// Reset ModeChangeDelay status if all swicthes are off (debounce switch)
if ((m1 != LOW) && (m2 != LOW) && (m3 != LOW)) {
ModeChangeDelay = false;
if (!ModeChangeDelay) {
// switch 1 pushed - Next menu
if ((m1 == LOW)) {
if (MenuChangeDelay >= millis()) {
MenuSelect = MenuSelect + 1;
CharDelay = millis() + CharDelayTime;
if(MenuSelect > MaxMenuSelect) {
MenuSelect = 1;
}else{
MenuCount = 0;
MenuCount += 1;
MenuChangeDelay = millis() + MenuChangeDelayTime;
ModeChangeDelay = true;
if (MenuCount > 1) { // a bit of code to avoid sending unneeded chars to LCD
MenuChar = 6;
}else{
MenuChar = 0;
MenuCharOld = 0;
// switch 2 pushed - Prev menu
if ((m2 == LOW)) {
MenuSelect = MenuSelect - 1;
if(MenuSelect < 1) {
MenuSelect = MaxMenuSelect;
}else{
MenuCount = 0;
MenuCount += 1;
MenuChar = 6;
}else{
MenuChar = 0;
MenuCharOld = 0;
// switch 3 pushed - Select
if ((m3 == LOW)) {
DoMenuSelect = true;
MenuChangeDelay = 0;
}else{
MenuCount = 0;
MenuChar = 0;
MenuCharOld = 0;
// switch 4 pushed - Boost
if ((m4 == LOW)) {
UseRetard = true;
DelayRdn = ! DelayRdn; // toggle delay
// switch 5 pushed - Idle
if ((m5 == LOW)) {
UseBoost = true;
I have read example code showing how to read the values from the ADC but it's just not clicking on how to adjust my code for the analog switches
Eg.
int x;
x = analogRead (0);
lcd.setCursor(10,1);
if (x < 60) {
lcd.print ("Right ");
else if (x < 200) {
lcd.print ("Up ");
else if (x < 400){
lcd.print ("Down ");
else if (x < 600){
lcd.print ("Left ");
else if (x < 800){
LCD.print ("Select");
