Reducing payload size of nRF to achieve optimum range
I have read online that reducing the payload size of the message can dramatically increase range.
My question is what is the lowest amount of bytes I can send? And let's say I set it to 4 bytes -- my message cannot exceed 4 characters?
I read it here
I reckon you need to do your own tests, just like the guy in your link.
If you are using the ackPayload feature then dynamic payload size is automatically applied.
I have had a pair of low-power nRF24L01+ modules (with PCB antennas like the black one in the pictures in the link) working reliably at 110 metres range outdoors.
I can't immediately see how payload size matters, unless with a smaller payload there is less scope for errors.
...R
JeromeAriola:
I am all for real world testing, but if reducing the size of a packet does increase range 'dramatically' there is something wrong with the modules.
If errors caused by noise etc are random then its true that at the limit of reception a long packet is more likely to suffer errors.
However due to the headers and trailers that are often added to the data portion of the packet, if you split a large packet into smaller ones, you will increase the overall amount of data sent (as there are more headers and trailers) and thus increase, not reduce, the chances of errors.
