Reducing PWM motor noise
Hi there!
When Im driving a fan via a BC639 on PWM it works just fine but on lower analogWrites the fan gets quite noisy.
Are there any techniques to reduce this noise on lower speeds at least a bit?
Thank you very much!
Use a higher frequency of PWM? Checkout things like the TimerOne library for convenient functions to help with this, or read the datasheet chapters on the timers.
Had a similar problem with THIS PROJECT.
The code is there so you can see the approach I took.
Bob.
