I am making a timer that is programmed with the sunrise/sunset times for my city and I am making Arduino use a relay to control some mains lighting. I am using a chronodot to keep time. I have it working, the only problem is that it is too large. My programming skills are basic and I'm sure there is a better way to do this. Below is my code. The current size is 41000 bytes and I need to put it on a Duemilanove so down to 32000 bytes (I think).
#include <Wire.h>
#include "Chronodot.h"
Chronodot RTC;
int LightOff[367] = {0, 930, 930, 930, 929, 929, 929, 928, 928, 927, 927, 926, 925, 925, 924, 923, 922, 921, 20, 919, 918, 917, 916, 915, 913, 912, 911, 909, 908, 906, 905, 903, 902, 900, 859, 857, 855, 854, 852, 850, 848, 846, 845, 843, 841, 839, 837, 835, 833, 831, 829, 827, 825, 823, 820, 818, 816, 814, 812, 810, 809, 808, 805, 803, 801, 759, 756, 754, 752, 750, 747, 745, 743, 741, 738, 736, 734, 731, 729, 727, 724, 722, 720, 717, 715, 713, 710, 708, 706, 703, 701, 659, 656, 654, 652, 650, 647, 645, 643, 640, 638, 636, 634, 631, 629, 627, 625, 623, 620, 618, 616, 614, 612, 610, 608, 607, 606, 601, 559, 557, 555, 553, 552, 550, 548, 546, 544, 542, 540, 539, 537, 535, 534, 532, 530, 529, 527, 526, 524, 523, 521, 520, 519, 517, 516, 515, 514, 513, 512, 510, 509, 509, 508, 507, 506, 505, 505, 504, 503, 503, 502, 502, 501, 501, 501, 500, 500, 500, 500, 500, 500, 500, 500, 500, 501, 501, 501, 502, 502, 503, 503, 504, 504, 505, 506, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 519, 520, 521, 522, 524, 525, 526, 528, 529, 530, 532, 533, 535, 536, 538, 539, 541, 542, 544, 546, 547, 549, 550, 552, 553, 555, 557, 558, 600, 602, 603, 605, 606, 608, 610, 611, 613, 615, 616, 618, 619, 621, 623, 624, 626, 628, 629, 631, 633, 634, 636, 638, 639, 641, 642, 644, 646, 647, 649, 651, 652, 654, 656, 657, 659, 700, 702, 704, 705, 707, 709, 710, 712, 714, 715, 717, 719, 720, 722, 724, 725, 727, 729, 730, 732, 734, 736, 737, 739, 741, 742, 744, 746, 748, 749, 751, 753, 755, 757, 758, 800, 802, 804, 805, 807, 809, 811, 813, 815, 816, 818, 820, 822, 824, 825, 827, 829, 831, 833, 834, 836, 838, 840, 841, 843, 845, 847, 848, 850, 852, 853, 855, 857, 858, 900, 901, 903, 904, 906, 907, 909, 910, 912, 913, 914, 915, 916, 918, 919, 920, 921, 922, 923, 924, 924, 925, 926, 927, 927, 928, 928, 929, 929, 929, 930, 930, 930, 930, 930, 930};
int LightOn[367] ={0, 1650, 1651, 1652, 1653, 1654, 1656, 1657, 1658, 1700, 1701, 1703, 1704, 1706, 1707, 1709, 1710, 1712, 1714, 1715, 1717, 1719, 1721, 1722, 1724, 1726, 1728, 1729, 1731, 1733, 1735, 1737, 1739, 1740, 1742, 1744, 1746, 1748, 1750, 1752, 1754, 1755, 1757, 1759, 1801, 1803, 1805, 1807, 1809, 1810, 1812, 1814, 1816, 1818, 1820, 1822, 1823, 1825, 1827, 1829, 1830, 1831, 1832, 1834, 1836, 1838, 1840, 1841, 1843, 1845, 1847, 1849, 1850, 1852, 1854, 1856, 1857, 1859, 1901, 1903, 1904, 1906, 1908, 1910, 1911, 1913, 1915, 1916, 1918, 1920, 1922, 1923, 1925, 1927, 1929, 1930, 1932, 1934, 1935, 1937, 1939, 1941, 1942, 1944, 1946, 1947, 1949, 1951, 1953, 1954, 1956, 1958, 1959, 2001, 2003, 2005, 2006, 2008, 2010, 2011, 2013, 2015, 2016, 2018, 2020, 2021, 2023, 2025, 2026, 2028, 2030, 2031, 2033, 2035, 2036, 2038, 2039, 2041, 2042, 2044, 2045, 2047, 2048, 2050, 2051, 2052, 2054, 2055, 2056, 2057, 2059, 2100, 2101, 2102, 2103, 2104, 2105, 2106, 2107, 2108, 2109, 2110, 2111, 2111, 2112, 2113, 2113, 2114, 2114, 2115, 2115, 2115, 2116, 2116, 2116, 2116, 2116, 2116, 2116, 2116, 2116, 2116, 2115, 2115, 2115, 2114, 2114, 2113, 2113, 2112, 2111, 2111, 2110, 2109, 2108, 2107, 2106, 2105, 2104, 2103, 2102, 2101, 2100, 2058, 2057, 2056, 2054, 2053, 2051, 2050, 2048, 2047, 2045, 2044, 2042, 2040, 2038, 2037, 2035, 2033, 2031, 2029, 2028, 2026, 2024, 2022, 2020, 2018, 2016, 2014, 2012, 2010, 2007, 2005, 2003, 2001, 1959, 1957, 1955, 1952, 1950, 1948, 1946, 1943, 1941, 1939, 1937, 1934, 1932, 1930, 1927, 1925, 1923, 1921, 1918, 1916, 1914, 1911, 1909, 1906, 1904, 1902, 1859, 1857, 1855, 1852, 1850, 1847, 1845, 1843, 1841, 1838, 1836, 1834, 1831, 1829, 1827, 1824, 1822, 1820, 1818, 1815, 1813, 1811, 1808, 1806, 1804, 1802, 1800, 1758, 1755, 1753, 1751, 1749, 1747, 1745, 1742, 1740, 1738, 1736, 1734, 1732, 1730, 1728, 1727, 1725, 1723, 1721, 1719, 1717, 1716, 1714, 1712, 1711, 1709, 1707, 1706, 1704, 1703, 1701, 1700, 1658, 1657, 1656, 1654, 1653, 1652, 1651, 1650, 1649, 1648, 1647, 1646, 1645, 1644, 1644, 1643, 1642, 1642, 1641, 1641, 1640, 1640, 1640, 1639, 1639, 1639, 1639, 1639, 1639, 1639, 1639, 1640, 1640, 1640, 1641, 1641, 1642, 1642, 1643, 1643, 1644, 1645, 1646, 1647, 1648, 1649};
int Relay = 7; // Relay on Pin 7
int DayCode = 0;
int Year = 0;
int Month = 0;
int Day = 0;
int Hour = 0;
int Minute = 0;
int Second = 0;
int Multiplier = 0;
int Time = 0;
pinMode(Relay, OUTPUT);
Wire.begin();
RTC.begin();
DateTime now = RTC.now(); // Retrieve all information from ChronoDot
Year = now.year();
Month = now.month();
Day = now.day();
Hour = now.hour();
Minute = now.minute();
Second = now.second();
if (Month == 1) { //Create the multiplier which is added to the day to obtain the date code
Multiplier = 0; }
if (Month == 2) {
Multiplier = 31; }
if (Month == 3) {
Multiplier = 60; }
if (Month == 4) {
Multiplier = 91; }
if (Month == 5) {
Multiplier = 121; }
if (Month == 6) {
Multiplier = 152; }
if (Month == 7) {
Multiplier = 182; }
if (Month == 8) {
Multiplier = 213; }
if (Month == 9) {
Multiplier = 244; }
if (Month == 10) {
Multiplier = 274; }
if (Month == 11) {
Multiplier = 305; }
if (Month == 12) {
Multiplier = 335; }
DayCode = Multiplier + Day; // Determine what day it is
Time = Hour*100 + Minute;
// Perform Calculations to turn relay on/off
if (DayCode == 1) {
if (Time == LightOff[DayCode]) {
digitalWrite(Relay, LOW); }
if (Time == LightOn[DayCode]) {
digitalWrite(Relay, HIGH); }
if (DayCode == 2) {
etc for the rest of the days
I know I need to parse down my hundreds of if statements but am unsure on what statement to use.
Thanks for helping a first time Arduino user,
Spencer
