Currently my sketch is on 111% of dynamic memory and so won’t upload. Any suggestions on how to reduce this. I am using this with an arduino nano and the project is a speedcoach
Thanks Tom
#include <SPI.h>
#include <SandTimer.h>
#include <millisDelay.h>
#include <Adafruit_GPS.h> //Libraries
#define GPSSerial Serial
Adafruit_GPS GPS(&GPSSerial);
SandTimer timer1;
#define GPSECHO false
#include <Arduino.h>
#include <U8g2lib.h>
#ifdef U8X8_HAVE_HW_SPI
#endif
#ifdef U8X8_HAVE_HW_I2C
#include <Wire.h>
#endif
U8G2_SSD1309_128X64_NONAME0_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
uint32_t timer = millis();
const int chipSelect = 4;
float ms = 0; //Meters/Second variable
float avems = 0; //Average M/S variable
float mscounter = 0; //Speed total (for average)
int integcounter = 0; //Counts half-seconds
float meterstraveled = 0; //Total meters
int splittotal = 0; //Split total (in seconds) (Essential to be an integer)
int splitseconds = 0; //Seconds on split display (Essential to be an integer)
int splitminutes = 0; //Minutes on split display (Essential to be an integer)
int seconds = 0;
int minutes = 0;
int hours = 0; //Self-explanatory (for timers)
int splitaveragetotal = 0; //All split seconds added together (for average split)
int splitaverageseconds = 0; //Split average seconds
int splitaverageminutes = 0; //Split average minutes
int splitaverage = 0; //Split average
int splitaveragesecondsdisp = 0; //Display variables, fixes a bug
int splitaverageminutesdisp = 0;
float splitmdisp = 0;
float splitsdisp = 0; //Display Variables
int tc = 0; //Counter variable
int dp = 0; //Data-point variable
int dpave = 0; //Average of the data-points
int dprec = 0; //Counter variable
float knot = 0;//Speed in knots recorded from GPS
float aveknots = 0; //Speed in knots averaged over 1/2 second (equal to 1 data point and 5 knot readings)
int knotcounter = 0; //Counter variable
int sensorValue = analogRead(A3); //For the data write switch
float msfm = 0; //M/S for the meters calculation
millisDelay secdelay; //Timing delay (for timer)
float voltage = sensorValue * (5.0 / 1023.0); //Converts A3 reading into a 5v equivalent
Wire.begin();
Wire.setClock(400000L);
GPS.begin(9600);
GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);
GPS.sendCommand(PGCMD_ANTENNA);
delay(1000); //GPS initialization
u8g2.begin();
GPSSerial.println(PMTK_Q_RELEASE);
int realhours = GPS.hour - 8;
if(realhours < 0) {realhours = realhours+24;} //For SD timestamp (24 hour format)
const char s[] PROGMEM = "Progmem";
const char s1[] PROGMEM = "ABC" ;
const char s2[] PROGMEM = "DEF" ;
const char s3[] PROGMEM = "GHI" ;
const char s4[] PROGMEM = "SMT" ;
const char *a[] = { s1, s2, s3, s4 };
if (secdelay.justFinished()) {seconds++; secdelay.repeat();} //Checks if 1 second has passed, updates seconds variable
if (seconds == 60) {seconds = 0; minutes++;} //Checks if 60 seconds have passed, resets seconds, increases minutes
if (minutes == 60) {minutes = 0; hours++;} //Checks if 60 minutes have passed, resets minutes, increases hours
char c = GPS.read();
if (GPSECHO)
if (c) Serial.print(c);
if (GPS.newNMEAreceived()) {
Serial.println(GPS.lastNMEA());
if (!GPS.parse(GPS.lastNMEA())); //Serial GPS info for debugging
if (timer > millis()) timer = millis(); //Restarts main timer
if (timer1.finished()) {knot = knot+GPS.speed; knotcounter++;
timer1.startOver();}
if (millis() - timer > 500) { //Runs every half-second (responsible for screen-flicker)
timer = millis(); // Resets timer
if (GPS.fix) {
aveknots = knot/knotcounter;
Serial.println(aveknots);
ms = (aveknots*0.5144444); //Converts knots to meters/second
Serial.println(ms);
knot = 0;
tc = 0;
knotcounter = 0;
aveknots = 0;
if (ms <= 0.75) {u8g2.clearBuffer(); // clear the internal memory
u8g2.setFont(u8g2_font_courR08_tr); // choose a suitable font
u8g2.drawStr(0,10,"Error: IDLE"); // write something to the internal memory
u8g2.drawStr(1,10,"Battery: ");
u8g2.setCursor(1,80);
u8g2.drawStr(2,10,"Meters:");
u8g2.setCursor(2,80);
u8g2.print(meterstraveled);
u8g2.sendBuffer(); // transfer internal memory to the display
if (ms > 0.75)
msfm = ms;
mscounter = (mscounter+msfm); //Continually adds speed to total (for averages)
integcounter = (integcounter+1); //Adds +1 to variable every half second (for averages)
avems = mscounter/integcounter; //Generates average meters/second (for total)
meterstraveled = avems*(integcounter/2); //Calculates total (meters/second divided by seconds)
meterstraveled = round(meterstraveled);
splittotal = 500/(ms); //Generates seconds per 500m
dp = dp + splittotal; //Adds data-points for dpave variable
dprec++;
if (dprec >= 6) {dpave = dp/6; //Calculates average
dprec = 0;
dp = 0; //Resets data-points and counter variable
splitminutes = dpave/60; //Generates split minutes from split seconds
splitseconds = dpave - (splitminutes*60); //Displays remaining seconds
splitaveragetotal = splitaveragetotal+splittotal; //All split times (in seconds) added together
splitaverage = splitaveragetotal/(integcounter); //Averages out split times w/ seconds
splitaverageminutes = splitaverage/60; //Calculates split minutes
splitaverageseconds = splitaverage-splitaverageminutes*60; //Calculates split seconds
splitaverageminutesdisp = splitaverageminutes;
splitaveragesecondsdisp = splitaverageseconds;
splitmdisp = splitminutes;
splitsdisp = splitseconds; //Display variables
u8g2.setFont(u8g2_font_courR08_tr); // choose a suitable font --------------------CHANGE THIS FONT TO SOMETHING LARGER
u8g2.drawStr(0,10,"M:");
u8g2.setCursor(0, 25);
u8g2.drawStr(1,10,"S:");
u8g2.setCursor(1, 25);
u8g2.print(splitmdisp);
u8g2.drawStr(1,50,":");
u8g2.setCursor(1, 75);
u8g2.print(splitsdisp); //adjust pixels to get a good display
