Redundant calls to digitalWrite()
If I make a redundant call to digitalWrite() does it have any effect on the output? For example:
while(true)
  digitalWrite(pinNum, HIGH);
while(true)
  if (digitalRead(pinNum) != HIGH)
Electrically, is there a difference between these two code snippets? For example, does the output waver or stutter at all when the digitalWrite is called?
joshuabardwell:
No.
No.
No.
Ok, thanks.
and if the pin is an input? ]:slight_smile:
robtillaart:
DigitalWrite to an input pin enables or disables the pullup resistor.
but this line makes it conditional
  • if (digitalRead(pinNum) != HIGH) ...
so electrical there could be a difference
robtillaart:
This was the point of the original question, though. And the answer is that setting an I/O pin to the same state that it has already been set to does not make any difference apart from using a few CPU cycles.
