Guys
A little bit of assistance, please.
I have always been led to believe that reed relays are amongst the worst switches for contact bounce, so have always avoided using them, except for things like door open/closed.
I recently got a tipping bucket rain gauge, which is fitted with a reed. First response was to look at replacing with a unipolar hall effect, but no go, as the magnet uses its N pole for the reed.
Next option was to use s/w debounce, but I keep coming across references to the fact that millis and digitalRead don't work well in an ISR. So h/w seemed to be the way to go.
Checking with the scope, I found that the pulse is between 100-120mS, with switch bounce occuring for approx. 60uS. This suprised me as numerous contributers to the forum seem to advocate allowing 5-10mS switch debounce.
So my solution is pin set to INPUT_PULLUP, with an external 10k to 5v and 100nF to Gnd, giving me a time constant of 667uS. Any comments?
As an exercise, I ran this sketch, without the debounce.
const byte pulsepin = A0;
pinMode(pulsepin,INPUT_PULLUP);
Serial.println(digitalRead(pulsepin));
This didn't show any spurious +ve pulses, but I realise that Serial.println and digitalRead both take finite amounts of time, so very short duration glitches could well be missed.
As another exercise, I would like to see what is happening on every iteration of the loop, with minimal time 'lost', ie no Serial or digitalRead. I am guessing that this would require lots of bit bashing, but at this point, with my experience, I am totally out of my depth.
Any suggestions or comments?
TIA
Fof
