'reeks' dos not name a type.
Hello everyone, I am having a little problem with my code.
It is supposed to be a memory game like simon says.
i get the error “Reeks does not name a type”
//Joystick
const int X_pin = A4;
const int Y_pin = A5;
int Joy_Waarde;
//leds
const int led_Rood = 13;
const int led_Groen = 12;
const int led_Blauw = 11;
const int led_Geel = 10;
//componenten
const int buzzer = 4;
//reeks
const int reeksMax = 100;
int reeks[reeksMax];
int reeksIndex = 0;
int X_Value = 0;//Waarde X-Axis Joystick
int Y_Value = 0;//Waarde Y-Axis Joystick
  randomSeed(analogRead(0));
  pinMode (led_Rood, OUTPUT);
  pinMode (led_Groen, OUTPUT);
  pinMode (led_Blauw, OUTPUT);
  pinMode (led_Geel, OUTPUT);
  pinMode(buzzer, OUTPUT);
  Serial.println("Het spel is begonnen!");
  X_Value = analogRead(X_pin);
  Y_Value = analogRead(Y_pin);
  int joy_Blauw = (X_Value == 0);
  int joy_Groen = (X_Value == 1023);
  int joy_Geel = (Y_Value == 1023);
  int joy_Rood = (Y_Value == 0);
  if (joy_Groen == HIGH) {
    digitalWrite(led_Groen, HIGH);
    digitalWrite(led_Groen, LOW);
  if (joy_Blauw == HIGH) {
    digitalWrite(led_Blauw, HIGH);
    digitalWrite(led_Blauw, LOW);
  if (joy_Geel == HIGH) {
    digitalWrite(led_Geel, HIGH);
    digitalWrite(led_Geel, LOW);
  if (joy_Rood == HIGH) {
    digitalWrite(led_Rood, HIGH);
    digitalWrite(led_Rood, LOW);
int leds = random(10, 14);
reeks[reeksIndex] = leds;
for (int i = 0; i = reeksMax;) {
  reeksIndex = 0;
delay(5000);
void reset() {
 int i = 0;
  for (i = 0; i < 4; i++) {
    delay (500);
  reeksIndex = 0;
  delay(3000);
while (huidig > reeksIndex) {
  int laatste_Joy = 0;
  while (joy_Rood == HIGH || joy_Geel == HIGH || joy_Groen == HIGH || joy_Blauw == HIGH) {
      laatste_Joy = led_Rood;
      laatste_Joy = led_Geel;
      laatste_Joy = led_Groen;
      laatste_Joy = led_Blauw;
  digitalWrite(laatste_Joy, LOW);
  if (laatste_Joy != 0){
    if (reeks[huidig] != laatste_Joy){
      reset();
      laatste_Joy = 0;
    }else{
      huidig++;
      laatste_Joy = 0:;
Thank you in advance!
Look carefully where your loop() function ends.
Edit: and your reset () function
for (int i = 0; i = reeksMax;) That's not going to go well.
Thank you for your reply, I think i fixed both of your answers.
I now get an error "a function-definition is not allowed here before '{' token (void reset)
Could you help me with that?
Thank you very much!
Without seeing your code?
Not a hope.
sorry!
here is the code.
void reset() {
    delay (500);
  reeksIndex = 0;
  delay(3000);
All of the code.
Sorry I am new to this.
//Joystick
int Joy_Waarde;
//leds
//componenten
//reeks
int reeksIndex = 0;
  int i = 0;
  for (i = 0; i = reeksMax;) {
    reeksIndex = 0;
  delay(5000);
void reset(){
      delay (500);
    reeksIndex = 0;
    delay(3000);
      if (laatste_Joy != 0) {
        if (reeks[huidig] != laatste_Joy) {
          reset();
          laatste_Joy = 0;
          huidig++;
          laatste_Joy = 0:;
Where does your loop () function end?
At the end of the code.
Blueshirt97:
Then you have defined a function, reset() inside another function, loop(). It's not permitted.
Where should I put the function reset()?
Blueshirt97:
Anywhere outside of loop() or any other function.
By itself, after you close loop().
