I have bought a Reely S-5252-030 digital servo but cannot find out whether it is a 360°, 180° or 90° servo. Where is this info to be found. The datasheet states the torque and actuation time but not the degrees it is capable of.
I am very new to digital servos but I have read that with a 360° servo only the speed, and direction can be controlled but with a 180° (or 90°) servo the angle can be specified. Is this correct?
steveinaustria:
Curiously, this information is often lacking from the web sites that sell servos.
Kind of. A continuous rotation servo can only set speed and direction and yes, they're often referred to as 360 degree servos or ex-servos. Servos exist that have positional control for more than 180 degrees though.
How can I use my Reely Servo S-5252-030?
Wire it up and try it with the servo library. Just try sending it to 100 degrees and see what it does. Note that you may need a separate power supply - the Arduino can't provide enough current.
Continuous rotation servos, often called 360 degree, have no ability to control angle/position, that's correct.
Since you already have the servo it's easiest to run the Sweep or Knob examples from the IDE and see what it does. You should power it with a separate power source NOT from the Arduino 5V pin.
It always seems to be referred to as a "Standard RC servo" so I'd expect it to have positional control and a range of movement somewhere between 120 degrees and 180 degrees.
