reemplazo delay con millis
hola chicos alguien que pueda modificar este esquema en el que se utiliza la función delay en una función idéntica utilizando los millis? Necesito esto para ser capaz de aceptar entradas de Arduino Uno por control remoto.
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
#include <IRremote.h> // usa libreria IR
int receiver = 7; // Ricevitore IR digital pin 7
IRrecv irrecv(receiver); // create instance of 'irrecv'
decode_results results;
  pinMode(8, OUTPUT); //Initiates Motor Channel A pin
  pinMode(9, OUTPUT); //Initiates Brake Channel A pin
  pinMode(10,OUTPUT);//output
  Serial.begin(9600); // for serial monitor output
  irrecv.enableIRIn(); // Start the receiver
  pinMode(13, OUTPUT); // Pin 13 output led
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // Print a message to the LCD.
  lcd.print(" IL PASSATEMPO");
  lcd.setCursor(0, 1);
  // print the number of seconds since reset:
  lcd.print(" SELEZIONA PROG");
  if (irrecv.decode(&results)) // have we received an IR signal?
    Serial.println(results.value, HEX); // display it on serial monitor in hexadecimal
    irrecv.resume();// receive the next value
    while ( results.value == 0xFF30CF ||  results.value == 0xFF30CF ) //tasto 1 sul telecomando
      digitalWrite(13, HIGH);   // set the LED on
      lcd.setCursor(0, 1); // (note: line 1 is the second row, since counting begins with 0):
      lcd.print("  PROGRAMMA 001"); // print the number of seconds since reset:
      //forward @ full speed
      digitalWrite(8, HIGH); //Establishes forward direction of Channel A
      digitalWrite(9, LOW);   //Disengage the Brake for Channel A
      analogWrite(10, 255);   //Spins the motor on Channel A at full speed
      delay(600000); //gira 10 minuti orario
      digitalWrite(9, HIGH); //Eengage the Brake for Channel A
      delay(120000); //freno motore per 2 minuti
      digitalWrite(8, LOW); //Establishes backward direction of Channel A
      digitalWrite(9, HIGH);   //Disengage the Brake for Channel A
      analogWrite(10, 255);   //Spins the motor on Channel A at half speed
      delay(600000); //gira 10 minuti antiorario
      digitalWrite(8, HIGH); //Eengage the Brake for Channel A
      digitalWrite(13, LOW);
      delay(3600000); //si ferma tutto per 1 ora
    while ( results.value == 0xFF18E7 ||  results.value == 0xFF18E7 ) //tasto 2 sul telecomando
      lcd.print("  PROGRAMMA 002"); // print the number of seconds since reset:
      delay(300000); //gira 5 minuti orario
      delay(60000); //freno motore per 1 minuti
      delay(300000); //gira 10 minuti antiorario
      delay(1800000); //si ferma tutto per 30 minuti
    while ( results.value == 0xFF7A85 ||  results.value == 0xFF7A85 ) //tasto 3 sul telecomando
      lcd.print("  PROGRAMMA 003"); // print the number of seconds since reset:
      analogWrite(10, 200);   //Spins the motor on Channel A at full speed
      analogWrite(10, 200);   //Spins the motor on Channel A at half speed
    while ( results.value == 0xFF10EF ||  results.value == 0xFF10EF ) //tasto 4 sul telecomando
      lcd.print("  PROGRAMMA 004"); // print the number of seconds since reset:
      digitalWrite(15, LOW);
      delay(1500000); //si ferma tutto per 25 minuti
gracias
