Ref. Doc. analogRead(3) or/and analogRead(A3)
What is the correct syntax
analogRead(3)
or
analogRead(A3)
or both is correct ?
In the Reference section, in the analogRead() page, there is an exemple containing:
int analogPin = 3; // potentiometer wiper (middle terminal) connected to analog pin 3
val = analogRead(analogPin); // read the input pin
In the Learning section, in the Analog Input Pins, there is an exemple containing:
pinMode(A0, OUTPUT);
Could there be a little sentence in the analogRead() page telling how you name a pin: 3 or A3 or both?
If you want to use an analog pin as a digital pin then A3 is the only correct answer:
pinMode(A3, OUTPUT);  // Set Analog Input 3 as a digital output
digitalWrite(A3, HIGH);  // Set the Analog Input 3 to HIGH
pinMode(3, OUTPUT);  // Set Digital pin 3 as an output
digitalWrite(3, HIGH);  // Set Digital pin 3 to HIGH
For analogRead() you can use 3 or A3 but it is easier to understand if you use A3.
Thank you. :slight_smile:
