Ok, then I'll live with that.
I do not think that batch will be needed - so far I have some 4 arrays that could be updated via json so not a very big deal for batch. Just wanted a bit cleaner code. I am always suspicious when something similar repeats.
My code is far from complete so I am still experimenting.
reads ds18d20 on GPIO 15
publish & receive from MQTT
#include <OneWire.h>
#include <DallasTemperature.h>
#include <WiFi.h>
#include <PubSubClientL.h>
#include <ArduinoJson.h>
#include <Preferences.h>
Preferences prefs;
// Data wire is plugged TO GPIO 15
#define ONE_WIRE_BUS 15
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
// Number of temperature devices found
int numberOfDevices;
// We'll use this variable to store a found device address
DeviceAddress tempDeviceAddress;
// Update these with values suitable for your network.
const char* ssid = "wi-fi";
const char* password = "";
const char* mqtt_server = "172.16.0.14";
const char* TOPIC = "Bruzis";
WiFiClient espClient;
PubSubClient client(espClient);
static char payload[1536];
#define MSG_BUFFER_SIZE (1536)
char msg[MSG_BUFFER_SIZE];
unsigned long lastMsg = 0;
//SETTINGS MATRIX (14 relays)
int i;
//digital sensor ID address HEX
uint8_t T_ID_Arr[14][8] = {
{0x28,0xCC,0x44,0xAD,0x5F,0x20,0x01,0x85},
{0x28,0x6D,0x00,0x25,0x5F,0x20,0x01,0xDD},
{0x28,0x16,0x43,0x10,0x5F,0x20,0x01,0xD3},
{0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0}
byte relayArr [14] = {5, 19, 18, 17, 16, 0, 0, 0, 0, 0, 0, 0, 0, 0}; //corresponding relay pins
byte relayStatusArr[14] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}; //relay high/low status, 0 at the start
byte deviceArr[14] = {1, 1, 1, 2, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0}; //device code, 1-probe, 2-device, 0-unpopulated
byte logicArr[14] = {1,1,2,0,0,0,0,0,0,0,0,0,0,0}; //device logic, 1-up, 2-down, 0-unpopulated
//device pin matrix
byte D_relay_Arr[14][14] = {
{0,0,0,0,0,0,0,0,0,0,0,0,0,0},
{1,0,0,0,0,0,0,0,0,0,0,0,0,0},
{0,1,1,0,0,0,0,0,0,0,0,0,0,0},
// User temperature settings
float targetArr[14];
float deltaArr[14]={1, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
//float targetArrS[14]={26, 26, 26, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
//float deltaArrS[14]={1, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
// END of declarations -------------------------------------------------------------------------------
void setup_wifi() {
// We start by connecting to a WiFi network
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
Serial.print(".");
randomSeed(micros());
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
// This function handles received command messages
void myMessageArrived(char* topic, byte* payload, unsigned int length) {
// Convert the message payload from bytes to a string
String message = "";
for (unsigned int i=0; i< length; i++) {
message = message + (char)payload[i];
// Print the message to the serial port
Serial.print("Incoming message: ");
Serial.println(message);
// extract values from incoming Json
StaticJsonDocument <256> doc;
deserializeJson(doc,payload);
String Array = doc["Array"];
byte Placeholder = doc["Place"];
float newValue = doc["Value"];
//Array[Placeholder] = newValue; does not work?!
if (Array == "targetArr") {targetArr[Placeholder] = newValue}
if (Array == "deltaArr") {deltaArr[Placeholder] = newValue}
// add some later
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
// Create a random client ID
String clientId = "ESP32Client-";
clientId += String(random(0xffff), HEX);
// Attempt to connect
if (client.connect(clientId.c_str())) {
Serial.println("connected");
// mqtt topic for incoming commands
client.subscribe("ESP_in");
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
// function to print a device address
void printAddress(DeviceAddress deviceAddress) {
for (uint8_t i = 0; i < 8; i++){
if (deviceAddress[i] < 16) Serial.print("0");
Serial.print(deviceAddress[i], HEX);
// function to get a device address as String
String formatAddress(DeviceAddress deviceAddress)
String Address;
if (deviceAddress[i] < 16) Address = Address + "0";
Address = Address + String(deviceAddress[i], HEX);
Serial.println(Address);
return Address;
void setup(){
// start serial port
prefs.begin("targetArr"); //namespace
//bytes can be put/get in namespace directly see prefs2struct example
//prefs.putBytes("targetArr", (byte*)(&targetArrS), sizeof(targetArrS));
prefs.getBytes("targetArr", &targetArr, sizeof(targetArr));
setup_wifi();
client.setServer(mqtt_server, 1883);
client.setCallback(myMessageArrived); //initializes incoming commands
// Start up the library
sensors.begin();
// Grab a count of devices on the wire
numberOfDevices = sensors.getDeviceCount();
// locate devices on the bus
Serial.print("Locating devices...");
Serial.print("Found ");
Serial.print(numberOfDevices, DEC);
Serial.println(" devices.");
// Loop through each device, print out address
for(int i=0;i<numberOfDevices; i++){
// Search the wire for address
if(sensors.getAddress(tempDeviceAddress, i)){
Serial.print("Found device ");
Serial.print(i, DEC);
Serial.print(" with address: ");
printAddress(tempDeviceAddress);
//Serial.println(tempDeviceAdress, DEC);
Serial.print("Found ghost device at ");
Serial.print(" but could not detect address. Check power and cabling");
// Set up the relay outputs, and start them with LOW
for (i = 0; i < 14; i++) {
pinMode(relayArr[i], OUTPUT);
digitalWrite(relayArr[i], LOW);
void cool (float tempC, int i)
// need probe check if exists
if(relayStatusArr[i] == 0 and tempC >= targetArr[i] + deltaArr[i]){
digitalWrite(relayArr[i], 1);
relayStatusArr[i] = 1;
if(relayStatusArr[i] == 1 and tempC <= targetArr[i]){
digitalWrite(relayArr[i], 0);
relayStatusArr[i] = 0;
void heat (float tempC, int i)
if(relayStatusArr[i] == 0 and tempC <= targetArr[i] - deltaArr[i]){
if(relayStatusArr[i] == 1 and tempC >= targetArr[i]){
void PumpStatusCheck(int index)
relayStatusArr[index] = 0;
for (int a = 0; a < 14; a++) {
if (D_relay_Arr[index][a] != 0) {
relayStatusArr[index] |= relayStatusArr[a];
digitalWrite(relayArr[index], relayStatusArr[index]);
void loop(){
if (!client.connected()) {
reconnect(); // maintain MQTT connection
client.loop();
sensors.requestTemperatures();
if (deviceArr[i] == 1){ // detect probe mark in array
//check if sensor exists
float tempC = sensors.getTempC(T_ID_Arr[i]);
if (logicArr[i] == 1) {
heat(tempC, i);
else if (logicArr[i] == 2){
cool(tempC, i);
} else if (deviceArr[i] == 2){ //detect device mark in array
PumpStatusCheck (i);
long now = millis();
if (now - lastMsg > 50000) {
lastMsg = now;
DynamicJsonDocument doc(1536); // maximum size for 14 boxes is recomended 1536 (min 1120)
doc[String(i)]["T"]=round(tempC*10)/10;
doc[String(i)]["R"]=digitalRead(relayArr[i]);
doc[String(i)]["P"]=targetArr[i];
doc[String(i)]["L"]=int(logicArr[i]);
serializeJsonPretty(doc, payload);
client.publish("B_Status", payload);
//serializeJsonPretty(doc, Serial);
//Serial.println();
