Reference to a String Array:
HI,
I have this pseudo/test code:
(Sorry for NOT Marking the code below, I have seearched for the CTL ????? (mark key(s)) in help, but I Just can't find it. Deeply sorry )
String Destin[] = {"WR","RD","DIR","ANA","PULL"};
String Command[] = {"GO","STOP","HELP"};
String Str = "GO";
Str.toUpperCase();
for (int n = 0; n <= 3; ++n)
if (Command[n] == Str)
Serial.println('Command found ');
Serial.println('Command not found ');
It does not work as I hoped. Instead I get a random number (error number (?)) written 3 times (Serial.println(..)) .
Question:
Is it possible in ARD C to do something as shown (modifying my code) or how should I do IT ?
Kris AKA Snestrup2016
Please read this before posting a programming question and take the advice regarding the use of code tags then post a complete program that can be compiled that demonstrates the problem.
Command has only three elements; don't try retrieving the fourth.
HI,
#UKHeliBob : Thanks for the advice. Actually I knew it. MY fault. I apologize.
#AWOL: Correct. A big, big TYPO. Sorry, I should have discovered that - before I send the code. I was a bit frustrated, working on the code since early morning.
Here is the code (total):
String Istr;
byte _comma_count = 0;
String msg_fields[20] = "";
int Antal; /* danish for NUMBER */
String Command[] = {"WR","RD","HELP"};
String Str = "WR";
Istr = readline();
if (Istr != "")
Istr.toUpperCase();
Antal = getCSVfields(Istr);
// this is a test , trying to make it easier to find and manipulate string(s).
for (int n = 0; n <= 2; n++)
Serial.println('Command not found');
if (Antal != 0 )
Serial.print("antal = ");
Serial.println(Antal);
Serial.print("comm[0] = ");
Serial.println(msg_fields[0]);
String Comm = msg_fields[0];
Serial.print("NY comm = ");
Serial.print(msg_fields[0]);
Serial.print(" '");
Serial.print(Comm);
Serial.print("' '");
Serial.print(Comm[0]);
Serial.println("' ");
// Tried if (msg_fields[0] = "RD") { } ... does not work
// this works:
if ((0x52 == msg_fields[0][0]) && (0x44 == msg_fields[0][1]))
RDCommand();
else if ((0x57 == msg_fields[0][0]) && (0x52 == msg_fields[0][1]))
WRCommand();
Antal = 0;
Istr = "";
String readline()
if (Serial.available() == 0) return ("");
Istr = "";
Istr = Serial.readStringUntil('\n'); /* \r == CR \n = LF */
return (Istr);
int getCSVfields( String input_buffer)
byte _sentencePos = 0;
_comma_count = 0;
for (int n = 0; n <= 20; ++n)
msg_fields[n] = "";
while (1)
if (input_buffer[_sentencePos] == NULL) break;
if (input_buffer[_sentencePos] == 44) /* , */
_comma_count++;
msg_fields[_comma_count] = "";
_sentencePos++;
msg_fields[_comma_count] += input_buffer[_sentencePos];
_sentencePos++;
return _comma_count + 1;
void RDCommand()
Serial.println("test RD 1 ");
Serial.print("test COMM 2 ");
Serial.println(msg_fields[1]);
return;
void WRCommand()
Serial.println("test WR 1 ");
return;
Why do I have to use Integers as chars in
else if ((0x57 == msg_fields[0][0]) && (0x52 == msg_fields[0][1])) --- this ?
Then why did you decide to ignore the advice again ?
HI,
Yes, You may say i am a fool, and In some ways you're right. (Please don't say it loudly !).
I have printed the approx. 15 pages and I can assure you, that I WILL read it again. Carefully and concentrated.
You don't. 0x57 is the same as 'W' and 0x52 is the same as 'R'.
    msg_fields[n] = "";
Crapping on element 21 of a 20 element array is still NOT a good idea.
