The internal reference voltages of the ATmega are NOT precise. 1.1V really means 1.1V+/-10% (or so…actual numbers are in the datasheet).
Yes, how is your circuit wired up? Voltage divider? If so, what is the other resistance value? How much is your temp sensor’s resistance going to change? That will help answer the question of how much current you’re drawing.
That’s over the full voltage (1.8 – 5.5v) and temperature operating range, with a regulated 5v supply would you really expect the internal reference to vary anywhere near that amount?
Yes, I would expect that much variance anyways. Accurate references are individually laser-trimmed and I doubt Atmel goes to that extra level of expense.
These are inexpensive microcontrollers, with inexpensive imprecise on-chip oscillators, inexpensive imprecise A/D's, and an inexpensive imprecise voltage reference. It does the job it's meant to do, but if you want high clock accuracy you use a crystal, high A/D accuracy you use an external part, and high voltage reference accuracy, you use an external reference.
I am traveling at the moment so can't test it myself, but if you have a reasonably accurate voltmeter, could you see how much actual error you get with your ATmega ADC measurements when using the internal reference.
Sounds like a fun thing to try with several boards and get some statistics. I'll just look at the AREF output directly rather than do A/D conversions as those will be subject to the inaccuracies of the converter itself. Sounds like a project for this weekend...I'll post the results.
Thanks for all the replies! I’m really having touble putting the right knowledge together (although Grumpy_Mike’s site helped alot).
I wired it (the oil temp resistor going right into the engine’s carter) up as follows:
So (correct me when I am wrong) I concluded: supplying 1.1V ref voltage will set the highest temperature of the sensor to:
((10 Ohm * 5V) / 1.1V) - 10 Ohm = 35.5 Ohm
This results in a high temp range (>150degC).
But actually I want to filter out >2000 Ohm and apply the ADC resolution to the part from 2000 Ohm - 40 Ohm. But I think I will get enough resolution when setting ref to 1.1V (temporary when I read out the oil temp since the orther sensors should use a ref of 5V).
When I do set the reference voltage to internal (1.1V), but still supply 5V as drawn above.
How do I calculate the resistance value? (So I can lookup the value in a R->Temp table).
I used to do this with: ((1023*10 Ohm) / measured voltage) - 10 Ohm
But obviously this is not correct anymore since 1.1V is now 1023? :-/
Since the maximum measurable voltage is 1.1 Volt this equals 1023.
This means when we theoretically measure 5V we should get a value of 4560 (1023*5/1.1). So to measure R:
