They don’t work because they won’t connect to any of the apps that came with the instructions. They are generic and off brand. Any idea if/how they can be reflashed with code that I could use to control it. I assume it has something similar to an esp8226 to control the on board 5v relay…..
I have a ftid adapter that I have flashed sonoff devices with before, but don’t really know how I would reflash this. Any ideas?
SmartEHome+ Is what it suggests. But I can’t even find it. I bought these over a year ago. I just found them and have been fooling around with esp8226 based on how it looked thought I may be able to do something with them.
It certainly could be a predecessor to the existing 8266, but I doubt it’s compatible with the current tool chain...
If it is WIFI and Alexis compatible, there’s a chance the API and cloud support no longer exists.
The bottom line is that you need more detailed information…
Now for the possibilities…
You could possibly replace that daughterboard with a real ESP, and program it to work the way you want, but these modules are so cheap, it would only be for something custom.
Luckily, it looks like the I/o pins have been listed, so a bit of reverse engineering shouod yield results.
I think you may have hit the nail on the head. I just saw them in my junk pile and thought if it were something simple I would flash them some how and make use of them, but it seems it is not going to be an easy task. I appreciate the help though!
Hello, I also have 3 of these smart plugs and I cannot use them because the app does not work, I disassembled one of them and removed the wifi module, I connected it through an arduino uno to 3v and serial communication with pins 12 and 13, to listening to this module is necessary to configure a baud rate of 74880 and activate NR and CL. The answer is the following:
ets Jan 8 2013,rst cause:2, boot mode:(3,6)
load 0x40100000, len 2592, roo1tail 0
chksum 0xf3
load 0x3ffe8000, len 764, room 8
tail 4
chksum 0x92
load 0x3ffe82fc, len 6rm
tail 0
chksum 0x22
csu0
nbvo (f
Pe HSM:OSF eM8t25)jtne@0
rf cal sector: 251
freq trace enable 0
rf[112] : 00
rf[113] : 00
rf[114] : 01
Dr.(9 mdu 13:
v16pe1
Deo267
t_auic:1r s
=========|vi2199ai26iavo20CitI1
=========!!!hiEfw, pi
e 61:6)oA:98:
d
ce ai96.s555,11.
n0U_Deepept, u c
l1d (1:6cset station mode to scan test AP
scandone
TESTing scan done, status=0
~~> rescan testing AP 1
set station mode tct scandone
~~> rescan testing AP 2
set station mode t
scandone
test AP not found, start working
enter deln
AO_ elor0oa
214f i>
vS ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮,s ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮
<dn _0_rtn0sda
aies:7-------
..........reset_count = 0
.....................................................................................................................................................................................................................................NOT start checking server response
I analyzed the board and I was able to replicate the action of the button and the 2 LEDs, only 2 resistors are needed, a button and 2 LEDs, as shown in the photo.
