sterretje:
Post your code as you see it in the IDE.
1)
Place your cursor in the code window and press T (that is, control and t at the same time) to format the code.
2)
copy the code
3)
use code tags as shown below when positing the code
type
** **[code]** **
paste your code after that
type
** **[/code]** **
The result ill look like
your code here
Next, compile. The output window will show the errors. Click in the output window, scroll through it and select all 'orange' text. Using the above principle, post the errors using code tags.
* PID Basic Example
* Reading analog input 0 to control analog PWM output 3
#include <PID_v1.h>
#define PIN_INPUT 0
#define PIN_OUTPUT 3
//Define Variables we'll be connecting to
double Setpoint, Input, Output;
//Specify the links and initial tuning parameters
double Kp=2, Ki=5, Kd=1;
PID myPID(&Input, &Output, &Setpoint, Kp, Ki, Kd, DIRECT);
//initialize the variables we're linked to
Input = analogRead(PIN_INPUT);
Setpoint = 100;
//turn the PID on
myPID.SetMode(AUTOMATIC);
myPID.Compute();
analogWrite(PIN_OUTPUT, Output);
* PID Adaptive Tuning Example
* One of the benefits of the PID library is that you can
* change the tuning parameters at any time. this can be
* helpful if we want the controller to be agressive at some
* times, and conservative at others. in the example below
* we set the controller to use Conservative Tuning Parameters
* when we're near setpoint and more agressive Tuning
* Parameters when we're farther away.
#include <PID_v1.h>
#define PIN_INPUT 0
//Define the aggressive and conservative Tuning Parameters
double aggKp=4, aggKi=0.2, aggKd=1;
double consKp=1, consKi=0.05, consKd=0.25;
PID myPID(&Input, &Output, &Setpoint, consKp, consKi, consKd, DIRECT);
Setpoint = 100;
//turn the PID on
double gap = abs(Setpoint-Input); //distance away from setpoint
if (gap < 10)
{ //we're close to setpoint, use conservative tuning parameters
myPID.SetTunings(consKp, consKi, consKd);
//we're far from setpoint, use aggressive tuning parameters
myPID.SetTunings(aggKp, aggKi, aggKd);
myPID.Compute();
* PID RelayOutput Example
* Same as basic example, except that this time, the output
* is going to a digital pin which (we presume) is controlling
* a relay. the pid is designed to Output an analog value,
* but the relay can only be On/Off.
* to connect them together we use "time proportioning
* control" it's essentially a really slow version of PWM.
* first we decide on a window size (5000mS say.) we then
* set the pid to adjust its output between 0 and that window
* size. lastly, we add some logic that translates the PID
* output into "Relay On Time" with the remainder of the
* window being "Relay Off Time"
#include <PID_v1.h>
#define PIN_INPUT 0
#define RELAY_PIN 6
int WindowSize = 5000;
unsigned long windowStartTime;
windowStartTime = millis();
Setpoint = 100;
//tell the PID to range between 0 and the full window size
myPID.SetOutputLimits(0, WindowSize);
//turn the PID on
myPID.Compute();
* turn the output pin on/off based on pid output
if (millis() - windowStartTime > WindowSize)
{ //time to shift the Relay Window
windowStartTime += WindowSize;
if (Output < millis() - windowStartTime) digitalWrite(RELAY_PIN, HIGH);
else digitalWrite(RELAY_PIN, LOW);
* Thermocouple to serial for MAX31855 example
* Version: 1.00
* Date: 26-12-2011
* Company: Rocket Scream Electronics
* Website: www.rocketscream.com
* This is an example of using the MAX31855 library for Arduino to read
* temperature from a thermocouple and send the reading to serial interfacec.
* Please check our wiki (www.rocketscream.com/wiki) for more information on
* using this piece of library.
* This example code is licensed under Creative Commons Attribution-ShareAlike
* 3.0 Unported License.
* Revision Description
* 1.00 Initial public release.
// ***** INCLUDES *****
#include <MAX31855.h>
// ***** PIN DEFINITIONS *****
const unsigned char thermocoupleSO = 12;
const unsigned char thermocoupleCS = 10;
const unsigned char thermocoupleCLK = 13;
MAX31855 MAX31855(thermocoupleSO, thermocoupleCS, thermocoupleCLK);
Serial.begin(57600);
double temperature;
// Retrieve thermocouple temperature in Degree Celsius
temperature = MAX31855.readThermocouple(CELSIUS);
Serial.print("Thermocouple temperature: ");
Serial.print(temperature);
Serial.println(" Degree Celsius");
// Retrieve cold junction temperature in Degree Celsius
temperature = MAX31855.readJunction(CELSIUS);
Serial.print("Junction temperature: ");
